ACC-004
ACC-004
    LAIRD(莱尔德)
    SMD
    BOARD CARRIER BISMS02BI FOR KIT
ACC-004 数据手册
AC4490 OEM Transceiver Family 3.3V, 1 Watt Transmit OEM Transceiver Family Part Number Description - 5 mW to 1000 mW Transcievers AC4490 Series - Server/Client Protocol AC4490-1000M 900 MHz FHSS module w/ MMCX ant. connector AC4490LR-1000M 900 MHz FHSS module w/ MMCX ant. connector, Longer Range version AC4490-1000M-485* 900 MHz FHSS module w/ MMCX ant. connector, RS485 SDK-AC4490-1000M AC4490-1000M Developer Kit SDK-AC4490LR-1000M AC4490LR-1000M Developer Kit AC4790 Series - Peer-to-Peer Protocol AC4790-1000M 900 MHz FHss module w/MMCX ant. Connector AC4790LR-1000M 900 MHz FHSS module w/ MMCX ant. connector, Longer Range version AC4790-1000M-485* 900 MHz FHSS module w/ MMCX ant. connector, RS485 SDK-AC4790-1000M AC4790-1000M Developer Kit SDK-AC4790LR-1000M AC4790LR-1000M Developer Kit 3.3V - 5.5V, 200 mW Transmit OEM Transceiver Family Part Number Description - 5 mW to 200 mW Transceivers AC4490 Series - Server/Client Protocol AC4490-200M 900 MHz FHSS module w/ MMCX ant. connector AC4490LR-200M 900 MHz FHSS module w/ MMCX ant. Connector, Longer Range version 900 MHz FHSS module w/ MMCX ant. connector, RS485 AC4490-200M-485 AC4490-200A 900 MHz FHSS module w/ integral ant. AC4490-200A-485 900 MHz FHSS module w/ integral ant., RS485 SDK-AC4490-200M AC4490-200M Developer Kit SDK-AC4490LR-200M AC4490LR-200M Developer Kit SDK-AC4490-200A AC4490-200A Developer Kit AC4790 Series - Peer-to-Peer Protocol AC4790-200M 900 MHz FHSS module w/ MMCX ant. connector AC4790LR-200M 900 MHz FHSS module w/ MMCX ant. Connector, Longer Range version AC4790-200M-485 900 MHz FHSS module w/ MMCX ant. connector, RS485 AC4790-200A 900 MHz FHSS module w/ integral ant. AC4790-200A-485 900 MHz FHSS module w/ integral ant., RS485 SDK-AC4790-200M AC4790-200M Developer Kit SDK-AC4790LR-200M AC4790LR-200M Developer Kit SDK-AC4790-200A AC4790-200A Developer Kit Accessories Part Number Description 0700-00012 Samtec 20-pin mating connector for AC44xx 0650-00005 Power Supply, 7.5 VDC, 1.5 A, Sw. Reg., 100 - 240 VAC input 900 MHz Antennas & Cables Part Number Description 0600-00019 S467FL-5-RMM-915S, 1/2 wave, 7", 2dBi, RA, MMCX plug 0600-00025 S467FL-5-RMM-915, 1/2 wave, 7", 2dBi, MMCX plug 0600-00024 S467AH-915S, 1/2 wave, 7", 2dBi, RA, RPSMA 0600-00027 S467AH-915, 1/2 wave, 7", 2dBi, RPSMA 0600-00028 S161AH-915R, 1/2 wave, 6", 2.5dBi, RA, RPSMA 0600-00029 S161AH-915, 1/2 wave, 6", 2.5dBi, RPSMA 0600-00030 S331AH-915, 1/4 wave, 3.5", 1dBi, RPSMA 1300-00023 5" RG178 coax, RA MMCX plug to RPSMA bulkhead 868 - 870 MHz OEM Transceiver family 868 - 870 OEM Transceiver Family, 3.3 - 5.5 V Part Number Description AC4486-5M* 868 - 870 MHz, 0 - 5 mW, MMCX AC4486-5M-485* 868 - 870 MHz, 0 - 5 mW, MMCX, 2-wire RS485 AC4486-5A* 868 - 870 MHz, 0 - 5 mW, integral antenna AC4486-5A-485* 868 - 870 MHz, 0 - 5 mW, integral antenna, 2-wire RS485 868 - 870 MHz, 0 - 250 mW, MMCX AC4868-250M* AC4868-250M-485* 868 - 870 MHz, 0 - 250 mW, MMCX, 2-wire RS485 AC4486-5M Developer Kit SDK-AC4486-5M* AC4486-5A Developer Kit SDK-AC4486-5A* SDK-AC4868-250M* AC4868-250M Developer Kit Accessories for AC4486 and AC4868 Description Part Number 0700-00012 Samtec 20-pin mating connector for AC44xx 0650-00005 Power Supply, 7.5 VDC, 1.5 A, Sw. Reg., 100 - 240 VAC input 868 - 870 MHz Antennas & Cables Part Number Description 0600-00020 S467FL-6-RMM-868S, 1/2 wave, 7", 2dBi, RA, MMCX plug 1300-00023 5" RG178 coax, RA MMCX plug to RPSMA bulkhead 2.4 GHz OEM Transceiver Family AC4424 (-40 ° to 80 ° C) Industrial Temperature Part Number Description 2.4GHz OEM Transceiver, 5V TTL Serial, 10mW AC4424-10 AC4424-10A 2.4GHz OEM Transceiver, 5V TTL Serial, 10mW, integral ant. AC4424-100 2.4GHz OEM Transceiver, 5V TTL Serial, 100mW LT4424-200 2.4GHz OEM Transceiver, 5V TTL Serial, 200mW SDK-AC4424-10 AC4424-10 Developer Kit SDK-AC4424-10A AC4424-10A Developer Kit AC4424-100 Developer Kit SDK-AC4424-100 SDK-LT4424-200 LT4424-200 Developer Kit LT2510, Industrial Temperature (-40 o to 80 o C) Part Number Description PRM110 2.4GHz OEM Transceiver, SMT, 3.3V TTL, 100mW, u.FL Jack PRM111 2.4GHz OEM Transceiver, SMT, 3.3V TTL, 100mW, Chip Ant PRM112 2.4GHz OEM Transceiver, SMT, 3.3V TTL, 100mW, u.FL Jack, CE Approved PRM113 2.4GHz OEM Transceiver, SMT, 3.3V TTL, 100mW, Chip Ant, CE Approved PRM120 2.4GHz OEM Transceiver, Pluggable, 3.3V TTL, 100mW, u.FL Jack PRM121 2.4GHz OEM Transceiver, Pluggable, 3.3V TTL, 100mW, Chip Ant PRM122 2.4GHz OEM Transceiver, Pluggable, 3.3V TTL, 100mW, u.FL Jack, CE Approved PRM123 2.4GHz OEM Transceiver, Pluggable, 3.3V TTL, 100mW, Chip Ant, CE Approved PRM130 2.4GHz OEM Transceiver, Pluggable, 3.3V TTL, 100mW, u.FL Jack, AC4424 Size PRM132 2.4GHz OEM Transceiver, Pluggable, 3.3V TTL, 100mW, Chip Ant, CE Approved AC4424 Size DVK-PRM110 LT2510 Developer Kit, SMT, 3.3V TTL, 100mW, u.FL Jack EVB-PRM110-U LT2510 USB Eval Board, SMT, 3.3V TTL, 100mW, u.FL Jack EVB-PRM110-R LT2510 RS232 Eval Board, SMT, 3.3V TTL, 100mW, u.FL Jack DVK-PRM111 LT2510 Developer Kit, SMT, 3.3V TTL Serial, 100mW, Chip Ant EVB-PRM111-U LT2510 USB Eval Board, SMT, 3.3V TTL Serial, 100mW, Chip Ant EVB-PRM111-R LT2510 RS232 Eval Board, SMT, 3.3V TTL Serial, 100mW, Chip Ant DVK-PRM112 LT2510 Developer Kit, SMT, 3.3V TTL, 100mW, u.FL Jack, CE Approved LT2510 USB Eval Board, SMT, 3.3V TTL, 100mW, u.FL Jack, CE Approved EVB-PRM112-U LT2510 RS232 Eval Board, SMT, 3.3V TTL, 100mW, u.FL Jack, CE Approved EVB-PRM112-R DVK-PRM113 LT2510 Developer Kit, SMT, 3.3V TTL Serial, 100mW, Chip Ant, CE Approved EVB-PRM113-U LT2510 USB Eval Board, SMT, 3.3V TTL Serial, 100mW, Chip Ant, CE Approved EVB-PRM113-R LT2510 RS232 Eval Board, SMT, 3.3V TTL Serial, 100mW, Chip Ant, CE Approved DVK-PRM120 LT2510 Developer Kit, Pluggable, 3.3V TTL Serial, 100mW, u.FL Jack DVK-PRM121 LT2510 Developer Kit, Pluggable, 3.3V TTL Serial, 100mW, Chip Ant DVK-PRM122 LT2510 Developer Kit, Pluggable, 3.3V TTL Serial, 100mW, u.FL Jack, CE Approved DVK-PRM123 LT2510 Developer Kit, Pluggable, 3.3V TTL Serial, 100mW, Chip Ant, CE Approved 2.4 GHz Accessories Description Part Number Samtec 20-pin mating connector for AC44xx 0700-00012 0650-00005 Power Supply, 7.5 VDC, 1.5 A, Sw. Reg., 100 - 240 VAC input 2.4 GHz Antennas & Cables Part Number Description 0600-00002 S181FL-5-RMM-2450S, 1/2 wave, 5", 2dBi, RA, MMCX plug 0600-00008 S181FL-5-RMM-2450, 1/2 wave, 5", 2dBi, MMCX plug 0600-00014 S181AH-2450S, 1/2 wave, 5", 2dBi, RA, RPSMA 0600-00016 S181AH-2450, 1/2 wave, 5", 2dBi, RPSMA S151FL-5-RMM-2450S, 7", 5dBi, RA, MMCX plug 0600-00012 S151FL-5-RMM-2450, 7", 5dBi, MMCX plug 0600-00011 S151AH-2450S, 7", 5dBi, RA, RPSMA 0600-00010 0600-00022 S151AH-2450, 7", 5dBi, RPSMA NZH2400 microstrip antenna 2150-00006 1300-00023 5" RG178 coax, RA MMCX plug to RPSMA bulkhead 1300-00041 5" RG178 coax, u.FL plug to RPSMA bulkhead Packaged Wireless Products 2.4 GHz ConnexLink RS-232 Packaged Product Part Number Description CL4424-100-232 2.4 GHz RS232 Transceiver (Client Config) 100 mWatt w/antenna CL4424-100-232-SP 2.4 GHz RS232 Transceiver Starter Pack* 100 mWatt w/antennas CL4424-100-485 2.4 GHz RS485 Transceiver (Client Config) 100 mWatt w/antenna CL4424-100-485-SP 2.4 GHz RS485 Transceiver Starter Pack* 100 mWatt w/antennas 2200-00076 CL4424-100-232 Board Only RS-232 with DB9 (no enclosure) *A Starter Pack includes one Server and one Client, standard RS-232 cables (No cables with RS485 version), Nearson S151 Antennas, power supplies 900 MHz ConnexLink RS-232, 485 packaged product Part Number Description 900 MHz RS232 Transceiver (Client config) 1.0 Watt w/antenna - DB9 interface connector CL4490-1000-232 CL4490-1000-232-SP 900 MHz RS232 Transceiver Starter Pack* 1.0 Watt (Server/Client protocol) CL4490-1000-485 900 MHz RS485 Transceiver (Client config) 1.0 Watt w/antenna - Terminal Block interface connector CL4490-1000-485-SP 900 MHz RS485 Transceiver Starter Pack* 1.0 Watt (Server/Client protocol) - Terminal Block interface connector CL4490-1000-PRO 900 MHz RS232/RS485/RS422 Switching Interface Transceiver (Client config) 1.0 Watt w/antenna - DB9 interface connector CL4490-1000-PRO-SP 900 MHz RS232/RS485/RS422 Switching Interface Transceiver Starter Pack* 1.0 Watt (Server/Client protocol) 2200-00122 CL4490-100-232 Board Only RS-232 with DB9 (no enclosure) CL4790-1000-232 900 MHz RS232 Transceiver (Peer-to-peer protocol) 1.0 Watt w/antenna - DB9 interface connector CL4790-1000-232-SP 900 MHz RS232 Transceiver Starter Pack (Peer-to-peer protocol)** 1.0 Watt CL4790-1000-485 900 MHz RS485 Transceiver (Peer-to-peer protocol) 1.0 Watt w/antenna - Terminal Block interface connector CL4790-1000-485-SP 900 MHz RS485 Transceiver Starter Pack (Peer-to-peer protocol)** 1.0 Watt - Terminal Block interface connector *Starter Pack includes one Server and one Client, standard RS-232 cables (no cables with RS485 version), Nearson S467 Antennas, power supplies 900 MHz ConnexLink USB packaged product Part Number Description CL4490-200-05 900 MHz USB Transceiver (Client config) 200mW w/antenna - Power over USB CL4790-200-05 900 MHz USB Transceiver (Peer-to-peer protocol) 200mW w/antenna - Power over USB ConnexLink Accessories Part Number Description 1300-00032 Null-Modem Cable (replaces standard cable if connecting Aerocomm units to DCE devices) 0650-00005 Power Supply, 7.5 VDC, 1.5 A, Sw. Reg., 100 - 240 VAC input ConnexModem - Industrial Wireless 56K Modem Part Number Description CM4490-1000-232-SP 900MHz (Server/Client architecture) Industrial 1W 56K Modem-to-RS232 Starter Pack* ConnexNet - Industrial Ethernet Transceivers Description Part Number CN4490-1000-232-SP 900 MHz (Server/Client architecture) Industrial 1W Ethernet-to-RS232 Starter Pack* CN4490-1000-PRO-SP 900 MHz (Server/Client architecture) Industrial 1W Ethernet-to-ConnexLink Pro Starter Pack* 900 MHz (Server/Client architecture) Industrial 1W Ethernet Transceiver with antenna and power supply CN4490-1000 CN4490-1000-SP 900 MHz (Server/Client architecture) Industrial 1W Ethernet Bridge with antenna and power supply CN4790-1000-232-SP 900 MHz (Peer-to-peer architecture) Industrial 1W Ethernet-to-RS232 Starter Pack* CN4790-1000 900 MHz (Peer-to-peer architecture) Industrial 1W Ethernet Transceiver with antenna and power supply *Starter Pack includes one Server and one Client, standard RS-232 cables (no cables with RS485 version), Nearson S467 Antennas, power supplies ZB2430 OEM ZigBee Transceiver Family Part Number Legend Z = Zigbee (802.15.4) nnn = Output Power in mW S = Surface Mount, M = Pluggable 1 = TI RF Chip Set A = Chip Antenna, U = u.FL Antenna Jack X = No Over-Air Firmware Upgrade, F = Over-Air Firmware Upgrade C = Coordinator, R = Router, E = End Device Long Range ZB2430 OEM ZigBee Transceivers (2.4 GHz, 3V, 2-100 mW) Part Number Description High Power ZigBee Commissioner Zigbee Commissioner, SMT, 100mW, OTA, Chip Antenna Z100S1AFM Z100S1UFM Zigbee Commissioner, SMT, 100mW, OTA, u.FL Jack High Power ZigBee Coordinator Z100S1AFC Zigbee Coordinator, SMT, 100mW, OTA, Chip Antenna Z100S1UFC Zigbee Coordinator, SMT, 100mW, OTA, u.FL Jack High Power ZigBee Router Zigbee Router, SMT, 100mW, OTA, Chip Antenna Z100S1AFR Zigbee Router, SMT, 100mW, OTA, u.FL Jack Z100S1UFR High Power ZigBee End Device Z100S1AFE Zigbee End Device, SMT, 100mW, OTA, Chip Antenna Z100S1UFE Zigbee End Device, SMT, 100mW, OTA, u.FL Jack High Power ZigBee Developer Kits - Surface Mount Package Long Range SMT Zigbee Developer kit, OTA, 1 Coordinator (USB, u.FL), 3 Rtrs (RS-232, chip ant), 1 End Device (RS-232) SDK-Z100S1AF SDK-Z100S1UF Long Range SMT Zigbee Developer kit, OTA, 1 Coordinator (USB, u.FL), 3 Routers (RS-232, u.FL), 1 End Device (RS-232) SDK-Z100S1AF-M Long Range SMT Zigbee Developer kit, OTA, 1 Commissioner (USB, chip ant), 1 Coordinator (USB, u.FL), 3 Rtrs (RS-232, chip ant), 1 End Device (RS-232) SDK-Z100S1UF-M Long Range SMT Zigbee Developer kit, OTA, 1 Commissioner (USB, u.FL), 1 Coordinator (USB, u.FL), 3 Routers (RS-232, u.FL), 1 End Device (RS-232) EVB-Z100S1AFM Zigbee Eval Board Commissioner-USB, 100mW, OTA, SMT, Chip Ant EVB-Z100S1UFM Zigbee Eval Board Commissioner-USB, 100mW, OTA, SMT, u.FL Jack EVB-Z100S1AFC Zigbee Eval Board Coordinator-USB, 100mW, OTA, SMT, Chip Ant Zigbee Eval Board Coordinator-RS232, 100mW, OTA, SMT, Chip Ant EVB-Z100S1AFC-2 Zigbee Eval Board Coordinator-USB, 100mW, OTA, SMT, u.FL Jack EVB-Z100S1UFC EVB-Z100S1UFC-2 Zigbee Eval Board Coordinator-RS232, 100mW, OTA, SMT, u.FL Jack Zigbee Eval Board Router-RS232, 100mW, OTA, SMT, Chip Ant EVB-Z100S1AFR Zigbee Eval Board Router-RS232, 100mW, OTA, SMT, u.FL Jack EVB-Z100S1UFR EVB-Z100S1AFE Zigbee Eval Board End Device-RS232, 100mW, OTA, SMT, Chip Ant EVB-Z100S1UFE Zigbee Eval Board End Device-RS232, 100mW, OTA, SMT, u.FL Jack CE Approved ZB2430 OEM ZigBee Transceivers (2.4 GHz, 3V, 2-40 mW) Part Number Description CE Approved ZigBee Commissioner Z040S1AFM Zigbee Commissioner, SMT, 40mW, OTA, Chip Antenna, CE Approved Z040S1UFM Zigbee Commissioner, SMT, 40mW, OTA, u.FL Jack, CE Approved CE Approved ZigBee Coordinator Z040S1AFC Zigbee Coordinator, SMT, 40mW, OTA, Chip Antenna, CE Approved Z040S1UFC Zigbee Coordinator, SMT, 40mW, OTA, u.FL Jack, CE Approved CE Approved ZigBee Router Z040S1AFR Zigbee Router, SMT, 40mW, OTA, Chip Antenna, CE Approved Z040S1UFR Zigbee Router, SMT, 40mW, OTA, u.FL Jack, CE Approved CE Approved ZigBee End Device Z040S1AFE Zigbee End Device, SMT, 100mW, OTA, Chip Antenna, CE Approved Z040S1UFE Zigbee End Device, SMT, 100mW, OTA, u.FL Jack, CE Approved CE Approved ZigBee Developer Kits - Surface Mount Package SDK-Z040S1AF CE Approved SMT Zigbee Developer kit, OTA, 1 Coordinator (USB, u.FL), 3 Rtrs (RS-232, chip ant), 1 End Device (RS-232) SDK-Z040S1UF CE Approved SMT Zigbee Developer kit, OTA, 1 Coordinator (USB, u.FL), 3 Routers (RS-232, u.FL), 1 End Device (RS-232) SDK-Z040S1AF-M CE Approved SMT Zigbee Developer kit, OTA, 1 Commissioner (USB, chip ant), 1 Coordinator (USB, u.FL), 3 Rtrs (RS-232, chip ant), 1 End Device (RS-232) SDK-Z040S1UF-M CE Approved SMT Zigbee Developer kit, OTA, 1 Commissioner (USB, u.FL), 1 Coordinator (USB, u.FL), 3 Routers (RS-232, u.FL), 1 End Device (RS-232) EVB-Z040S1AFM Zigbee Eval Board Commissioner-USB, 40mW, OTA, SMT, Chip Ant, CE Approved EVB-Z040S1UFM Zigbee Eval Board Commissioner-USB, 40mW, OTA, SMT, u.FL Jack, CE Approved EVB-Z040S1AFC Zigbee Eval Board Coordinator-USB, 40mW, OTA, SMT, Chip Ant, CE Approved EVB-Z040S1AFC-2 Zigbee Eval Board Coordinator-RS232, 40mW, OTA, SMT, Chip Ant, CE Approved EVB-Z040S1UFC Zigbee Eval Board Coordinator-USB, 40mW, OTA, SMT, u.FL Jack, CE Approved EVB-Z040S1UFC-2 Zigbee Eval Board Coordinator-RS232, 40mW, OTA, SMT, u.FL Jack, CE Approved EVB-Z040S1AFR Zigbee Eval Board Router-RS232, 40mW, OTA, SMT, Chip Ant, CE Approved EVB-Z040S1UFR Zigbee Eval Board Router-RS232, 40mW, OTA, SMT, u.FL Jack, CE Approved EVB-Z040S1AFE Zigbee Eval Board End Device-RS232, 40mW, OTA, SMT, Chip Ant, CE Approved EVB-Z040S1UFE Zigbee Eval Board End Device-RS232, 40mW, OTA, SMT, u.FL Jack, CE Approved 2.4 GHz Accessories Part Number Description 0650-00005 Power Supply, 7.5 VDC, 1.5 A, Sw. Reg., 100 - 240 VAC input 2.4 GHz Antennas & Cables Part Number Description 0600-00040 S181FL-6-PX-2450S, 1/2 wave, 5", 2dBi, RA, u.FL plug 0600-00014 S181AH-2450S, 1/2 wave, 5", 2dBi, RA, RPSMA 0600-00039 S151FL-5-PX-2450S, 7", 5dBi, RA, u.FL plug 0600-00010 S151AH-2450S, 7", 5dBi, RA, RPSMA 1300-00041 5" RG178 coax, u.FL plug to RPSMA bulkhead BISM - 2.4GHz Bluetooth Family 2.4GHz Bluetooth Modules Part Number Description Class 1 Bluetooth Modules TRBLU23-00200 BISM II - Bluetooth Serial Module 3.6V TRBLU23-00300 BISM II - No Antenna, u.FL Jack BISMS02BI BISM II Surface Mount Module BISMS02BI-NA BISM II Surface Mount Module, No Antenna BTM402 BISM II PA - BISM II With Power Amplifier 3.6V BTM403 BISM II - Bluetooth Serial Module 3.3V BTM404 BISM II PA - BISM II With Power Amplifier 3.3V BTM520 Bluetooth Multimedia Module Plus, No Antenna BTM521 Bluetooth Multimedia Module Plus, Internal Antenna BISDK02BI-02 Bluetooth Serial Module Development Kit BISDK02BI-03 Bluetooth & 802.11 Serial Module Development Kit DVK-BTM520 Bluetooth Multimedia Module Plus, No Antenna Development Kit DVK-BTM521 Bluetooth Multimedia Module Plus, Internal Antenna Development Kit Class 2 Bluetooth Modules BTM410 Bluetooth AT Data Module, No Antenna BTM411 Bluetooth AT Data Module, Internal Antenna BTM420 Bluetooth HCI Data Module, No Antenna BTM421 Bluetooth HCI Data Module, Internal Antenna BTM510 Bluetooth Multimedia Module, No Antenna BTM511 Bluetooth Multimedia Module, Internal Antenna DVK-BTM410 Bluetooth AT Data Module, No Antenna Development Kit DVK-BTM411 Bluetooth AT Data Module, Internal Antenna Development Kit DVK-BTM420 Bluetooth HCI Data Module, No Antenna Development kit DVK-BTM421 Bluetooth HCI Data Module, Internal Antenna Development Kit DVK-BTM510 Bluetooth Multimedia Module, No Antenna Development Kit DVK-BTM511 Bluetooth Multimedia Module, Internal Antenna Development Kit Packaged Bluetooth Transceiver Family 2.4GHz Bluetooth Dongles Description Part Number BRBLU03-010A0 Bluetooth USB Adapter Version 2 (USB II) BHCRS02BI Bluetooth RS232 Adapter 2.4 GHz Bluetooth Accessories Part Number Description ACC-004 Surface Mount Adapter ACC-005 Winbond CODEC ACC-007 Multichannel CODEC CWAA-00005-01 3.6mm white posts- 1K WISM - 2.4GHz WiFi Family 2.4GHz 802.11 b&g Modules Part Number Description WISMC01BI 802.11 Wireless LAN Module, UW, TCP/IP BISM Size WISMC04BI 802.11 Wireless LAN Module, UW, TCP/IP Extended Connector WISMC03BI 802.11 Wireless LAN Module, SLIP, 802.3 BISM Size WISDK01BI-02 802.11 Wireless LAN Development Kit 2.4 GHz Bluetooth Accessories Part Number Description ACC-004 Surface Mount Adapter ACC-005 Winbond CODEC ACC-007 Multichannel CODEC CWAA-00005-01 3.6mm white posts- 1K
ACC-004 价格&库存
很抱歉,暂时无法提供与“ACC-004”相匹配的价格&库存,您可以联系我们找货
