CAB.X04
CAB.X04
    TAOGLASLIMITED
    CBL ASSY SMA F TO M CFD200 305MM
CAB.X04 数据手册
SPECIFICATION Part No. : CAB.X04 Product Name : Taoglas Magnet Mount Antenna Base Cable Assembly SMA(F) on base to SMA(M) Straight Plug on cable with 305mm(1ft) CFD-200 low loss cable Photo : SPE-14-8-096/B/WY Page 1 of 7 1. Cable Insertion Loss 2. CFD-200 Cable Specification 2.1 Drawing – Cross Section SPE-14-8-096/B/WY Page 2 of 7 2.2 Structure and Dimensions 2.3 Electrical & Physical Specification ELECTRICAL Attenuation 150MHz 450MHz 900MHz 1500MHz 1800MHz 2500MHz dB/100M 12.1 21.6 31.2 41.1 45.3 54.4 Insulation Resistance 1000 MΩ-Km (Min) Capacitance 80.4  3 pF/m Nom. Impedance 53  3 Ω MECHANICAL Cable Type CFD-200 coaxial cable Cable length 1ft (305mm) SMA(M) SMA(F) Magnet Mount Base Connector Connector Max. Torque Magnetic Pull Force 2.92kgf Weight 280g Magnet Ferric Oxide 0.9N∙m ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-14-8-096/B/WY Page 3 of 7 3. Technical Drawing 3.1 CAB.X04 Note: Minimum Bend Radius:12.7mm SMA Connector Recommended Torque for Mounting is 0.9N∙m Maxium Torque for Mounting is 1.176 N∙m SPE-14-8-096/B/WY Page 4 of 7 3.2 Connectors SPE-14-8-096/B/WY Page 5 of 7 4. Magnetic Pull Force (kilogram-force, kgf) 4.1 Testing setup Maximum Pull Force : 2.92kgf SPE-14-8-096/B/WY Page 6 of 7 5. Packaging Unit: mm SPE-14-8-096/B/WY Page 7 of 7
CAB.X04 价格&库存
很抱歉,暂时无法提供与“CAB.X04”相匹配的价格&库存,您可以联系我们找货
