MMA-062020-C3
MMA-062020-C3
    MWT
    WFQFN12_EP
    MMIC GAAS AMP 6-22GHZ 12QFN
MMA-062020-C3 数据手册
MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Features:        Frequency Range: 6 – 22 GHz P1dB: 18.5 dBm @Vdd=5V P3dB: 19.5 dBm @Vdd=5V Gain: 14 dB Vdd =3 to 6 V Ids = 130 mA Input and Output Fully Matched to 50 Ω Applications:    Communication systems Microwave instrumentations ECM Functional Block Diagram Description: The MMA-062020 is a broadband GaAs MMIC general purpose gain block for 19.5dBm saturated maximum output power and high gain over full 6 to 22GHz frequency range. This amplifier was optimally designed for broadband applications requiring flat gain with excellent input and output port matches. Absolute Maximum Ratings: SYMBOL PARAMETERS (Ta= 25 C)* UNITS Vd1, Vd2 Drain-Supply Voltage Min. Max. V 6.5 Id1 Drain Supply Current mA 70 Id2 Drain Supply Current mA 84 Pin max RF Input Power dBm 20 Toper Operating Temperature ºC -40 to +85 Tch Channel Temperature ºC +150 Tstg Storage Temperature ºC -55 to +165 Tmax Max. Assembly Temp (60 sec max) ºC +300 *Operation of this device above any one of these parameters may cause permanent damage. MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 1 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Electrical Specifications: Vds=5V, Ids=130mA, Ta=25 C Z0=50 ohm Parameter Units Typical Data Frequency Range Gain (Typ / Min) Gain Flatness (Typ / Max) Input RL(Typ/Max) Output RL(Typ/Max) Output P1dB(Typ/Min) Output IP3 (1) Output Psat(Typ/Min) Operating Current at P1dB (Typ/Max) Thermal Resistance GHz dB +/-dB dB dB dBm dBm dBm 6 - 22 14 / 13.5 0.8 / 1 8/6 10/7 18.5/18 28 19.5/18.5 mA 130 / 132 C /W 65 (1) Output IP3 is measured with two tones at output power of 0 dBm/tone separated by 20 MHz. MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 2 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Typical RF Performance: Vds=5V, Ids=130mA, Z0=50 ohm, Ta=25 ºC 20 15 S11, S21, S22 (dB) 10 DB(|S(1,1)|) MEAS_PKG 5 DB(|S(2,1)|) MEAS_PKG 0 DB(|S(2,2)|) MEAS_PKG -5 -10 -15 -20 2 4 6 8 10 12 14 16 18 20 Frequency (GHz) 22 24 26 28 30 S11[dB], S21[dB], and S22[dB] vs. Frequency IM3 level [dBc] vs. Output power/tone [dBm] P-1 and Psat vs. Frequency Pout[dBm], Gain[dB], and Ids[mA] vs. Input power [dBm] MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 3 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Typical Bias dependent RF Performance: 20 18 16 S21 (dB) 14 12 10 8 DB(|S(2,1)|) sp_TRL_3V130mA 6 DB(|S(2,1)|) sp_TRL_4V130mA 4 DB(|S(2,1)|) sp_TRL_5V130mA 2 DB(|S(2,1)|) sp_TRL_6V130mA 0 2 4 6 8 10 12 14 16 18 20 Frequency (GHz) 22 24 26 28 30 24 26 28 30 24 26 28 30 S21(dB) over voltage Bias dependent P1 vs. Frequency 0 -2 -4 S11 (dB) -6 -8 -10 -12 DB(|S(1,1)|) sp_TRL_3V130mA -14 DB(|S(1,1)|) sp_TRL_4V130mA -16 DB(|S(1,1)|) sp_TRL_5V130mA -18 DB(|S(1,1)|) sp_TRL_6V130mA -20 2 4 6 8 10 12 14 16 18 20 Frequency (GHz) 22 S11(dB) over Voltage 0 DB(|S(2,2)|) sp_TRL_3V130mA -2 DB(|S(2,2)|) sp_TRL_4V130mA -4 S22 (dB) Bias dependent P-3 vs. Frequency -6 DB(|S(2,2)|) sp_TRL_5V130mA -8 DB(|S(2,2)|) sp_TRL_6V130mA -10 -12 -14 -16 -18 -20 2 4 6 8 10 12 14 16 18 20 Frequency (GHz) 22 S22(dB) over Voltage MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 4 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Typical Over Temperature RF Performance: Vds=5V, Ids=130mA, Z0=50 ohm, Ta=25 ºC P1 over temperature S21(dB) over temperature P-3 over temperature S11(dB) over temperature S22(dB) over Voltage MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 5 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Applications The MMA-062020-C3 is a GaAS PHEMT amplifier designed for Class-A condition, flat gain performance from 6GHz to 22GHz. It is applicable for cascadable gain stage for EW amplifiers, buffer stages, LO drivers, and transmitter amplifiers used in commercial communication systems. This amplifier is provided as a 3x3mm QFN package, and the packaged amplifier is fully compatible with industry standard high volume surface mount PCB assembly processes. Biasing and Operation The MMA-062020-C3 is normally biased with a single positive supply voltage connected to both Vd1 and Vd2 pins. The recommended drain supply voltages are 3 to 6 volts. RF input and output ports are DC decoupled internally. Typical DC supply connection with bi-passing capacitors for the MMA-062020-C3 is shown in following pages. Assembly Techniques GaAs MMICs are ESD sensitive. ESD preventive measures must be employed in all aspects of storage, handling, and assembly. MMIC ESD precautions, handling considerations, die attach and bonding methods are critical factors in successful GaAs MMIC performance and reliability. MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 6 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Package Pin-out: 3 +/- 0.13 Pin #1 Dot 0.3 12 10 1 Pin #1 9 0.5 3 +/- 0.13 3 7 4 6 2.1 1.5 SQUARE 0.8 Pin 2 8 12 10 1, 3, 7, 9, 13 (center pad) 4, 5, 6, 11 Description RF Input RF Output Vd1 Vd2 Ground N/C MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 7 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Application Circuit: Vdd1 Vdd2 3 GND PAD 13 4 GND 2 9 8 7 RF Output GND RF OUT GND 6 RF IN 1 10 12 GND 5 RF Input 11 0.1uF 0.1uF MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 8 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Recommended Application Board Design: Board Material is 10mil (Dielectric) thickness Rogers 4350B with 0.5oz cupper clads. Board is soldered on a gold plated solid cupper block and adequate heat-sinking is required for 0.7W total maximum power dissipation. Vd1 C1 Vd2 C2 RF_OUT RF_IN Part C1, C2 Description 0.1uF capacitor (0603) MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 9 of 10, Updated June 2019 MMA-062020-C3 6-22GHz, 0.1W Gain Block Data Sheet Recommended Application Board Design: Board Material is 10mil (Dielectric) thickness Rogers 4350B with 0.5oz cupper clads. The board material and mounting pattern, as defined in the data sheet, optimizes RF performance and is strongly recommended. An electronic drawing of the land pattern is available upon request from MwT Sales & Application Engineering. GCWG layout Close-up 0.1 0.35 1.0 0.6 0.2 0.25 1.1 0.2 0.6 Plated Through Hole D=0.3 All units are in millimeters. Underneath of the package must be Cupper filled plated through holes. D=0.3mm and Space=0.5mm Total Via-holes = 3 x 3 MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data sheet is subject to change without notice. All rights reserved © Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 10 of 10, Updated June 2019
MMA-062020-C3 价格&库存
很抱歉,暂时无法提供与“MMA-062020-C3”相匹配的价格&库存,您可以联系我们找货
