S2307MP18SMM
S2307MP18SMM
    LAIRD(莱尔德)
    DO-214AC(SMA)
    ANT DIRECT PNL 7.5DBI 18"SMA M
S2307MP18SMM 数据手册
October 28, 2015 RE: End of Life Part Numbers This letter is to notify that the attached list of part numbers will go (EOL) End of Life as of 12/31/2015. The final date of sale is 12/31/2015. All items purchased are non-cancelable and non-returnable. Bruce Juhl Account Manager Laird, Infrastructure Antenna Systems 3481 Rider Trail South, Earth City, Missouri 63045 Tel: 636.898.6000 Fax: 636.898.6100 Email: sales@lairdtech.com Web: www.lairdtech.com 2 Part Number CAF28711 CAF28775 CAF28871 CAF28948 CAF28957 CAF28985 CAF29177 CAF94165 (IFD2450-RT36) CAF94408 CAF94503 CAF94571 CAF94675 (IFD2450-RT60) ENA2400SMT-001 EXH2400SMLH J34216V00-120N MAF94001 MAF94003 MAF94015 MAF94025 MAF94035 MAF94044 MAF94049 MAF94050 MAF94058 MAF94062 MAF94065 MAF94068 MAF94078 MAF94080 MAF94096 MAF94097 MAF94107 MAF94109 MAF94121 MAF94123 MAF94124 MAF94127 MAF94132 MAF94133 MAF94134 MAF94140 MAF94141 MAF94142 MAF94143 MAF94146 MAF94147 MAF94148 MAF94151 MAF94156 MAF94163 MAF94164 MAF94190 MAF94198 MAF94225 MAF94229 MAF94234 MAF94239 MAF94243 MAF94257 MAF94258 MAF94262 MAF94265 MAF94275 MAF94276 MAF94356 MAF94357 MAF94358 MAF94368 MAF94376 MAF94379 MAF94381 MAF94385 MAF94389 MAF94403 MAF94404 MAF94410 MAF94411 MAF94412 MAF94422 MAF94423 MAF94433 MAF94436 MAF94439 MAF94441 MAF94459 MAF94460 MAF94461 MAF94462 MAF94466 MAF95025 MAF95028 MAF95035 MAF95056 MAF95057 MAF95066 MAF95067 MAF95081 MAF95087 MAF95092 MAF95098 MAF95099 MAF95100 MAF95104 MAF95107 MAF95289 MKDHK MM-RD-RSMA PC2415XNM36 S1713BNF S1718AMP S1718MP S1856MPC10NF S1857AMP S1857MP S2307AMP S2307AMP36RTN S2307MP S2307MP10RTN S2307MP10SMF S2307MP10TNF S2307MP18SMM S2307MP36RTN S2406BH12RTN S2407HVP12NF S2407SLP12NF S2408P36NM S2409P36RTN S24493BFNF S24493BPX12SMF S24493BPX36RSM S24493DM36NM S24493DM-91RTNM S24497PDA96RTN S5153BH36RTN S5153BH7RSM S5158WBPX36NM S57212AMP S57212AMP10NF S57212MP S57212MP10NF S57212MP42NM S8243B S8802MP10NF SAF25054 SAH35-90-16 SAH58-120-16-WB SAH58-90-17-WB SL2453WP36RNF SL8064P12NF SL8064P36SMM SO24-120X3-15 SQ2303P12NF SQ2303P-203NM SQ2303P36RSM SQ2303P36RTN SQ2303P72RTN SQ2303PNF SQ2405DD12NF SQLBRK WCP2400MMCX1 WCP2400MMCX3 WCP2400MMCX5 WCP2400MMCX7 WCP2400MMCX8 WCR2400MMCX WTL2449CQ1-BRSMM WTL2449SA-10 WTL2449SA1-15UFL YE240015R Part Description DUCK,CXR,RTNM EXE-Series Rubber Duck, 1/2-wave coaxial dipole Antenna operating over 2400-2500 MHz with Unity Gaing and a Reverse TN DUCK,COAX,MMCXP, 2400-2500 MHz DUCK,A,1/4,SMAM DIPOL,WCP,127,IPX MHF DUCK,CXR,RTNM, 1400 MHz DUCK,WXE,TNCM 2.4 GHz Micropshere Diversity, 2400-2500 MHz, 3 dBi Omnidirectional Infrastructure/In-building antenna with 36" Plenum ra DUCK,WIC2452 802.11 b/g, 2400-2500 MHz, Mcblue Embedded Antenna with 2.0 dBi gain and 76 mm RG178 coaxial cable terminated in an DUCK,MICROBLUE,STR RSMAM 2.4 GHz Micropshere Diversity, 2400-2500 MHz, 3 dBi Omnidirectional Infrastructure/In-building antenna with 60" Plenum ra NanoAnt BT2.0 Embedded SMT Antenna DUCK,EXH,2400MHz Sectr,V-Pol,120Dg,NF 802.11 b/g, 2400-2500 MHz, Right Angle Dipole with 2 dBi gain and 86mm of RG178 coaxial cable terminated in a Flying Lead DIPOL,WTBP,150,IP MHF WCR-series , 2400-2500 MHz, dipole with 3.9" (100 mm) of RG178 coaxial cable and a flying lead (i.e. no connector) WTBP- series 802.11 a/b/g 2400-2500/4900-6000 MHz, Dipole antenna with 2.0-3.0 dBi nominal gain with 5.9" (150 mm) of WTS-series 802.11 abg, 2400-2500/4900-5875 MHz, dipole antenna with 130mm of RG178 coaxial cable terminated with a fl 802.11 b/g, 2400-2500 MHz, Mcblue Embedded Antenna with 2.0 dBi gain and 203 mm RG178 coaxial cable terminated in an WRR-series , 2400-2500 MHz, dipole with 4.9" (125 mm) of RG113 coaxial cable terminated with an IPEX connector and a ferr WTC-series 802.11 abg, 2400-2500/4900-6000 MHz, Dipole antenna with 2.0-3.7 dBi nominal gain terminated with a Reverse WCP-series , 2400-2500 MHz, dipole with 14" (356 mm) of RG178 coaxial cable and an MMCX connector WTS-series 802.11 abg, 2400-2500/4900-5875 MHz, dipole antenna with 130mm of 1.13 mm coaxial cable terminated with a WRR-series , 2400-2500 MHz, dipole with 5.1" (130 mm) of RG113 coaxial cable terminated with an IPEX connector and a ferr WRR-series , 2400-2500 MHz, dipole with 2.6" (65 mm) of RG113 coaxial cable terminated with an IPEX connector and a ferri Bluechip- Embedded,Antenna operating over 2400-2500/4900-6000 MHz with 2-3 dBi gain and 45 mm of OD113 coaxial cabl 802.11 a/b/g Right Angle Dipole Antenna operating over 2400-2500/4900-6000 MHz with 2-3 dBi gain and 86 mm of RG178 c WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 110mm of 1.13 mm coaxial cable terminated with a IPX connecto 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 9.8 in (250 mm) of RG178 coaxial cable term WTS-series 802.11 abg, 2400-2500/4900-5875 MHz, dipole antenna with 356mm of RG178 coaxial cable terminated with a ST 802.11 a/b/g Embedded Antenna, NanoGreen, 2-4 dBi, 16.5 x 51 mm (wxl), with 128 mm of 1.13mm coaxial cable terminate 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 3.5 in (90 mm) of RG113 terminated with an I 802.11 a/b/g Embedded Antenna, NanoGreen, 2-4 dBi, 16.5 x 51 mm (wxl), with 129 mm of 1.13mm coaxial cable terminate WTS-series 802.11 abg, 2400-2500/4900-5875 MHz, dipole antenna terminated with an Reverse Polarity SMA male connecto WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 110mm of 1.13 mm coaxial cable terminated with a IPX connecto WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 110mm of 1.13 mm coaxial cable terminated with a flying lead. A WTS-series 802.11 abg, 2400-2500/4900-5875 MHz, dipole antenna terminated with an SMA male connector Nickel Plated. A WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 110mm of 1.13 mm coaxial cable terminated with a IPX connecto WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 110mm of 1.13 mm coaxial cable terminated with a IPX connecto WRR-series , 2400-2500 MHz, dipole with Round Sleeve, 5.1" (130 mm) of RG113 coaxial cable terminated with an IPEX conn WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 100mm of RG178 coaxial cable terminated with a flying lead. An WRR-series , 2400-2500 MHz, dipole with Round Sleeve and 3.9" (100 mm) of RG178 coaxial cable terminated with an IPEX co 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 8 in (203 mm) of RG113 coaxial cable termi WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 100mm of 1.13 mm coaxial cable terminated with a IPX connecto 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 1.9in (47 mm) of RG113 coaxial cable termi WRR-series , 2400-2500 MHz, dipole with 5.1" (130 mm) of RG113 coaxial cable terminated with an IPEX connector and a ferr WRR-series , 2400-2500 MHz, dipole with Round Sleeve, 5.1" (130 mm) of RG113 coaxial cable terminated with an IPEX conn WRR-series , 2400-2500 MHz, dipole with 2.2" (55 mm) of RG178 coaxial cable terminated with an IPEX connector. Antenna WRR-series , 2400-2500 MHz, dipole with 5.1" (130 mm) of RG113 coaxial cable terminated with an IPEX connector and a ferr WCR-series , 2400-2500 MHz, dipole with 5.9" (150 mm) of RG113 coaxial cable and an IPEX connector 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 3.9in (100 mm) of RG113 coaxial cable term WRR-series , 2400-2500 MHz, dipole with Hexagonal Sleeve, 1.4" (35 mm) of RG113 coaxial cable terminated with an IPEX co WRR-series, 2400-2500 MHz, dipole antenna terminated with an SMA male connector Ni Plated. Antenna color Black WCR-series , 2400-2500 MHz, dipole antenna with ferrite bead and a Reverse SMA male connector WCR-series , 2400-2500 MHz, dipole antenna with an Reverse SMA male connector 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 8 in (203 mm) of RG113 coaxial cable termi WTC-series 802.11 abg, 2400-2500/4900-6000 MHz, Dipole antenna with 2.0-3.7 dBi nominal gain with 11" (279 mm) of 1.13 WTC-series 802.11 abg, 2400-2500/4900-6000 MHz, Dipole antenna with 2.0-3.7 dBi nominal gain with 7" (178 mm) of 1.13O WRR-series , 2400-2500 MHz, dipole with 3.3" (85 mm) of RG113 coaxial cable terminated with an IPEX connector. Antenna 802.11 b/a, 2400-2500 & 4900-6000 MHz, Mini-NanoBlade Embedded Antenna with 3 in (80 mm) of OD113 cable terminated WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 127mm of 1.13 mm coaxial cable terminated with a IPX connecto WTS-series 802.11 abg, 2400-2500/4900-5875 MHz, dipole antenna with 279mm of 1.13 mm coaxial cable terminated with a 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 5.7 in (146 mm) of OD113 terminated with an 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 1 in (25 mm) of OD113 terminated with an IP 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 3.5 in (97 mm) of RG113 terminated with an I WCP-series , 2400-2500 MHz, dipole with 5" (127 mm) of RG178 coaxial cable and an IPEX connector 802.11 b/a, 2400-2500 & 4900-6000 MHz, Embedded Nanoblade Antenna with 11.8in (300mm) of RG178 cable terminated w WRR-series 802.11 a/b/g , 2400-2500/4900-5000 MHz, dipole with Round Sleeve and 3.9" (100 mm) of RG113 coaxial cable t WTS-series 802.11 abg, 2400-2500/4900-5875 MHz, dipole antenna with 130mm of 1.13 mm coaxial cable terminated with a WRR-series , 2400-2500 MHz, dipole with Round Sleeve and 3.9" (100 mm) of RG113 coaxial cable terminated with an U.FL co WCP-series , 2400-2500 MHz, dipole with 4" (102 mm) of RG178 coaxial cable and an Straight SMA Plug WRR-series, 2400-2500 MHz, dipole with Round Sleeve and 7.9" (200 mm) of RG113 coaxial cable terminated with an U.FL co WRR-series, 2400-2500 MHz, dipole with 7.9" (200 mm) of RG113 coaxial cable terminated with an U.FL connector. Antenna WTS-series 802.11 bg, 2400-2500 MHz, dipole antenna with 230mm of 1.13 mm coaxial cable terminated with a U.FL connec 802.11 a/b/g Embedded Antenna, NanoGreen, 2-4 dBi, 16.5 x 51 mm (wxl), with 229 mm of 1.13mm coaxial cable terminate WCP-series , 2400-2500 MHz, dipole with 15.7" (400 mm) of RG178 coaxial cable and an MHF connector 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 1.3 in (33 mm) of RG178 terminated with a Ri 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 5.9 in (150 mm) of RG113 coaxial cable term WRR-series, 2400-2500 MHz, dipole antenna terminated with an SMA male connector Cr Plated. Antenna color Black. WRR-series, 2400-2500 MHz, dipole with 11" (280 mm) of RG113 coaxial cable terminated with an U.FL connector. Antenna WCP-series , 2400-2500 MHz, dipole with 15.75" (400 mm) of RG178 coaxial cable and an U.FL connector 802.11 b/a, 2400-2500 & 4900-6000 MHz, Mini-NanoBlade Embedded Antenna with double sided tape (12 x 35 x 1 mm), 14.5 802.11 b/a, 2400-2500 & 4900-6000 MHz, Mini-NanoBlade Embedded Antenna with double sided tape (12 x 35 x 1 mm), 9.8 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 1.96 in (50 mm) of OD113 coaxial cable term WTS-series 802.11 abg, 2400-2500/4900-5875 MHz, dipole antenna with sleeve and 220mm of OD113 coaxial cable terminat 802.11 b/a, 2400-2500 & 4900-6000 MHz, Mini-NanoBlade Embedded Antenna with double sided tape (12 x 35 x 1 mm), 9.8 WCP-series , 2400-2500 MHz, dipole with 12" (305 mm) of RG178 coaxial cable and an U.FL connector 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 3.9 in (100 mm) of OD113 terminated with an 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 5.1 in (130 mm) of OD113 terminated with an 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 1.6 in (40 mm) of OD113 terminated with an 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 3.9 in (100 mm) of RG178 terminated with fly 802.11 a/b/g Embedded Antenna, NanoGreen, 2-4 dBi, 16.5 x 51 mm (wxl), with 127 mm of RG-178 and flying lead 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 4.5 in (115 mm) of RG113 terminated with an 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 2 in (52 mm) of OD113 terminated with an IP 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 25.6 in (650 mm) of OD113 coaxial cable te 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 8 in (203 mm) of RG178 coaxial cable termi 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 8 in (203 mm) of RG178 coaxial cable termi 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 4.9in (124 mm) of RG113 coaxial cable term 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 6.7 in (170 mm) of RG178 terminated with a R 802.11 b/a, 2400-2500 & 4900-6000 MHz, NanoBlade Embedded Antenna with 9.8 in (250 mm) of OD113 terminated with an 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 12 in (305 mm) of RG178 coaxial cable term 802.11 b/g, 2400-2500 MHz, Embedded Nanoblue Antenna (44.5 x 12.6mm) with 4 in (102 mm) of RG178 coaxial cable termi WRR-series, 2400-2500 MHz, dipole with 10" (254 mm) of RG178 coaxial cable terminated with an Right Angle MMCX plug co HRDKT,HEAVY DUTY ART MNT Mount,Mag,195-5'-RSMAM 2.4 GHz, 14 dBi gain, Directional Yagi Antenna with 36" of cable and Reverse Type N male connector Omni,PolMnt,12,NF Panel,DirLnk,10in,SMAF Panel,DirLnk,10in,NF Panel,DirLnk,10in,NF Panel,DirLnk,10in,SMAF Panel,DirLnk,10in,NF Panel,ArtMnt,10in,NF DirectLink Series Campus & In-building, 7.5 dBi articulating wall mount, Directional Antenna with 36" of coaxial cable termina Panel,WalMnt,10in,NF Panel,WalMnt,10in,RTNM Panel,WalMnt,10in,SMAF Panel,WalMnt,10in,NF Panel,WalMnt,18in,SMAM Panel,WalMnt,36in,RTNM 2.4 GHz high gain, 8 dBi, Omnidirectional antenna with a Reverse TNC connector Dual Linear, H- & V-pol, Directional Panel Antenna operating at 2400-2500 MHz with 7 dBi nominal gain. The antenna has du 802.11 b/g, 2400-2500 MHz, Dual Slant 45 deg polarization, Directional Antenna with 7 dBi of gain , and 12" of coaxial cable Linearly polarized 8 dBi, 2400-2500 MHz, indoor/outdoor,directional panel antenna with 36" of cable terminated in Type N m Linearly polarized 8dBi , 2400-2500 MHz, indoor/outdoor,directional panel antenna with 36" of cable terminated with an Rev Dual band, 2400-2500/ 4900-5900 MHz, 6 dBi, high gain Omnidirectional Collinear antenna with a Type N female connector Dual band, 2400-2500/ 4900-5900 MHz, 6 dBi, vertically polarized Omnidirectional Collinear antenna with an SMA female con Dual band, 2400-2500/ 4900-5900 MHz, 6 dBi, vertically polarized Omnidirectional Collinear antenna with a Reverse SMA con 802.11 a/b/g, 2400-2500/4900-5990, 3 dBi Tri-mode Omidirectional Diversity Panel antenna with 36" of coaxial cable termina 802.11 a/b/g, 2400-2500/4900-5990, 3 dBi Tri-mode Omidirectional Diversity Panel antenna with 36" (91 cm) of coaxial cable DPanel,ArtMnt,96in,RTNM Special purpose Omnidirectional 5 dBi antenna operating in the 5150-5350 MHz band with an Reverse TNC connector Special purpose Omnidirectional 5 dBi antenna operating in the 5150-5350 MHz band with an Reverse SMA connector Omni,BPXMnt,36in,NM Panel,ArtMnt,10in,NF Panel,ArtMnt,10in,NF Panel,WalMnt,10in,NF Panel,WalMnt,10in,NF DirectLink Series Campus & In-building, 12 dBi wall mount, Directional Antenna operating over 5725- 5825 MHz with 42" of c Omni,PolMnt,23in,NF Omni,DirLnk,10in,NF 802.11 b/g right angle Dipole operating over 2400-2500 MHz with 2.0 dbi gain and 140 mm of RG178 coaxial cable terminate Sectr,HPOL,Fixed,NF Sectr,HPOLWB,FIXED,NF Sectr,HPOLWB,,NF Trimode 802.11 a/b/g Dual Band 2.4 - 2.5 GHz & 5.15 - 5.875 GHz Omnidirectional ceiling mount panel antenna with 3 dBi gai Trimode 802.11 a/b/g Dual Band 2.4 - 2.5 GHz & 5.15 - 5.35 GHz Omnidirectional ceiling mount panel antenna Trimode 802.11 a/b/g Dual Band 2.4 - 2.5 GHz & 5.15 - 5.35 GHz Omnidirectional ceiling mount panel antenna Sectr,VPOL,Fixed,NF Squint Omnidirectional Panel Antenna with Type N female connector. Unique solution to the low power characteristics of pic Squint Omnidirectional Panel Antenna with Type N male connector. Unique solution to the low power characteristics of picoc Squint Omnidirectional Panel Antenna with Reverse SMA connector. Unique solution to the low power characteristics of pico Squint Omnidirectional Panel Antenna with Reverse TNC connector. Unique solution to the low power characteristics of picoc Squint Omnidirectional Panel Antenna with Reverse TNC connector. Unique solution to the low power characteristics of picoc Squint Omnidirectional Panel Antenna with Type N female connector. Unique solution to the low power characteristics of pic Omni,Squint,12in,NF Mount,Squint,L-Bracket WCP-series , 2400-2500 MHz, dipole with 1" (25.4 mm) of RG178 coaxial cable and an MMCX connector WCP-series , 2400-2500 MHz, dipole with 3" (76.2 mm) of RG178 coaxial cable and an MMCX connector WCP-series , 2400-2500 MHz, dipole with 5" (127 mm) of RG178 coaxial cable and an MMCX connector WCP-series , 2400-2500 MHz, dipole with 7" (174 mm) of RG178 coaxial cable and an MMCX connector WCP-series , 2400-2500 MHz, dipole with 8" (203 mm) of RG178 coaxial cable and an MMCX connector WCR-series , 2400-2500 MHz, fixed dipole antenna with an MMCX connector DIPOL,WTL,RSMAM DIPOL,WTL,100MM,FL DIPOL,WTL,150MM,MHF Indoor/Outdoor 2.4 GHz, 15 dBi, 15 element fully Enclosed Ruggedized Yagi antenna with 18" of coaxial cable terminated in a Gaing and a Reverse TNC Male input connector nna with 36" Plenum rated RG-142 coaxial cable terminated in a Reverse Polarity TNC connector. cable terminated in an IPX connector nna with 60" Plenum rated RG-142 coaxial cable terminated in a Reverse Polarity TNC connector. minated in a Flying Lead no connector) with 5.9" (150 mm) of RG178 cable terminated in a Flying Lead ble terminated with a flying lead. Antenna color Black l cable terminated in an IPX connector. Connector orientation B. EX connector and a ferrite bead. Antenna color black with connector orientation A. minated with a Reverse Polarity SMA male connector cable terminated with a IPX connector. Antenna color Black EX connector and a ferrite bead. Antenna color Black with connector orientation A. X connector and a ferrite bead. Antenna color black with connector orientation A. m of OD113 coaxial cable terminated in an IPEX connector. and 86 mm of RG178 coaxial cable terminated in a Flying Lead, DLINK ted with a IPX connector. Antenna color Black G178 coaxial cable terminated with an IPEX connector (connector orientation A) ble terminated with a STR MMCXP connector. Antenna color Black coaxial cable terminated in an IPEX connector. 13 terminated with an IPEX connector (connector orientation B) coaxial cable terminated in an IPEX connector. ity SMA male connector Black Chrome Plated. Antenna color Black. ted with a IPX connector. Antenna color Grey ted with a flying lead. Antenna color Black nnector Nickel Plated. Antenna color Black. ted with a IPX connector. Antenna color Grey (FB) ted with a IPX connector. Antenna color Black (FB) nated with an IPEX connector and a ferrite bead. Antenna color Grey with connector orientation A. d with a flying lead. Antenna color Black minated with an IPEX connector. Antenna color Black with connector orientation A. 113 coaxial cable terminated with an IPEX connector (connector orientation A), Double sided tape (30 x 12 x 3.2 mm), a ferrite bead and ted with a IPX connector. Antenna color Black 113 coaxial cable terminated with an IPEX connector and Double Sided Tape (35 x 6 x 1 mm) EX connector and a ferrite bead. Antenna color White with connector orientation A. nated with an IPEX connector and a ferrite bead. Antenna color Black with connector orientation A. X connector. Antenna color Black with connector orientation A. EX connector and a ferrite bead. Antenna color Anthracite with connector orientation A. G113 coaxial cable terminated with an IPEX connector (connector orientation A) and double sided sticky tape minated with an IPEX connector. Antenna color black with connector orientation C. nna color Black 113 coaxial cable terminated with an IPEX connector (connector orientation A) h 11" (279 mm) of 1.13OD cable terminated in a MHF/U.FL connector h 7" (178 mm) of 1.13OD cable terminated in a MHF/U.FL connector X connector. Antenna color black with connector orientation A. OD113 cable terminated with a flying lead (i.e. no connector) ted with a IPX connector. Antenna color Black (FB) cable terminated with a IPX connector. Antenna color Black 113 terminated with an IPEX connector (connector orientation C), ferrite bead and strain relief 3 terminated with an IPEX connector (connector orientation B) and ferrite bead. 13 terminated with an IPEX connector (connector orientation B) 178 cable terminated with a flying lead (i.e. no connector) f RG113 coaxial cable terminated with an U.FL connector. Antenna color Black with connector orientation A. cable terminated with a IPX connector. Antenna color Black (FB) minated with an U.FL connector. Antenna color Black with connector orientation A. minated with an U.FL connector. Antenna color Black with connector orientation A. .FL connector. Antenna color Black with connector orientation A. ted with a U.FL connector. Antenna color Black coaxial cable terminated in an U.FL connector. 78 terminated with a Right Angle Reverse Polarity SMA connector (connector orientation A) G113 coaxial cable terminated with an U.FL connector (connector orientation A) enna color Black. FL connector. Antenna color Black with connector orientation A. e (12 x 35 x 1 mm), 14.5 in (370 mm) of OD113 cable terminated with an MHFconnector e (12 x 35 x 1 mm), 9.8 in (250 mm) of OD113 cable terminated with an MHFconnector OD113 coaxial cable terminated with an U.FL connector (connector orientation A) with DST 3 coaxial cable terminated with a IPX connector. Antenna color Black e (12 x 35 x 1 mm), 9.8 in (250 mm) of OD113 cable terminated with an MHFconnector 113 terminated with an IPEX connector (connector orientation A) and ferrite bead 113 terminated with an IPEX connector (connector orientation A) and ferrite bead 13 terminated with an IPEX connector (connector orientation B) and ferrite bead. 178 terminated with flying lead (i.e. no connector) and flying lead 113 terminated with an IPEX connector (connector orientation A) and ferrite bead 3 terminated with an IPEX connector (connector orientation A) and ferrite bead. OD113 coaxial cable terminated with an IPEX connector (connector orientation A) 178 coaxial cable terminated with an IPEX connector (connector orientation A) and Double sided tape (30 x 12 x 3.2 mm) 178 coaxial cable terminated with an Right Angle Reverse Polarity SMA connector (connector orientation D) G113 coaxial cable terminated with an IPEX connector (connector orientation A) 178 terminated with a Right Angle Reverse Polarity MMCX connector (connector orientation A) 113 terminated with an IPEX connector (connector orientation A) G178 coaxial cable terminated with an Right Angle MMCX connector (connector orientation D) 178 coaxial cable terminated with an Right Angle SMA male connector (connector orientation D) ght Angle MMCX plug connector. Antenna color Black with connector orientation A. of coaxial cable terminated with a Reverse TNC female connector. n. The antenna has dual ports, H & V, with 12" coaxial cables terminated in a Type N female connector. nd 12" of coaxial cable terminated in a Type N-Female terminated in Type N male connector terminated with an Reverse TNC connector e N female connector with an SMA female connector. Installation mountin options include pole/mast, ceiling I-beam and suspended ceiling mount with a Reverse SMA connector. Installation mountin options include pole/mast, ceiling I-beam and suspended ceiling mount of coaxial cable terminated in a Type N male connector. Horizontal mast mount configuration (91 cm) of coaxial cable terminated in a Reverse TNC male connector. Horizontal mast mount configuration TNC connector SMA connector 5825 MHz with 42" of coaxial cable terminated with a Type N male connector. coaxial cable terminated in a flying lead. l antenna with 3 dBi gain and 36" of RG58 coaxial cable terminated in a Reverse Polarity Type N female connector er characteristics of picocells, microcells and RF distribution systems characteristics of picocells, microcells and RF distribution systems r characteristics of picocells, microcells and RF distribution systems characteristics of picocells, microcells and RF distribution systems characteristics of picocells, microcells and RF distribution systems er characteristics of picocells, microcells and RF distribution systems al cable terminated in a Type N female connector mm), a ferrite bead and double sticky tape eiling mount eiling mount
S2307MP18SMM 价格&库存
很抱歉,暂时无法提供与“S2307MP18SMM”相匹配的价格&库存,您可以联系我们找货
