MMA-495933-Q5
MMA-495933-Q5
    MWT
    WFQFN24_EP
    RF Amplifier IC General Purpose 4.9GHz ~ 5.9GHz 24-QFN (5x5)
MMA-495933-Q5 数据手册
MMA-495933-Q5 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Features: • Frequency Range: 4.9 to 5.9 GHz • 46 dBm IP3 • 33 dBm P1dB • 26 dBm Pout @ 2.0% EVM • 10.5 dB Gain • Input and Output Matched to 50 Ω for Easy Cascade • Surface Mount QFN 5x5mm Package Applications: • 802.16 WiMax • 802.11 WLAN • Point-To-Point Radio Communications • Telecomm Infrastructure Description: The MMA-495933-Q5 is a 2.0 watt amplifier pre-matched to 50 ohm operating over frequency range 4.9 GHz to 5.9 GHz. The RF gain is 10.5 dB. The typical output IP3 is 46 dBm and P1dB is 33 dBm. The MMA-495933-Q5 amplifier has excellent performance for 802.11 WLAN and 802.16 WiMax applications. At 2.0% error vector magnitude (EVM), the amplifier can achieve an average output power of 26 dBm. The MMA-495933-Q5 is packaged in a quad flat no-lead (QFN) with a copper base paddle which offers excellent thermal conductance, reduced lead inductance, small size, near chip-scale footprint and thin profile. Electrical Specifications: Vds=7.5V, Ta=25 ºC, Z0=50 ohm Parameter Units Min Frequency Range GHz 4.9 Small Signal Gain dB 10.0 Input/Output VSWR N/A Pout at 1dB Compression Point dBm Pout @ 2% EVM (1) dBm 26 Output Third Order Intercept (2) dBm 46 DC Current mA 600 V -1.0 °C/W 16 Gate Voltage(VGS) Thermal Resistance Junction to Case Typical Max 5.9 10.5 2.0:1/3.7:1 +32.5 +33.0 (1) The output power is 26 dBm for 2.0% EVM and the test signal is 802.16, 256 carriers, 64 QAM with 2/3 coding factor. The measured EVM includes the accumulated errors (0.8%) from the modulator and driver stages. (2) The output power per tone is 22 dBm and the tone separation is 20 MHz center at 5.5 GHz. MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © ECCN: 3A001.b.2.a.4 Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 1 of 8, Updated October 2017 MMA-495933-Q5 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Typical RF Performance: Vds=7.5V, Vgs=-1.0V, Ids=600mA, Z0=50 ohm, Ta=25 ºC P1dB vs Frequency EVM vs Pout 35 4 P1dB (dBm) EVM (%) 5 3 2 1 34 33 0 -5 -2 1 4 7 10 13 16 19 22 25 28 32 4.9 Pout (dBm) 5.1 5.3 5.5 5.7 5.9 5.7 5.9 Frequency (GHz) F4.9 F5.1 F5.5 F5.9 Return Loss vs Frequency 13 12 11 10 9 8 7 6 5 Return Loss (dB) Gain (dB) Gain vs Frequency 0 -5 -10 -15 -20 4.9 4.9 5.1 5.3 5.5 Frequency (GHz) 5.7 5.9 5.1 5.3 5.5 Frequency (GHz) Input MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 2 of 8, Updated October 2017 Output MMA-495933-Q5 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Absolute Maximum Ratings: (Ta= 25 °C)* PARAMETERS Bias Voltage (VDS) Continuous RF Input Power Peak Input Power Operating Temperature Storage Temperature UNITS V dBm dBm ºC ºC ABSOLUTE MAXIMUM 8.5 +30 +33 -40 to +85 -65 to +150 *Operation of this device above any one of these parameters may cause permanent damage. Typical Scattering Parameters: Freq (GHz) 4.50 4.60 4.70 4.80 4.90 5.00 5.10 5.20 5.30 5.40 5.50 5.60 5.70 5.80 5.90 6.00 6.10 6.20 6.30 6.40 6.50 S11 MAG 0.58 0.55 0.50 0.47 0.39 0.34 0.29 0.27 0.25 0.25 0.26 0.25 0.25 0.23 0.22 0.21 0.21 0.21 0.20 0.18 0.13 ANG 12.98 -3.95 -21.89 -41.41 -63.21 -87.96 -116.06 -146.83 -178.36 151.23 122.38 94.62 66.79 37.69 6.29 -27.52 -62.14 -95.69 -128.03 -161.31 158.70 Vds=7.5V, Vgs=-0.9V Ids=600mA ,Z0=50 ohm, Ta=25 ºC S21 MAG 2.91 2.95 3.02 3.09 3.19 3.29 3.38 3.46 3.50 3.52 3.51 3.51 3.51 3.51 3.51 3.49 3.44 3.37 3.27 3.15 3.00 ANG 0.321 -16.40 -32.99 -49.68 -66.76 -84.69 -103.06 -121.82 -140.56 -159.17 -177.74 163.49 144.51 124.99 104.90 84.28 63.09 41.27 18.99 -3.87 -27.27 S12 MAG 0.039 0.042 0.044 0.047 0.05 0.052 0.054 0.056 0.059 0.061 0.063 0.064 0.066 0.068 0.070 0.072 0.073 0.073 0.073 0.072 0.069 ANG -65.1 -82.14 --99.79 -117.69 -135.82 -153.91 -172.01 169.92 151.74 133.45 115.10 96.64 77.99 58.98 19.74 19.74 -0.53 -21.21 -42.40 -64.18 -86.44 S22 MAG 0.42 0.46 0.51 0.54 0.56 0.57 0.58 0.57 0.57 0.56 0.54 0.52 -.49 0.46 0.39 0.39 0.36 0.32 0.27 0.22 0.17 MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 3 of 8, Updated October 2017 ANG -123.15 -129.49 -135.38 -140.75 -145.62 -150.16 -154.50 -158.81 -163.22 -167.68 -176.57 -176.57 179.20 175.16 167.02 167.02 162.48 157.70 153.51 151.77 156.32 MMA-495933-Q5 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Mechanical Information: All dimensions are in mm Pin Assignment Pin # Function Pin # Function 1 2 3 4 5 6 7 8 9 10 11 12 N/C N/C RF in RF in N/C N/C N/C N/C N/C Vdd N/C N/C 13 14 15 16 17 18 19 20 21 22 23 24 N/C N/C RF out RF out N/C N/C N/C N/C N/C Vgs N/C N/C MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 4 of 8, Updated October 2017 MMA-495933-Q5 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Application Note The measurements presented are recorded at Vdd=7.5 volts and Ids= 600 mA. The evaluation board layout is shown in Figure 1. Rogers 4003 is the choice for many RF board materials because of its high frequency response, temperature stability and low cost. The board height is 20 mils and the copper trace weight is 1 oz. Many through holes with a drill diameter of 12 mils are spread uniformly across the center pad for thermal relief and RF ground. It is recommended that via holes be placed nearby the DC bias connector to maintain ground continuity between the top and bottom ground planes. Mounting holes near the unit will help secure the board to the chassis, minimize ground current loops and improve thermal conductivity in the absence of sweat soldering the board to the chassis. The via hole design, shown in Figure 2, uses two via patterns that are interleaved; one is 5x5 and the other is 4x4; the finished via hole diameter is 9 mils. The pitch between holes is 25 mils. The simulated thermal impedance is less than 0.9°C/W. The PCB finish is nickel over copper with a gold flash. Please consult our factory to request s-parameters, Gerber file and samples. The MMA-495933-Q5 amplifier includes two built-in bias tees for gate control at QFN pin 10 and for drain control at QFN pin 22. In addition, the MMA-495933-Q5 has its own DC blocking capacitors. The breakdown voltage for the blocking capacitor is 22 VDC. The schematic for the evaluation board is shown in Figure 3. The evaluation board has two bias terminals; terminal P1 is for gate control and terminal P2 is for drain control. The gate control should be adjusted first before setting the drain. The typical gate voltage is -1.0 volts and the drain voltage is 7.5 volts. The bias current is approximately 600 mA with no RF applied. These bias conditions can vary with the application requirements; that is, setting lower current for low power or setting higher current for pristine performance. Figure 3 Evaluation Board Schematic MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 5 of 8, Updated October 2017 MMA-495933-Q5 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Application Note (continued) The typical small signal gain response, shown in Figure 4, varies from 10 to 11 dB over the frequency range 4.9 to 5.9 GHz. The output IP3 response shown in Figure 5 uses a two tone separation of 20 MHz at 4.9 and 5.9 GHz. Notice that linearity of this amplifier is maintained at very low power levels which give rise to better signal to noise interference ratio. A block diagram of the WiMAX test setup is shown in Figure 6. The burst frame length is 141 symbols and the channel bandwidth is 3.5 MHz. A summary of the burst is shown in Figure 7. The measured EVM error is segmented into two sections. The SMU200A contributes about 0.5%, and the driver contributes about 0.3% to the total EVM. The EVM measurement includes the 0.8% error from the driver and source. The residual EVM error for the MMA-495933Q5 is 1.2% at burst power of 27 dBm. MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 6 of 8, Updated October 2017 MMA-495933-Q5 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Application Note (continued) The noise figure, shown in Figure 8, is less than 8.0 dB across the frequency range 4.9 to 5.9 GHz. The MMA-495933-Q5 includes a stability resistor that adds to the noise figure. The typical noise floor for an on-chip WiMAX modulator is -107 dBm per MHz. Assume that the total system gain is approximately 35 dB and the predriver stage used has a gain of 25 and noise figure of 5.5 dB. The noise floor to PA is -79 dBm per MHz. The noise floor at the output of the MMA-495933-Q5 is -68.5 dBm per MHz. This shows that sensitivity for this system is -29 dBm per 3.5 MHz for SNR = 34 dB. The MMA-495933-Q5 does not noise limit the system performance. IE E E 8 0 2 .1 6 - 2 0 0 4 O FDM Frequency: 5.5 GHz Signal Level Setting: 7.4 dBm External A tt: 18.8 dB Sweep Mode: C ontinuous Trigger Mode: External Trigger O ffset: -10 µs Burst Type: O FDM DL Burst Modulation: A LL No O f Data Symbols: 1/2425 Res ult S ummary No. of Bursts 4 Mean Limit Max Limit Unit EV M A ll C arriers Min 1 .9 4 1 .9 8 2.82 2 .0 5 2.82 % EV M Data C arriers 1 .9 5 1 .9 8 EV M P ilot C arriers 1 .8 3 1 .9 0 IQ O ffset 0 .1 3 0 .1 3 Gain Imbalance 0 .0 8 0 .0 8 Q uadrature Error - 0 .0 0 2 - 0 .0 0 2 C enter Frequency Error 2 4 4 .2 7 2 4 4 .2 7 ± 44000 2 4 4 .2 7 ± 44000 0 .0 3 0 .0 3 ±8 0 .0 3 ±8 2 7 .1 2 2 7 .1 5 2 7 .1 6 8 .3 2 8 .5 3 8 .7 7 1 1 .2 6 1 1 .2 6 1 1 .2 6 C lock Error Burst P ower C rest Factor RSSI RSSI Standard Deviation C INR % 2 .0 5 17.78 0 .1 3 % 17.78 0 .0 8 3 9 .7 0 % % - 0 .0 0 2 ° - 1 1 .1 6 3 9 .7 0 C INR Standard Deviation 2 .0 5 Hz ppm dBm dB dBm dB 3 9 .7 0 2 .8 3 dB dB Figure 9 802.16 256 carriers, 64 QAM at 5.5 GHz, Pavg=27.1 dBm @ EVM=2% MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 7 of 8, Updated October 2017 MMA-495933-Q5 4.9 – 5.9 GHz Linear Power Amplifier Data Sheet Application Note (continued) IE E E 80 2 .16 - 2 00 4 O FDM Frequency: 5.5 GHz Signal Level Setting: 7.4 dBm External A tt: 18.8 dB Sweep Mode: C ontinuous Trigger Mode: External Trigger O ffset: -10 µs Burst Type: O FDM DL Burst Modulation: A LL No O f Data Symbols: 1/2425 C apture Memory 1Ref 17.4 dBm No of Samples C apture Time A tt/El 80001 20 ms Gate 25.00 / 0.00 dB Burst O ff 4 (4) Figure 10 0.00000 s 32.60 dBm 0s Marker 1 * 32 24 16 8 0 -8 -16 -24 -32 A TRG LVL 0.0000 ms 2.0000 ms/div The test pattern is 256 carriers and modulations are QPSK, 16QAM and 64 QAM. 20.0000 ms C onstellation vs Symbol Marker 1 Q uadrature - 0.0255 Inphase 6.5232 * 7.00 WiMax constellation Pavg=27 dBm at 5.5 GHz for 2.0% EVM for all carriers. The signal power versus time is shown in yellow. B The constellation shown represents QPSK, 16QAM and 64 QAM. 1 -7.00 -7.00 7.00 IE E E 802 .1 6- 2 004 O FDM Frequency: Signal Level Setting: 10.3 dBm External A tt: 18.8 dB Sweep Mode: C ontinuous 5.5 GHz Trigger Mode: External Trigger O ffset: -10 µs Burst T ype: O FDM DL Burst Modulation: A LL No O f Data Symbols: 1/2425 A djacent C hannel P ower Relative C hannel Bandwidth Spacing TX 3.5 MHz ... Lower Upper 26.89 dBm A djacent 3.5 MHz 3.5 MHz -38.86 dB -39.35 dB A lternate 3.5 MHz 7 MHz -59.04 dB -58.92 dB 2nd A lternate 3.5 MHz 10.5 MHz -63.21 dB -63.40 dB 3rd A lternate ... ... ... ... 4th A lternate ... ... ... SpectrumA C P Ref 11.8 dBm A tt/EL 25.00 / 0.00 dB RBW V BW SWT 100 kHz 1 MHz 2s Figure 11 ... Marker 1 -52.2 dBm 2.3 GHz 1 of 1 Sweep * 21 11 C0 C0 cl1 cu1 B 1 1 RM CLRWR cl1 -9 cu1 ACPR at Pavg=27 dBm at 5.5 GHz. The channel bandwidth is 3.5 MHz. The first adjacent channel ratio is -39 dBc; the second channel ratio is -59 dBc. TRG -19 -29 LVL cl2 cl2 cu2 cu2 -39 1cl3 -49 cl3 cu3 cu3 -59 5487.651 MHz 2.470 MHz/div 5512.349 MHz MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 8 of 8, Updated October 2017
MMA-495933-Q5 价格&库存
很抱歉,暂时无法提供与“MMA-495933-Q5”相匹配的价格&库存,您可以联系我们找货
