R2T24LW-15-RMMCX
R2T24LW-15-RMMCX
    LAIRD(莱尔德)
    ANT ROOTENNA 15DBI 8" RMMCX
R2T24LW-15-RMMCX 数据手册
R2T2458 RooTenna® 2 Panel Antenna Innovative Technology for a Connected World ROOTENNA® 2 PANEL ANTENNA: 2.4 & 5.8 GHz OPERATION R2T24W-15 Regular Profile The RooTenna® 2 panel antenna offered by Laird Technologies was developed to allow integration of the customer’s radio equipment inside the weatherproof compartment. The expanded radio compartment is big enough to house transceivers, amplifiers, and other electronic equipment. Two sizes are available - the regular and a lower profile RooTenna®. The antenna design utilizes a wideband element array over a solid 8.5 inch square backplane for consistent performance over a wide bandwidth. The housing is UV stabilized ABS plastic. The backplate is alodine coated aluminum with stainless steel fasteners. All bracket fasteners are stainless steel for corrosion protection. There are qty 4 8-32 threaded standoffs provided inside the enclosure for customer mounting. Included with the Roo2 are a customer mounting plate and a patented RJ45-ECS ethernet connector system. R2T24LW-15 Low Profile FEATURES MARKETS • RooTenna®, the antenna with a pouch! • Integrated radio/antenna units • Dual band: 2400-2485 MHz 12 dBi; 4940-5850 MHz 15 dBi • High speed subscriber units • Includes patented RJ45-ECS ethernet connector system and customer mounting plate • 802.11a/b/g applications • Amplified antennas • WiMAX • Vertical or horizontal polarization • Available with RPSMA, RPTNC, MC Card, MMCX, RPMMCX and U.FL antenna connector ANTENNA PATTERNS -15 0 -3 -15 15 -30 60 75 -40 90 -90 105 -105 125 -125 135 -135 150 -150 165 180 2400 MHz Europe: +1.32.80.7866.12 IAS-EUSales@lairdtech.com Asia: +1.65.6.243.8022 IAS-AsiaSales@lairdtech.com www.lairdtech.com TM 45 -60 60 -30 -30 Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com 30 -45 -20 -60 60 -75 15 -10 -20 -60 0 -3 -30 45 -20 global solutions: local support -15 30 -45 45 -165 15 -10 -45 -75 0 -3 -30 30 -10 -30 75 -40 90 -90 -75 75 -40 90 -90 105 -105 105 -105 125 -125 125 -125 135 -135 135 -135 150 -150 -165 165 180 5150 MHz 150 -150 -165 165 180 5825 MHz R2T2458 RooTenna® 2 Panel Antenna Innovative Technology for a Connected World SPECIFICATIONS PARAMETER MIN Frequency Range (Dual Band) 2400 4940 TYP MAX UNITS 2485 5850 MHz Gain (2400-2485/4950-5850) 12/15 dBi 3db Beam Angle (2450 MHz) 43 Deg 3db Beam Angle (5470 MHz)) 22 Deg Front to Back 25 dB VSWR 1.5:1 Impedance 50 OHM Input Power Operating Temperature -45 Weight 20 W +70 °C 29 (0.8) 10.75 x 10.75 3.5 (267 x 267 x 89) 9 x 9 x 2.25 (229 x 229 x 57) 10.75 x 10.75 x 2.6 (267 x 267 x 67) 9 x 9 x 1.5 (229 x 229 x 38) Dimension R2T2458W Inside Dim R2T2458W Dimension R2T2458LW Inside Dim R2T2458LW oz (kg) in (mm) in (mm) WIND LOADING (LBS) MODEL 100 MPH 125 MPH R2T2458 27.8 43.4 SYSTEM ORDERING INFORMATION R2T2458W-XX R2T2458LW-XX 4940-5850 MHz RooTenna® regular profile 4940-5850 MHz RooTenna® low profile (Please note: Where “xx” appears, please specify connector. Connector options include RPSMA, RPTNC, MC Card, MMCX, RPMMCX and U.FL)) NOTES • All shipments F.O.B. Schaumburg, IL 60173 ANT-DS-R2T2458 0611 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2011 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
R2T24LW-15-RMMCX 价格&库存
很抱歉,暂时无法提供与“R2T24LW-15-RMMCX”相匹配的价格&库存,您可以联系我们找货
