MMA-495930-Q4
MMA-495930-Q4
    MWT
    VFQFN24_EP
    RF AMP MED PWR 24QFN
MMA-495930-Q4 数据手册
MMA-495930-Q4 4.9-5.9GHz Fully Matched Medium Power Amplifier Data Sheet Features: • • • • • • Ideal for 4900 –5900 MHz High Linearity / High Dynamic Range WiMax/WLAN and Point-To-Point Radio Applications Excellent RF Performance: o 45 dBm OIP3 o 30 dBm P1dB o 22 dBm Pout @ 2.0% EVM (Testing signal: 802.16/64 QAM) o 20 dB Gain Vdd =+7.5V Input and Output are Matched to 50 Ω MTTF > 100 years @ 85ºC ambient temperature Surface-Mount QFN 4X4mm Package Description: The MMA-495930-Q4 is a high linearity GaAs FET broadband MMIC amplifier utilizing MwT’s proprietary linear device technology. It is packaged in a low cost QFN 4X4mm surface mount package. Applications include the driver and the output stage of power amplifiers for WLAN and WiMax infrastructure base stations and access points. The third order intercept performance of the MMA-495930-Q4 is excellent and is typically 15 dB above the 1 dB gain compression point. Typical RF Performance: Vds=7.5V, Vgs=-0.9V, Ids=450mA, Ta=25 °C Z0=50 ohm Units Typical Data Frequency Range MHz 4900-5900 Gain (Typ / Min) dB 20 / 18 +/-dB 1.0 / 1.2 Input Return Loss dB 8 Output Return Loss dB 8 Output P1dB dBm 30 Output IP3 (1) dBm 45 Pout @ 2.0% EVM Operating Current Range (Typ / Max) Thermal Resistance dBm 22 mA 450 / 500 °C /W 20 Parameter Gain Flatness (Typ / Max) (1) Output IP3 is measured with two tones at output power of 13 dBm/tone separated by 10 MHz. MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 1 of 4, Updated July 2017 MMA-495930-Q4 4.9-5.9GHz Fully Matched Medium Power Amplifier Data Sheet Typical RF Performance: Vds=7.5V, Vgs=-0.9V, Ids=450mA, Z0=50 ohm, Ta=25 ºC MMA-495930 Gain vs Frequency MMA-495930 Return Loss vs Frequency 0 25 -5 Gain(dB) Gain(dB) 20 15 10 -10 -15 5 0 -20 2 3 4 5 Freq(GHz) 6 7 8 2 Gain 4 5 Freq(GHz) 6 7 8 Input RL Output RL MMA-495930 EVM vs Channel Power (64QAM Modulation) MMA-495930 Output Power vs Frequency 8 33 7 32 6 31 EVM(% ) Pow er(dBm ) 3 30 5 4 3 2 29 1 28 0 4.8 4.9 5 5.1 5.2 5.3 5.4 5.5 5.6 5.7 5.8 5.9 Freq(GHz) Output P-1 6 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 4.9GHz EVM 5.4GHz EVM Freq(GHz) 5.9GHz EVM MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 2 of 4, Updated July 2017 MMA-495930-Q4 4.9-5.9GHz Fully Matched Medium Power Amplifier Data Sheet Absolute Maximum Ratings: SYMBOL Vds Vgs Ids Igs Pdiss Pin max (Ta= 25 °C)* PARAMETERS Drain-Source Voltage Gate-Source Voltage Drain Current Gate Current DC Power Dissipation RF Input Power UNITS V V mA mA W dBm ABSOLUTE MAXIMUM 8.5 -6 to +0.8 500 5.0 4.0 +24.0 Toper Operating Temperature ºC -40 to +85 Tch Channel Temperature ºC 150.0 Tstg Storage Temperature ºC -60.0 to 150.0 *Operation of this device above any one of these parameters may cause permanent damage. Typical Scattering Parameters: Freq [GHz] S11 Vds=7.5V, Vgs=-0.9V, Ids=450mA, Z0=50 ohm, Ta=25 ºC S21 Mag - Ang S21 Mag - Ang 4.0 0.772 101 1.11 4.2 0.742 64.6 4.4 0.71 27.2 4.6 0.677 4.8 5.0 S21 Mag - Ang Mag - Ang 38.5 0.00598 165 0.67 -98.4 2.22 13.6 0.0075 138 0.734 -146 3.9 -27.7 0.0083 106 0.76 167 -11 6.05 -75.5 0.00796 77.8 0.688 123 0.528 -49.5 8.25 -127 0.00642 49.8 0.504 85.8 0.468 -86.9 9.67 -179 0.00641 32.8 0.351 60.8 5.2 0.425 -121 10.4 133 0.00586 11.4 0.277 49.3 5.4 0.407 -151 10.9 86.8 0.00576 -9.05 0.289 35.8 5.6 0.312 -172 11.3 42.7 0.00524 -39.6 0.324 13.3 5.8 0.241 180 11.7 -0.471 0.00447 -72 0.359 -15.2 6.0 0.253 180 11.8 -44.3 0.00304 -108 0.386 -47.1 6.2 0.33 167 11.9 -87.9 0.00204 -164 0.406 -80.7 6.4 0.417 143 11.7 -132 0.00191 109 0.413 -115 6.6 0.474 111 11.3 -178 0.00336 42 0.413 -149 6.8 0.476 75.9 10.6 136 0.00497 -0.827 0.392 -179 7.0 0.407 37.4 9.4 88.8 0.00659 -39.1 0.367 156 7.2 0.278 -8.24 8.06 41.3 0.00763 -74.7 0.342 138 7.4 0.137 -87.7 6.52 -5.59 0.00823 -109 0.35 128 7.6 0.213 164 4.96 -51.9 0.00741 -141 0.398 116 7.8 0.382 111 3.55 -95.5 0.00696 -170 0.468 102 8.0 0.522 72.4 2.44 -136 0.00561 167 0.54 84.2 MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 3 of 4, Updated July 2017 MMA-495930-Q4 4.9-5.9GHz Fully Matched Medium Power Amplifier Data Sheet Mechanical Information: All dimensions are in mm Pin Assignment Pin # Function Pin # Function 1 2 3 4 5 6 7 8 9 10 11 12 N/C N/C RF in RF in N/C N/C N/C N/C N/C Vdd N/C N/C 13 14 15 16 17 18 19 20 21 22 23 24 N/C N/C RF out RF out N/C N/C N/C N/C N/C Vgs N/C N/C MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 4 of 4, Updated July 2017
MMA-495930-Q4 价格&库存
很抱歉,暂时无法提供与“MMA-495930-Q4”相匹配的价格&库存,您可以联系我们找货
