FXP543.A.07.A.001
FXP543.A.07.A.001
    TAOGLASLIMITED
    FXP543.A.07.A.001
FXP543.A.07.A.001 数据手册
SPECIFICATION Part No. : FXP543.A.07.A.001 Description : Venti Circular 2.4/5.8GHz Flexible PCB Antenna Internal 3 x MIMO 100mm 1.37 mini coax cable with IPEX MHFHT Features : Dual Band WiFi MIMO x 3 Frequency 2.4~2.5GHz, 5.15~5.85GHz 45% efficiency and 1.5 to 5 dBi peak gain Diameter : 37mm, Thickness : 0.15mm Port 1, 2, 3 – 100mm Ø1.37 mini coaxial cable with IPEX MHFHT connector (U.FL comp) 3M adhesive for easy mounting RoHS compliant DSP-15-8-SPE-15-8-047/A/SS Page 1 of 21 1. Introduction The unique FXP543 Venti Circular antenna is the smallest 3-in-1 MIMO, internal flexible monopole type antenna for WiFi 2.4/5.8GHz in the market Featuring a thickness of only 0.15mm, the FXP543 is an ideal solution for gateways, routers, smart city applications such as WiFi hot spots, smart lighting control, video surveillance and traffic monitoring. The FXP543 has over 45% efficiency in both the 2.4GHz and 5GHz bands. It has been designed on a flexible material with a circular form-factor and cable connection for an easy installation. Great care has been taken to have high isolation (at least 10dB) between the three elements to ensure optimal MIMO system throughput. The antenna comes with double-sided 3M adhesive for easy and robust "peel and stick" mounting. Three cables terminate with IPEX (u.fl) connectors for easy installation. *If needed in order to comply with peak gain restrictions with certain wireless modules, the antenna peak gain can be reduced by simply using longer cable, or when tested in the actual device environment. Many module manufacturers specify peak gain requirements for any antennas that is to be connected to that module. Upon testing of any of our antenna with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas peak gain will be below the peak gain requirements. Taoglas can then issue a specification and/or report for this selected WiFi antennas in your device that will clearly show it complying with the peak gain requirements, so you can be assured you are meeting regulatory requirements for that module. DSP-15-8-SPE-15-8-047/A/SS Page 2 of 21 2. Specification ELECTRICAL * Port 1 Port 2 Port 3 Frequency(MHz) 2400-2500 5150-5850 2400-2500 5150-5850 2400-2500 5150-5850 Efficiency (%) 47.02 44.25 61.30 47.21 51.13 45.02 Peak Gain (dBi) 2.96 5.16 2.24 3.40 1.80 3.76 Average Gain (dBi) -3.28 -3.56 -2.13 -3.28 -3.30 -3.38 Return Loss (dB) < -10
FXP543.A.07.A.001 价格&库存
很抱歉,暂时无法提供与“FXP543.A.07.A.001”相匹配的价格&库存,您可以联系我们找货
FXP543.A.07.A.001
