Meteor
Part No:
FW.24.SMA.M
Description:
Meteor 2.4GHz Flexible Whip Monopole Antenna
Features:
External 2.4GHz Monopole Antenna
Rugged Design for Outdoor Use
Over 70% Efficiency*
Over 4dBi Peak Gain*
Robust Inner Steel Core
Antenna height 316mm
SMA(M) Straight Connector
IP65 dust and water-resistant
*Tested on 30*30cm Ground Plane
RoHS Compliant
SPE-17-8-003/C/AW
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
Radiation Patterns
8
5.
Mechanical Drawing
11
6.
Packaging
12
Changelog
13
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-17-8-003/C/AW
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The FW.24 is a flexible 2.4GHz whip antenna with a SMA(M) connector for outdoor use. It features excellent
efficiency (>75%) and high peak gain (>4 dBi) between 2400-2500MHz on a 30*30cm ground plane.
The antenna was specifically developed for applications such as weather monitoring systems,
motion/vibration sensors, pollution monitoring, and border guard monitoring systems.
Introduction
The FW.24 works in the 2.4 GHz Wi-Fi/Bluetooth/ISM band with high efficiency, meaning that it allows your
radio to consume less power than with a lower efficiency antenna when transferring data. The antenna
performs at its best while attached to a ground plane with dimensions of at least 30*30cm.
Introduction
The whip is made of a flexible inner steel core covered by PE so it is extremely resistant to abrasion and
maintains its original shape and RF performance. This rugged design and IP65 rating has been tested by
customers to withstand environmental stress and moderate physical shock in the field.
Introduction
The FW.24.SMA.M 2.4GHz antenna provides a simple solution to any outdoor devices where the FW.24
antenna’s rugged design and high efficiency can provide the best value to the application. For example, a
module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to
select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less
optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available.
Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due
to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure,
contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified
by the module manufacturer and enlisting our help will ensure you are getting the best performance possible
without exceeding the peak gain limits.
Other connector options are available or custom versions can be made subject to NRE and MOQ. Contact
your regional Taoglas office for details.
SPE-17-8-003/C/AW
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
3.
4.
4.
2400~2500MHz
In free space
On 30x30cm ground
64.5%
79.3%
4.26dBi
4.48dBi
Return loss
< -6dB
< -10dB
VSWR
≤ 3:1
≤ 2:1
Efficiency
Antenna
Characteristics
Peak Gain
Antenna
Radiation Patterns3.Antenna
Impedance
Polarization
3.
Specifications
Frequency
Characteristics2.
Radiation Pattern
3.
2.4GHz Wi -Fi
50Ω
Linear
Specifications
Omni-Directional
Input Power
2W
Total Power
10 W
Specifications
Mechanical
Dimensions
Height 307 ± 6 mm
Base Diameter
16 ± 0.8 mm
Whip Diameter
Antenna
Characteristics
6.2 ± 0.6 mm
Casing
ABS
Connector
SMA Male Straight
Weight
46.6 g
Antenna
Dust and Water Resistance
Characteristics
IP65
Environmental
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
4.
Antenna Radiation Patterns
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
Characteristics2.
SPE-17-8-003/C/AW
Specifications
www.taoglas.com
4
3.
4.
3.1
Return Loss
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-17-8-003/C/AW
www.taoglas.com
5
3.2
Efficiency
SPE-17-8-003/C/AW
www.taoglas.com
6
3.3
Peak Gain
SPE-17-8-003/C/AW
www.taoglas.com
7
4.
Radiation Patterns
4.
4.
4.
4.1
Test Setup
Y
4.
X
4.
4.
Antenna Radiation PatternsFree space
4.
Z
Y
X
4.
Z
On 30x30 cm ground plane
SPE-17-8-003/C/AW
www.taoglas.com
8
4.2
3D and 2D Radiation Patterns
3-D Radiation Pattern in free space @2450MHz
XY Plane
SPE-17-8-003/C/AW
XZ Plane
YZ Plane
www.taoglas.com
9
3-D Radiation Pattern on 30cm*30cm Ground Plane @2450MHz
XY Plane
SPE-17-8-003/C/AW
XZ Plane
YZ Plane
www.taoglas.com
10
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
8.
6.
Packaging
Packaging5.
SPE-17-8-003/C/AW
Mechanical Drawing
www.taoglas.com
11
6.
Packaging
6.
Packaging5.
6.
7.
Mechanical Drawing
1pcs FW.24.SMA.M per PE Bag
Bag Dimensions - 420*50mm
Weight - 41g
Packaging
Mechanical
Drawing
50pcs FW.24.SMA.M per Large PE Bag
Bag Dimensions - 520*370mm
Weight - 2.2Kg
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
200pcs FW.24.SMA.M per Carton
Carton Dimensions - 360*310*150mm
Weight - 8.4Kg
7.
Application Note
7.
7.
Pallet Dimensions:
1200*1000*1480mm
72 Cartons Per Pallet
9 Cartons Per Layer
8 Layers
Mechanical
Drawing
6.
Packaging5.
SPE-17-8-003/C/AW
Mechanical Drawing
www.taoglas.com
12
Changelog for the datasheet
SPE-17-8-003 - FW.24.SMA.M
Revision: C
Date:
Changes:
Changes Made by:
2019-08-16
Updated to new format
Dan Cantwell
Previous Revisions
Revision: B (Current Version)
Date:
Changes:
Changes Made by:
2017-10-19
Changed IP Rating to IP65
Carol Faughnan
Revision: A (Original First Release)
Date:
Notes:
2017-06-01
Author:
Andrew Wei
SPE-17-8-003/C/AW
www.taoglas.com
13
www.taoglas.com
SPE-17-8-003/C/AW
© Taoglas
www.taoglas.com
14
很抱歉,暂时无法提供与“FW.24.SMA.M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+79.57089
- 30+78.08370
- 55+76.60859
- 100+73.64630
- 国内价格
- 6+137.57931
- 24+123.81659
- 国内价格 香港价格
- 1+165.618861+21.48891
