VL-EPM-14H
VL-EPM-14H
    VERSALOGIC
    SBC GEODE LX800 500 MHZ 256 MB
VL-EPM-14H 数据手册
Product Data Sheet Cougar AMD Geode LX 800 Single Board Computer Overview Highlights The Cougar is a feature-rich, mid-performance single board computer that offers very low power consumption without sacrificing performance. The highly efficient AMD Geode LX 800 processor provides fanless extended temperature operation, while solderedon memory ensures high reliability. Equipped with dual 10/100 Ethernet, USB 2.0 ports, and RS-232/422/485 COM ports, the Cougar is ideal for defense, aerospace, homeland security, medical, and other embedded computing applications. ƒƒ AMD Geode LX 800 Processor ƒƒ Very low power consumption ƒƒ 256 MB soldered-on DDR memory ƒƒ Integrated video ƒƒ CompactFlash socket ƒƒ Extended temp. operation ƒƒ RoHS-compliant Like all VersaLogic products, the Cougar is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 15+ year production life guarantee, the Cougar provides a durable embedded computer solution with an excellent cost of ownership. The Cougar is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. C O R P O R A T I O N Product Data Sheet Features 1 2 3 AMD Geode LX 800 Processor Embedded BIOS PC/104-Plus Form Factor 800 MHz performance with ultra-low power consumption. OEM embedded features and firmware support. Field-upgradeable, customization available. Supports PCI and ISA expansion on a highly rugged format. High-performance Video Industrial Temperature MIL-STD-202G Analog and LVDS flat panel outputs for 18 and 24-bit displays. -40° to +85°C operation for harsh environments. Qualified for high shock and vibration operation. 256 MB DDR Memory Soldered-on RAM for high reliability. 4 Network Support Dual 10/100 Ethernet provides fast network access and boot ROM support. 5 USB Ports Four USB 2.0 ports provide flexible I/O options for keyboard, mouse, floppy drives, and other devices. 6 Integrated I/O Three COM ports (two RS-232, one RS-422/485) and one IDE interface. 7 CompactFlash Socket Removable non-volatile media has no moving parts and is bootable. 8 Fanless Operation No moving parts required for CPU cooling. Back side Modify Cougar to Your Exact Requirements Modified COTS options are available in quantities as low as 100 pieces. ƒƒ Standard Temperature Version ƒƒ Custom Testing ƒƒ Revision Locks ƒƒ Custom Labeling ƒƒ Custom Screening ƒƒ Conformal Coating ƒƒ BGA Underfill ƒƒ Connector & I/O Changes ƒƒ BIOS Modifications ƒƒ Application-Specific Testing ƒƒ Software and Drivers ƒƒ Etc. VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | info@versalogic.com | VersaLogic.com Cougar AMD Geode LX 800 Single Board Computer Specifications General Board Size Weight Processor Chipset Power Requirements§ Input Voltage System Reset and Hardware Monitors Stackable Bus Manufacturing Standards Regulatory Compliance Mass Storage PC/104-Plus compliant: 108 x 96 mm (4.25 x 3.78”) 99 grams (3.5 oz.) AMD Geode LX 800 AMD Geode CS5536 4.5W 5V ± 5% Watchdog timeout. Voltage rail monitoring. PC/104-Plus: supports 3.3V PCI signaling (2.2 compliant) IPC-A-610 Class 2 modified RoHS (2011/65/EU), Conflict Minerals compliant. Environmental Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Vibration, Random Mechanical Shock -40° to +85°C -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Memory System RAM 256 MB soldered-on DDR memory. Video Interface Desktop Display Interface* OEM Flat Panel Interface‡ Hard Drive Flash ATA-5, UDMA66 interface. 44-pin 2 mm connector. One CompactFlash socket (Type II) with DMA. Optional latching retention clip available. Network Interface Ethernet ‡ Network Boot Option Dual Autodetect 10BaseT/100BaseTX ports. Horizontal RJ45 connectors. Intel boot agent (downloadable) supports PXE protocol. Argon Managed Boot Agent (optional with royalty fee) supports PXE, RPL, NetWare, TCP/IP (DHCP, BOOTP) remote boot protocols. Device I/O USB ‡* COM 1 / 2* COM 3 Interface* Four USB 2.0/1.1 ports RS-232. 16C550 compatible. 115 Kbps. RS-422/485 selectable. 16C550 compatible. 460 Kbps. Software BIOS Operating Systems Phoenix Technologies Embedded BIOS with OEM enhancements. Field reprogrammable. Support for USB keyboard/mouse and USB boot. User-configurable CMOS defaults. Compatible with most x86 operating systems, including Windows, Windows Embedded, Linux, VxWorks, and QNX. § All power specifications represent operation at +25°C with +5V supply running Windows XP with Ethernet, keyboard, and mouse. *TVS protected port (enhanced ESD protection). ‡ Power pins on this port are protected with a self-resetting fuse Specifications are subject to change without notice. PC/104 and PC/104-Plus are trademarks of the PC/104 Consortium. CompactFlash is a trademark of SanDisk Corp. All other trademarks are the property of their respective owners. Integrated high-performance video. Up to 1600 x 1200 with 32-bit color. MMX™ + 3DNow!™ Standard analog output. 2 mm IDC connector. 18/24-bit LVDS interface. CMOS-selectable TFT panel types. C O R P O R A T I O N Cougar Product Data Sheet AMD Geode LX 800 Single Board Computer Ordering Information Model VL-EPM-14h Processor AMD Geode LX 800 Accessories Part Number Cable Kit VL-CKR-COUG VL-CBR-1008 VL-CBR-1201 VL-CBR-2003 VL-CBR-4405 VL-CBR-4406 VL-CBR-5011 VL-HDW-101 Cables VL-CBR-2010 VL-CBR-2011 VL-CBR-5009A VL-CBR-2034 Solid State Drives VL-CFM-4GB VL-CFM-2GB VL-CFM-1GB VL-CFM-1GBET VL-CFM-512 VL-CFM-512ET Audio VL-ADR-01S Development VL-PS200-ATX Description EPM-14 Cougar Eval. Cable Kit. Includes VL-CBR-5011, 1008, 1201, 4405, 4406, and HDW-101. Power cable, ATX to 10-pin VGA interface cable, 12-pin 2 mm (latching) / 15-pin VGA LPT cable, 20-pin 2 mm / DB-25F, 12” IDE adapter board, 2 mm to 0.1” IDE cable, 44-pin latching, 18” I/O cable set and paddleboard Standoff package, 4x screws, 4x standoffs, 15mm, Metric thread Call VersaLogic Sales at (503) 747-2261 for more information! Speed 500 MHz Operating Temp. -40° to +85°C Cooling Fanless Expansion Modules Part Number Accessories VCM-DAS-2 VCM-DAS-3a Description Form Factor Analog Input, x16 (16-bit resolution) 200kHz + Digital I/O x16 Analog Output x16 (12-bit resolution) + Digital I/O x24, industrial temperature PC/104 PC/104 Video VL-EPM-V7E Video expansion module: VGA and LVDS, industrial temperature In-Stack Power Supply VL-EPM-PS1a Power supply in-stack, industrial temperature PC/104-Plus PC/104-Plus LVDS / flat panel interface cable,18-bit (Hirose), 20" LVDS / flat panel cable, 18-bit (JAE), 20" I/O ribbon cable, 50-pin to 50-pin, 18" 6” 20-pin (F) ATX to 24-pin (M) ATX adapter cable (use with PS-ATX12-300A) SSD 4 GB CompactFlash SSD 2 GB CompactFlash SSD 1 GB CompactFlash SSD 1 GB CompactFlash, industrial temperature SSD 512 MB CompactFlash Type1 SSD 512 MB CompactFlash Type1, industrial temperature USB to Audio Adapter -25° to +85°C 200W ATX-style development power supply (20+4+4-pin ATX connector) VL-PS-ATX12-300A ATX development power supply (requires VL-CBR-2034) Hardware VL-ENCL-5C Development enclosure VL-HDW-203 PC/104 extractor tool (metal) VL-CF-CLIP1 CompactFlash retention clips x10 VL-HDW-106 Standoff package, 0.6", English thread VL-HDW-112 PC104 (ISA) Spacer VL-HDW-113 PC104 (PCI) Spacer VL-HDW-115 PC104 (blank) Spacer Take the Risk out of Embedded Computing Whether it’s selecting the optimum solution for your application, providing expert support during development, or on-time delivery of defect-free products, VersaLogic is here to make sure your project goes smoothly from initial concept through the extended life of your program. Contact VersaLogic today to learn more. Copyright © 2022 VersaLogic Corporation. All rights reserved. 01/11/22 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | info@versalogic.com | VersaLogic.com C O R P O R A T I O N
VL-EPM-14H 价格&库存
很抱歉,暂时无法提供与“VL-EPM-14H”相匹配的价格&库存,您可以联系我们找货
