IAA.01.121111
IAA.01.121111
    TAOGLASLIMITED
IAA.01.121111 数据手册
Iridium Certified Antenna Part No: IAA.01.121111 Description: External magnetic mount Iridium antenna Features: 1616 − 1626.5 MHz Designed to work in conjunction with a 30*30cm Ground plane Connector: SMA(M) ST Cable: 1.2m RG-174 Custom cables and connectors available Iridium has certified the IAA.01.121111 antenna for commercial use in connection with the Iridium Communications System RoHS & REACH Compliant SPE-13-8-009-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. 2D Radiation Patterns 8 5. 3D Radiation Patterns 10 6. Mechanical Drawing 11 7. Packaging 12 Changelog 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-13-8-009-E www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. Introduction The IAA.01 is a high-performance magnetic mount antenna which is designed specific to communicate efficiently with the Iridium® Satellite Communication system. The IAA.01 has been specifically designed to 1. work on a 30*30cm ground plane. Introduction The IAA.01 utilises the Taoglas expertise in ceramics by incorporating a ceramic patch tuned specifically for the antenna environment, giving greater stability. The antenna housing is strong, corrosive proof and 1. Introduction waterproof to IP67. The magnetic mount allows for easy installation and removal between vehicles or assets, it is easily converted to an adhesive type for greater flexibility. 1. Introduction Iridium® has certified the IAA.01.121111 Antenna for commercial use in connection with the Iridium Communications System. Iridium Satellite LLC is the owner of “Iridium” and all other Iridium trademarks, service marks and logos contained herein. The cable and connector are fully customizable, for more information contact your regional Taoglas Customer Support Team. SPE-13-8-009-E www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. 3. Electrical Specifications Frequency Range (MHz) 1616-1626.5MHz Centre Frequency 1621MHz Peak Gain (dBi) Antenna Characteristics With Ground plane(30x30cm) 3.7 Average Gain (dB) 4. With Ground plane(30x30cm) Antenna Radiation Patterns3. Antenna Efficiency (%) With Ground plane(30x30cm) Characteristics2. Specifications 3. -2.1 62 Impedance 50Ω VSWR 1.2 Polarization Antenna Characteristics2. RHCP Specifications Bandwidth 31.5kHz Mechanical 3. 4. Dimensions Antenna Characteristics 40.5 x 38 x 12.3mm Cable 1.2m of RG-174 Casing ABS Antenna ConnectorRadiation Patterns3.Antenna SMA Male Straight Ground Plane Size Characteristics 30 x 30cm Environmental 4. 4. Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Relative Humidity 40% to 95% RH Termination Ag (Environmentally Friendly PB Free) Antenna Radiation Patterns Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-13-8-009-E Characteristics2. Specifications www.taoglas.com 4 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-13-8-009-E www.taoglas.com 5 3.3 Average Gain 3.4 Peak Gain SPE-13-8-009-E www.taoglas.com 6 3.5 VSWR SPE-13-8-009-E www.taoglas.com 7 4. 4. 2D Radiation Patterns 4.1 Test Setup on a 30*30 Ground Plane Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-13-8-009-E www.taoglas.com 8 XY Plane X 0 345 10 330 5 0 315 -5 -10 300 -15 -20 -25 285 -30 -35 270 -40 15 30 45 60 75 90 255 Y 105 240 1621 MHz 120 225 135 210 150 195 165 (dBi) 180 ZX Plane Z 330 0 345 10 15 30 5 0 -5 -10 -15 -20 -25 -30 -35 -40 315 300 285 270 45 60 75 90 255 105 240 X 1621 MHz 120 225 135 210 150 195 ZY Plane 180 165 (dBi) Z 0 345 330 315 300 285 270 15 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 30 45 60 75 90 255 105 240 1621 MHz 120 225 135 210 150 195 165 180 SPE-13-8-009-E Y (dBi) www.taoglas.com 9 5. 3D Radiation Patterns 5.1 Mounted on 30cm x 30cm metal ground plane 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 1621 MHz 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-13-8-009-E 1621 MHz www.taoglas.com 10 6. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-009-E Mechanical Drawing www.taoglas.com 11 8. 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-009-E Mechanical Drawing www.taoglas.com 12 Changelog for the datasheet SPE-13-8-009 – IAA.01.12111 Revision: E (current version) Date: Changes: Changes Made by: 2020-02-07 New Test Data Jack Conroy Previous Revisions Revision: D Date: Changes: Changes Made by: 2019-05-02 New Test Data Jack Conroy Revision: C Date: Changes: Changes Made by: 2019-02-19 Updated the drawing Jack Conroy Revision: B Date: Changes: Changes Made by: 2014-02-27 Iridium Certification Aine Doyle Revision: A (Original Release) Date: Changes: Changes Made by: SPE-13-8-009-E 2013-01-25 Aine Doyle www.taoglas.com 13 www.taoglas.com © Taoglas SPE-13-8-009-E www.taoglas.com 14
IAA.01.121111 价格&库存
很抱歉,暂时无法提供与“IAA.01.121111”相匹配的价格&库存,您可以联系我们找货
IAA.01.121111
    IAA.01.121111
      • 100+268.91599
      库存:1
