VL-EPM-31ECP
VL-EPM-31ECP
    VERSALOGIC
    SBC BAYCAT ATOM QUAD 1.9GHZ
VL-EPM-31ECP 数据手册
Product Data Sheet BayCat PC/104-Plus Single Board Computer Overview Highlights The BayCat is a low-power / high-performance single board computer (SBC) with a traditional PC/104-Plus™ expansion interface. This combination makes it easy to upgrade existing systems to a powerful 4th generation Atom processor, while preserving plug-in expansion to existing specialty I/O boards. In addition, it also contains a full complement of on-board I/O interfaces, including USB 3.0, mini PCIe expansion socket, TPM chip, and a 24 bit digital I/O port. ƒƒ PC/104-Plus expansion site (ISA + PCI) ƒƒ 4th Generation Intel® Atom™ processor (“Bay Trail”) ƒƒ Single, dual, and quad-core models ƒƒ TPM (Trusted Platform Module) security chip ƒƒ Up to 8 GB RAM ƒƒ Gigabit Ethernet (2 ports) ƒƒ VGA and DisplayPort video ƒƒ Mini PCIe Socket / with mSATA support Driven by the low power E3800 (Bay Trail) processor, with clock rates up to 1.9 GHz, the BayCat features quad, dual, and singlecore processor options. Based on the industry-standard PC/104™ format (4.2 x 3.8 inches), this SBC is an excellent solution for size, weight and power (SWaP) sensitive applications. BayCat is built on the PC/104 form factor. It includes legacy ISA and PCI connectors to interface directly with PC/104-Plus plug-in boards. As with all VersaLogic products, the BayCat is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 10+ year extended life programs, the BayCat provides a durable embedded computer solution with an excellent cost of ownership. ƒƒ USB 3.0 and USB 2.0 ports ƒƒ Fanless versions ƒƒ -40° to +85°C Operating Temperature ƒƒ MIL-STD-202G shock & vibration ƒƒ PC/104 form factor (with ISA and PCI buses) ƒƒ Serial I/O ƒƒ SATA ƒƒ Digital I/O (24 lines) ƒƒ VersaAPI software support ƒƒ Customization available in quantities as low as 100 pcs. C O R P O R A T I O N Product Data Sheet Features 1 Intel Atom “Bay Trail” Processor 11 SPI Interface Up to 1.9 GHz clock rate. Quad, dual or single core options. Low power consumption. 2 High-performance Video 12 Main Power Input Integrated Intel Gen 7 graphics core supports DirectX 11, OpenGL 4, and H.264, MPEG-2 encoding/decoding. Analog VGA (2a) and mini DisplayPort video output (2b); both outputs support multiple display modes including Extended Desktop and Clone. 3 Industrial Temperature Supports SPI and SPX devices, including low cost analog and digital modules. Trusted Platform Module (on back side) -40° to +85°C operation for harsh environments PC/104 Form Factor Industry-standard PC/104-Plus expansion 5V Input ±5% MIL-STD-202G 13 PC/104 Expansion (on back side) Qualified for high shock/vibration environments Legacy PCI connector, stack-down 14 PC/104 Expansion (on back side) Legacy ISA connector, stack-down On-board TPM security chip can lock out unauthorized hardware and software 4 RAM (on back side) Up to 8 GB DDR3L socketed memory (one SO-DIMM). 5 8 5 Network Dual Ethernet interfaces, autodetect 10BaseT / 100BaseTX / 1000BaseT with remote boot support. 6 2b Industrial I/O 1 7 One USB 3.0 port (6a on back side); Dual RS232/422/485 serial ports (6b); four USB 2.0 ports support keyboard, mouse, and other devices, three 8254 timer/counters, I2C, and audio support (6c). 7 6b Digital I/O Twenty-four 3.3V digital I/O lines. 8 11 SATA 10 3 Gb/s SATA port. Supports rotating or solid state SATA drive. 9 9 Mini PCIe socket Supports Wi-Fi modems, GPS receivers, flash data storage with auto-detect mSATA flash storage support, and other mini PCIe modules. 6c 2a 10 MicroSD Socket Supports removable microSD card solid-state drives. 12 13 3 Tailor BayCat to Your Exact Requirements 6a 4 14 Customization options are available in quantities as low as 100 pieces. ƒƒ Conformal Coating ƒƒ Custom Labeling ƒƒ Custom Screening ƒƒ Custom Cabling ƒƒ BGA Underfill ƒƒ Connector & I/O Changes ƒƒ BIOS Modifications ƒƒ Storage device installation ƒƒ Software and Drivers ƒƒ Software pre-load ƒƒ Custom Testing ƒƒ Revision Locks ƒƒ And more – Back side VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | info@versalogic.com | VersaLogic.com BayCat PC/104-Plus Single Board Computer Specifications General Board Size Weight Processor Battery Power Requirements (+5V) † Input Voltage System Reset & Hardware Monitors Stackable Bus RoHS Memory PC/104 standard: 108 mm x 96 mm (4.23” x 3.77”) 140 grams (4.93 oz.) Intel 4th Generation “Bay Trail” Atom E3845 (quad core), E3826 (dual core), or E3815 (single core). 512K L2 cache per core. Supports Intel 64-bit instructions, AES Instructions, Execute Disable Bit, and Virtualization Technology. Connector for external 3.0V RTC backup battery Model Idle Typical Max. VL-EPM-31EAP 4.8W 5.15W 5.5W VL-EPM-31EBP 4.9W 5.2W 5.5W VL-EPM-31ECP 5.0W 6.5W 8.0W 5V +/- 5% Major voltage rails monitored. Watchdog timer with programmable timeout. CPU temperature and fan speed monitoring. Push-button reset and power. PC/104-Plus format. Legacy ISA and PCI connectors. RoHS (EU 2015/863) Environmental Cooling Options Operating Temperature ◊ Airflow Requirements Storage Temperature Altitude Thermal Shock Humidity Vibration, Sinusoidal Sweep ¤ Vibration, Random ¤ Mechanical Shock ¤ Bolt-down heat plate standard. Optional Heat sink, Heat sink with fan, heat pipe, and other thermal accessories available. Heat Sink + Model Heat Plate** Heat Sink Fan All Models -40°C to +85°C -40°C to +85°C -40°C to +85°C Ranges shown assume 90% CPU utilization. For detailed thermal information, refer to the VL-EPM-31 Reference Manual. **Heat plate must be kept below 90°C Refer to the VL-EPM-31 Reference Manual for detailed airflow requirements -40° to +85°C Operating* To 4,570m (15,000 ft.) Storage To 12,000m (40,000 ft.) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g halfsine, 11 ms duration per axis Security TPM Trusted Platform Module 1.2 device. Atmel - AT97SC3204-U2MA-20 † Represents operation at +25°C with +5V supply running Windows 7. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power is measured with 95% CPU utilization. ◊ Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) * For extended altitude information contact VersaLogic Sales Dept. ‡ TVS protected port (enhanced ESD protection) § Power pins on this port are overload protected ¥ Bootable storage device capability ¤ MIL-STD-202G shock and vibration levels are used to illustrate the extreme ruggedness of this product in general. Testing at higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact VersaLogic Sales for further information. Specifications are subject to change without notification. Intel and Atom are trademarks of Intel Corp. PC/104 and PC/104-Plus are trademarks of the PC/104 Consortium. PCI Express is a registered trademark of PCI-SIG. SATA and mSATA are trademarks of the Serial ATA International Organization. All other trademarks are the property of their respective owners. System RAM Memory Speed One SO-DIMM socket. Up to 8 GB DDR3L (1.35V) SDRAM. 1066 MHz or 1333 MHz, CPU dependent Video General VRAM Desktop Display Interface ‡ DisplayPort Interface § Integrated high-performance video. Intel Gen-7 graphics core with 4 Execution Units and Turbo Boost. Supports 2 independent displays. Supports DirectX 11, OpenGL 4.0, VP8, MPEG2, H.264, VC1, 2 HD streams (1080p@30fps), Flash and WMP support. Hardware Based Format Decode H.264, MPEG2, MVC, VC-1, WMV9, VP8, MJPEG Encode H.264, MPEG2, MVC Analog (VGA) and mini DisplayPort video interfaces support Extended Desktop, Clone, and Twin display modes. Optional adapter card converts DisplayPort output to LVDS for flat panel operation. Up to 224 MB shared DRAM Standard analog output (VGA). 24-bit. Up to 2560 x 1600 (60 Hz). Support DisplayPort Standard Version 1.1 Mini DisplayPort++ outputs supports DisplayPort and HDMI signaling (Video and Audio outputs). 24-bit. Up to 2560 x 1600. Mass Storage Rotating Drives / Flash / Solid-State Drives ¥ Single SATA (Revision 2.0) port. Latching connector. mSATA modules (SATA signaling, bootable). One microSD socket. Supports up to 32 GB. Bootable. Network Interface Ethernet ‡ Network Boot Option Two autodetect 10BaseT/100BaseTX/1000BaseT ports. On-board status LEDs and external LED header. IEEE 1588 Precision Time Protocol (PTP) slave compatible. Latching headers Via on-board BIOS extension Device I/O USB  ‡ § COM 1 / 2 ‡ Digital I/O I2C Audio Counter / Timers Four USB 2.0 host ports and one USB 3.0 host port. RS-232/422/485 selectable. 16C550 compatible. 460 Kbps. Twenty-four TTL I/O lines (3.3V). Independently configurable. Single I2C interface (3.3V) Via DisplayPort and HDMI interfaces, or optional VL-ADR-01 audio interface. Three 8254 compatible Programmable Interval Timers (PITs). Other I/O Mini PCIe Socket SPI Interface Full-length Mini PCIe socket. Supports Wi-Fi modems, GPS receivers, non-volatile flash data storage with auto-detect mSATA support, and other plug-in modules. Supports SPI and SPX devices. Supports up to two SPX modules. Software BIOS VersaAPI Sleep Mode Operating Systems Phoenix Technologies UEFI BIOS. Field reprogrammable. Support for USB keyboard/mouse and USB boot. VersaLogic Application Programming Interface to support on-board I/O devices. ACPI 3.0. Support for S3 and S4 suspend states and C1 processor state. Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX. C O R P O R A T I O N BayCat Product Data Sheet PC/104-Plus Single Board Computer Ordering Information Model VL-EPM-31EAP VL-EPM-31EBP VL-EPM-31ECP Processor Atom E3815 Atom E3826 Atom E3845 Cores Single Dual Quad Call VersaLogic Sales at (503) 747-2261 for more information! Speed 1.46 GHz 1.46 GHz 1.91 GHz Accessories Part Number Cable Kit VL-CKR-BAYCAT VL-CBR-4005 VL-CBR-2005 VL-CBR-1008 VL-CBR-1204 VL-CBR-1604 VL-CBR-0702 VL-CBR-1014 VL-CBR-1015 VL-HDW-105 VL-HDW-401 Thermal Options VL-HDW-412 VL-HDW-407 Cables VL-CBR-0401 VL-CBR-0503 VL-CBR-0701 VL-CBR-0901 VL-CBR-1206 VL-CBR-2031 VL-CBR-2033 VL-CBR-2034 Description BayCat development cable kit. Includes VL-CBR-4005, 2005, 1008, 1204, 1604, 0702, 1014, 1015, VL-HDW-105, and VL-HDW-401. System I/O paddleboard 12” 1mm 20-pin DIO cable and paddleboard 12” ATX power adapter cable 12” VGA Interface Cable, 12-pin PicoClasp Cable to 15-pin VGA 12” Dual Ethernet cable 20” SATA cable – latching 12" 1 mm 10-pin Pico-Clasp to two DB-9 Cable 1 m USB 3.0 Micro A plug to 3.0 Micro B plug 0.6" standoff package, metric thread Thermal Compound Paste. For attaching heat plates and sinks. Passive Heat Sink. Mounts to product’s heat plate. Cooling fan for HDW-406 passive heat sink. 6.25" ATX to SATA power cable 0.5 m USB 2.0 Male A to Male Micro-B Cable 19.75" SATA cable (non-latching) 9” Pico-Clasp to Dual SPX Cable, 9-pin 18” 12-pin Pico-Clasp / 15-pin VGA, RoHS 36” miniDisplayPort to MiniDisplayPort miniDisplayPort to HDMI Active Adapter, 6” (Commercial Temp.) 6” 20-pin (F) ATX to 24-pin (M) ATX adapter cable (use with PS-ATX12-300A) Audio VL-ADR-01S USB to Audio Adapter , -25° to +85°C Memory VL-MM9-xxEBN DDR3 PC3-12800 SO-DIMM memory module (1.35v) Drives VL-HDS35-xxx 3.5" rotating hard drive (SATA) Solid-State Storage (flash memory) VL-F41-xxxx microSD card (SDIO), SLC, industrial temp. Hardware VL-HDW-105 0.6" standoff package (Metric thread) VL-HDW-108 Mini PCIe Module / mSATA hardware kit (metric thread) 2.5 mm VL-HDW-112 PC104 (ISA) Spacer VL-HDW-113 PC104 (PCI) Spacer VL-HDW-115 PC104 (blank) Spacer Miscellaneous VL-PS200-ATX 200W ATX-style power supply (20+4+4-pin ATX connector) VL-HDW-111 Half to Full Size MiniPCIe Adapter kit. Metal adapter and screws (2) VL-HDW-203 PC/104 extractor tool (metal) VL-EPH-V6 Display Port to Dual Channel LVDS converter VL-PS-ATX12-300A ATX development power supply (requires VL-CBR-2034) DDR Max Speed 1066 MHz 1066 MHz 1333 MHz Graphics Frequency (Normal/Boost) 400 MHz / none 533 MHz/ 667 MHz 542 MHz/ 792 MHz Operating Temp. -40° to +85°C -40° to +85°C -40° to +85°C Cooling Heat Plate Heat Plate Heat Plate Expansion Modules Part Number Description Network VL-MPEe-E4E Gigabit Ethernet over Fiber adapter VL-MPEe-E3E Gigabit Ethernet adapter VL-MPEe-FW1E FireWire adapter Serial I/O VL-MPEe-U2E Quad serial plus twelve GPIOs Analog & Digital I/O VL-MPEe-A1E Analog input (12-bit resolution) VL-MPEe-A2E Analog input (16-bit resolution) VL-SPX-1 Analog Input Module 8-Channels VL-SPX-2 Digital I/O Module 16-lines VL-SPX-4 Analog Output Module 4-channels 12-bit VL-SPX-5 Solid State Switch Module 8-channel GPS VL-MPEu-G2E GPS receiver VL-MPEu-G3E Advanced GPS receiver Solid-State Storage (flash memory) VL-MPEs-F1Exx mSATA module (4/16/32 GB) (SATA) Adapters VL-MPEs-S3E SATA adapter VL-EPM-P2E Dual Mini PCIe Adapter Form Factor Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe SPX SPX SPX SPX Mini PCIe Mini PCIe Mini PCIe Mini PCIe PC-104 Mini PCIe Modules Take the Risk out of Embedded Computing Whether it’s selecting the optimum solution for your application, providing expert support during development, or on-time delivery of defect-free products, VersaLogic is here to make sure your project goes smoothly from initial concept through the extended life of your program. Contact VersaLogic today to learn more. Copyright © 2022 VersaLogic Corporation. All rights reserved. 01/14/22 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | info@versalogic.com | VersaLogic.com C O R P O R A T I O N
VL-EPM-31ECP
物料型号: - 型号包括VL-EPM-31EAP(单核Atom E3815)、VL-EPM-31EBP(双核Atom E3826)、VL-EPM-31ECP(四核Atom E3845)。
器件简介: - BayCat是一款低功耗、高性能的单板计算机(SBC),具有传统的PC/104-Plus™扩展接口。它易于升级现有系统到第四代Atom处理器,同时保留对现有专用I/O板的插件扩展能力。此外,它还包含全套的板载I/O接口,包括USB 3.0、mini PCIe扩展插座、TPM芯片和一个24位数字I/O端口。
引脚分配: - BayCat基于PC/104形式因素构建,包括传统的ISA和PCI连接器,以直接与PC/104-Plus插件板接口。
参数特性: - 基于低功耗的E3800(Bay Trail)处理器,时钟频率高达1.9 GHz,提供四核、双核和单核处理器选项。 - 包括PC/104-Plus扩展位(ISA + PCI)、高达8GB的RAM、千兆以太网(2端口)、VGA和DisplayPort视频、mini PCIe插座/带mSATA支持、USB 3.0和USB 2.0端口、无风扇版本、-40°至+85°C的工作温度范围、MIL-STD-202G抗震动和抗冲击、PC/104形式因素(带有ISA和PCI总线)、串行I/O SATA、数字I/O(24线)和VersaAPI软件支持。
功能详解: - 该SBC支持OEM应用,这些应用需要高可靠性和长期可用性。从应用设计支持到其10年以上的延长寿命计划,BayCat提供了一个耐用的嵌入式计算机解决方案,具有出色的拥有成本。
应用信息: - BayCat适用于尺寸、重量和功率(SWaP)敏感的应用场合。
封装信息: - 板尺寸为PC/104标准:108 mm x 96 mm(4.23" x 3.77"),重量为140克(4.93 oz)。
VL-EPM-31ECP 价格&库存
很抱歉,暂时无法提供与“VL-EPM-31ECP”相匹配的价格&库存,您可以联系我们找货
