WPS-495922-02
WPS-495922-02
    MWT
    SMD2
    PWR AMP LIN 4.9-5.9GHZ SMD
WPS-495922-02 数据手册
WPS-495922-02 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Features: Applications: • 11.0 dB Gain • 802.16 WiMax • 32 dBm P1dB • 802.11 WLAN • 47 dBm IP3 • Wireless Communications • EVM < 2.5% at 26 dBm Pout • Telecomm Infrastructure • Pre-match for Easy Cascade • Pb Free Surface Mount Pkg • MTTF > 100 yrs @ TC 150°C Description: The WPS-495922-02 is a 1.5 watt amplifier pre-matched to 50 ohm operating over frequency range 4.9 GHz to 5.9 GHz. The RF gain is 11 dB. The typical output IP3 is 47 dBm and P1dB is 32 dBm. The WPS-495922 amplifier has excellent performance for 802.11 WLAN and 802.16 WiMax applications. At 2.5% error vector magnitude (EVM), the amplifier can achieve an average output power of 26 dBm. The WPS-495922-02 is packaged in a leadless chip carrier with a proprietary copper alloy for excellent thermal conductance. The package construction is environmentally ‘lead free’ and ‘cadmium free’. Electrical Specifications: • @ 25°C, Vds = 7.5 V, Zo = 50 ohms SYMBOL PARAMETERS Min Freq. Frequency Range 4.9 SSG Small Signal Gain 9 VSWR Input/ Output VSWR P1dB Typical Max Unit 5.9 GHz 11 dB 3.0:1/2.0:1 - Pout at 1 dB Compression Point +32 dBm EVM Error Vector Magnitude (see note 1) 2.5 % OIP3 Output Third Order Intercept (see note 2) 47 dBm Ids DC Current 600 mA Vgs Gate Voltage -0.7 Volt Rth Thermal Resistance Junction to Case 18 °C/W Notes: 1. 2. The output power is 25 dBm for 2.5% EVM and the test signal is 802.16, 256 carriers, 64 QAM with 2/3 coding factor. The measured EVM includes the accumulated errors (1.6%) from the modulator and driver stages. The output power per tone is 22 dBm and the tone separation is 20 MHz center at 5.5 GHz. Absolute Maximum Ratings MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © June 2016 WPS-495922-02 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Package Outline Diagram (Package 02) P1dB vs Frequency 33 34 32 30 28 26 24 22 20 P1dB (dBm) Output Power (dBm) Pout vs Pin @ 5.5 GHz 32 31 30 10 12 14 16 18 20 22 24 4.9 5.1 Input Pow er (dBm ) Gain (dB) Return Loss (dB) 5.50 5.7 5.9 Return Loss vs Frequency -5 -7 -9 -11 -13 -15 4.5 5.00 5.5 Frequency (GHz) Gain vs Frequency 13.00 12.00 11.00 10.00 9.00 8.00 7.00 4.50 5.3 6.00 Frequency (GHz) 6.50 5 5.5 6 Frequency (GHz) Input MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Output 6.5 WPS-495922-02 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet S-parameters measured at Vdd=7.5V and Vg=-0.7V 25°C Freq (GHz) 4.50 4.60 4.70 4.80 4.90 5.00 5.10 5.20 5.30 5.40 5.50 5.60 5.70 5.80 5.90 6.00 6.10 6.20 6.30 6.40 6.50 S11 MAG 0.56 0.56 0.56 0.55 0.54 0.54 0.53 0.53 0.53 0.53 0.53 0.52 0.50 0.47 0.43 0.36 0.29 0.25 0.29 0.40 0.52 ANG -84.22 -99.93 -115.24 -130.63 -146.05 -161.60 -177.34 166.08 149.64 133.22 117.33 101.70 85.80 69.30 51.20 28.61 -2.41 -47.53 -95.77 -130.47 -154.23 S21 MAG 4.02 4.02 3.95 4.05 4.06 4.01 4.02 3.96 3.94 3.90 3.91 3.83 3.78 3.72 3.70 3.66 3.57 3.39 3.12 2.80 2.47 ANG -175.51 172.22 162.93 153.52 144.25 134.37 124.21 111.82 99.89 88.24 76.71 65.80 54.29 42.41 29.21 15.20 -0.23 -16.27 -32.21 -48.06 -63.21 S12 MAG 0.05 0.05 0.05 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.07 0.07 0.07 0.07 0.07 0.07 0.07 0.06 0.06 ANG 125.37 116.31 108.11 100.09 89.06 76.23 66.27 56.41 47.94 37.93 27.25 15.30 3.57 -9.28 -21.23 -34.21 -49.22 -64.77 -81.04 -97.23 -112.68 S22 MAG 0.50 0.48 0.46 0.44 0.42 0.40 0.37 0.35 0.32 0.29 0.27 0.25 0.23 0.22 0.22 0.23 0.26 0.30 0.34 0.38 0.41 MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © ANG 58.97 52.86 46.11 39.62 32.74 25.76 18.00 9.75 0.52 -9.67 -20.85 -33.30 -47.72 -64.15 -82.37 -101.50 -120.18 -137.91 -153.30 -166.87 -178.29 WPS-495922-02 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Application Note The evaluation board material, shown in Figure 1, is Rogers 4003 material, 20 mil thick, and 2 oz copper weight. Through holes with a diameter of 20 mils are spread uniformly over the center pad for thermal relief and RF ground. It is recommended that via holes be placed nearby the DC bias connector to maintain ground continuity between the top layer and bottom ground planes. Mounting holes near the unit will help secure the board to the chassis, minimize ground current loops and improve thermal conductivity in the absence of sweat soldering the board to the chassis. Figure 1 Evaluation board Biasing with quarter-wave stubs at the gate and drain are shown in Figure 1. The impedance of the quarter wave structures is cyclical with frequency. A RF short is observed at frequencies that are even multiples of quarterwavelength and open impedance is observed at frequencies that are odd multiples of a quarter-wavelength. A 56 ohm resistor is added in series to the gate bias. The effective impedance is increased which reduces the risk of oscillations. The 56 ohm resistor is not shown in Figure 1. Through holes underneath the package is required to connect the top and bottom grounds and to improve thermal conductivity. Typical large signal gain response, shown in Figure 2, varies from 10 to 11 dB over the frequency range 4.9 to 5.9 GHz. The output IP3 response shown in Figure 3 uses a two tone separation of 20 MHz at 5.1 and 5.9 GHz. OIP3 vs Output Power OIP3 (dBm) Large Signal Gain (dB) Large Signal Gain Pin=18 dBm 13.0 12.0 11.0 10.0 9.0 8.0 7.0 49 48 47 46 45 44 43 42 14 15 16 17 18 19 20 21 22 23 24 4.5 5 5.5 6 Frequency (GHz) Figure 2 Gain Response 6.5 Output Power per Tone (dBm) 5.1 GHz Figure 3 OIP3 MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © 5.9 GHz WPS-495922-02 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Application Note (Con’t) One of most stringent modulations for a linear amplifier is WiMAX 256 carriers, 64 QAM. The WiMAX test signals were generated using the Rhode & Schwarz SMU200A modulator and the FSQ26 is used to analyze signal integrity. An output power of 26 dBm is achieved for an error vector magnitude of 2.5% as shown in Figures 4 thru 6. Frequenc y: 5 .1 GH z Signal Level: 3 dBm E xternal A tt: 0 dB Sweep M ode: C ontinuous T rigger M ode: Free Run T rigger O ffs et: -1 0 µs Burs t T ype: O FDM DL Burs t M odulation: 6 4 Q A M 2 /3 N o O f Data Symbols : 1 /1 3 6 6 Res ult S ummary N o. of Burs ts 66 M ean Limit M ax Limit U nit E V M A ll C arriers M in 2 .2 8 2 .4 9 3 .7 6 2 .7 7 3 .7 6 % E V M Data C arriers 2 .2 8 2 .4 9 3 .7 6 2 .7 6 3 .7 6 % E V M P ilot C arriers 1 .8 6 2 .3 6 2 .8 2 % I Q O ffs et 2 .8 5 3 .2 4 3 .5 7 % Gain I mbalanc e 1 .0 6 0 .8 2 0 .5 0 % - 0 .0 2 4 0 .1 7 7 0 .3 9 2 ° Q uadrature E rror C enter Frequenc y E rror 4 0 .6 8 1 3 2 .2 6 Symbol C loc k E rror 1 .2 6 7 .6 9 Burs t P ower 3 .1 0 3 .2 7 3 .4 3 dBm C res t Fac tor 6 .3 7 6 .6 1 6 .8 3 dB SS T iming 0 .0 0 0 .0 0 0 .0 0 % ... ... ... RSSI ± 40800 ±8 * 1 8 5 .8 6 ± 40800 1 8 .5 8 ±8 Hz ppm dBm Figure 4 802.16, 256 carriers, 64QAM at 5.1 GHz, Pavg=26.3 dBm MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © WPS-495922-02 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Application Note (Con’t) Frequency: 5.9 GHz Signal Level: 16.5 dBm External A tt: 0 dB Sweep Mode: C ontinuous Trigger Mode: P ower Trigger O ffset: -10 µs Burst Type: O FDM DL Burst Modulation: 64Q A M3/4 No O f Data Symbols: 4/2425 Res ult S ummary No. of Bursts 2 * Min Mean Limit Max Limit Unit EV M A ll C arriers 2 .0 6 2 .0 7 2.82 2 .0 8 2.82 % EV M Data C arriers 2 .0 7 2 .0 8 2.82 2 .0 9 2.82 % EV M P ilot C arriers 1 .9 0 1 .9 1 1 .9 2 % IQ O ffset 0 .0 7 0 .1 0 0 .1 3 % Gain Imbalance 0 .1 8 0 .0 8 - 0 .02 % Q uadrature Error 0 .2 18 0 .2 3 8 0 .2 57 ° C enter Frequency Error 1 0 .71 1 0.9 6 ± 47200 1 1 .21 ± 47200 Symbol C lock Error - 0 .0 0 0 .0 0 ±8 0 .0 0 ±8 Burst P ower 1 5 .32 1 5.3 4 1 5 .36 8 .5 3 8 .5 4 8 .5 4 1 7 .72 1 7.7 2 1 7 .72 C rest Factor RSSI RSSI Standard Deviation C INR - 3.8 7 4 1 .70 C INR Standard Deviation 4 1.7 0 Hz ppm dBm dB dBm dB 4 1 .74 3 1.7 1 Figure 5 802.16 256 carriers, 64 QAM at 5.9 GHz, Pavg=25.2 dBm @ EVM=2% MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © dB dB WPS-495922-02 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Application Note (Con’t) Typical constellation response for 802.16 Pavg=26 dBm and 2.5% EVM Frequency: 5.1 GHz Signal Level: 1.9 dBm External A tt: 0 dB Sweep Mode: Continuous Trigger Mode: Free Run Trigger O ffset: -10 µs Burst Type: O FDM DL Burst Modulation: 64Q A M2/3 No O f Data Symbols: 1/1366 C apture Memory 1Ref 11.9 dBm No of Samples Capture Time A tt/El 480001 15 ms Gate 25.00 / 0.00 dB Burst Marker 1 O ff 67 (0) 8.34 dBm 0s 8 0 -8 -16 -24 -32 -40 -48 -56 A 0.0000 ms 1.5000 ms/div The test signal is 256 carriers, 64 QAM with 2/3 coding factor. 15.0000 ms C onstellation vs Symbol Marker 1 Q uadrature - 7.0274 Inphase 2.9146 7.00 Figure 6 WiMax constellation Pavg=26 dBm at 5.1 GHz for 2.5% EVM for all carriers. B The signal power versus time is shown in yellow. The constellation shown in represents 64 QAM. 1 -7.00 -7.00 C apture Memory 1Ref 11.5 dBm No of Samples C apture Time A tt/El 7.00 480001 15 ms Gate 25.00 / 0.00 dB Burst Marker 1 O ff 66 (0) 7.52 dBm 0s 8 0 -8 -16 -24 -32 -40 -48 -56 * A 0.0000 ms 1.5000 ms/div Figure 7 WiMax constellation Pavg= 25.8 dBm at 5.9 GHz. for 2.5% EVM. 15.0000 ms C onstellation vs Symbol Marker 1 7.00 Q uadrature - 7.0087 Inphase 3.0575 * B 1 -7.00 -7.00 7.00 MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved ©
WPS-495922-02 价格&库存
很抱歉,暂时无法提供与“WPS-495922-02”相匹配的价格&库存,您可以联系我们找货
