VL-EPU-3310-EBP
VL-EPU-3310-EBP
    VERSALOGIC
    CPU E3827 1.75GHZ 2GB
VL-EPU-3310-EBP 数据手册
Product Data Sheet Hawk Embedded Processing Unit Actual Size 55 x 84 x 22 mm (2.17 x 3.31 x 0.87”) Overview Highlights The Hawk is an extremely small and rugged embedded computer. It has been engineered and tested to meet the Military and Medical industries’ evolving requirements to develop smaller, lighter, and lower power embedded systems while adhering to stringent regulatory standards. Roughly the size of a credit card and less than one inch thick, the Hawk is the embedded industry’s smallest, lightest, ultra-rugged embedded x86 computer. This embedded computer, equipped with an Intel Atom E38xx “Bay Trail” processor, is designed to withstand extreme temperature, impact, and vibration. ƒƒ A complete x86 embedded computer ƒƒ -40° to +85°C Operating Temperature ƒƒ Extremely small (55 x 84 x 22 mm) ƒƒ Shock & vibration per MIL-STD-202G ƒƒ 4th Generation Intel® Atom™ processor (“Bay Trail”) - E3845 (quad core) or - E3827 (dual core) or - E3815 (single core) ƒƒ Up to 4 GB DDR3L soldered-on RAM Available in single, dual, and quad core versions, the Hawk provides extreme performance for its size, moderate power consumption (5.4 to 6.8W typical), and a very compact package. The Hawk provides compatibility with a broad range of standard x86 application development tools for reduced development time. The integrated Intel Gen-7 graphics core provides hardwareaccelerated MPEG-4/H.264 and MPEG-2 video encoding and decoding. A standard LVDS output supports flat panel displays. An optional adapter converts the LVDS output to VGA. ƒƒ Gigabit Ethernet ƒƒ LVDS video output ƒƒ Mini PCIe Socket / with mSATA support ƒƒ USB 2.0 ports ƒƒ Serial I/O ƒƒ SATA ƒƒ Wide Input Voltage Range - 8 to 17 volts ƒƒ Fanless operation ƒƒ Customization available in quantities as low as 100 pcs. continued   C O R P O R A T I O N Product Data Sheet Overview ...continued Industry-standard system interfaces include Gigabit Ethernet with network boot capability, four USB 2.0 ports, two serial ports, and Intel High-Definition Audio (HDA). A SATA 3 Gb/s interface supports high-capacity storage. On-board eMMC Flash, a microSD socket and a Mini PCIe socket with mSATA support provide flexible solid-state drive (SSD) options. The Mini PCIe socket also accommodates plug-in Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet, Firewire, and other mini cards. Designed and tested for industrial temperature (-40º to +85ºC) operation, the rugged Hawk also meets MIL-STD-202G specifications for shock and vibration. Soldered-on RAM and latching SATA, Ethernet, power, and main I/O connectors provide additional ruggedization for use in extremely harsh environments. A wide input voltage range of 8 to 17 volts (12V typ.) simplifies system power supply requirements. It is fully compatible with 12V automotive applications. Hawk is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks. Product customization is available, even in low quantities. Options include conformal coating, BGA underfill, BIOS / splash screen configuration, application specific testing, BOM revision locks, custom labeling, etc. As with all VersaLogic products, the Hawk is backed by a five-year warranty, 5+ year offthe-shelf availability guarantee, and expert US-based technical support. Product Life Extension options support availability through the year 2025.  Features Intel Atom “Bay Trail” Processor (not shown) Up to 1.9 GHz clock rate. Quad, dual or single core options. Low power consumption. 1 Fanless Operation No moving parts required for CPU cooling in most configurations. RAM (not shown) 5 Accepts 8 to 17 volts (12V typ.). 2 3 Network 4 6 SATA MicroSD Socket Supports removable microSD card solid-state drives. 7 Gigabit Ethernet (GbE) with remote boot support. Mini PCIe Card Socket Supports Wi-Fi modems, GPS, MIL-STD-1553, Ethernet, flash data storage with auto-detect mSATA flash storage support, and other mini PCIe modules. High-performance Video Integrated Intel Gen 7 graphics core supports DirectX 11, OpenGL 4.0, and H.264, MPEG-2 encoding/ decoding. LVDS video output. Embedded Processing Unit A complete embedded computer in an extremely small/rugged format. Wide Input Voltage Range Device I/O Dual RS-232/422 serial ports and Intel High Definition Audio (HDA) compatible. 3 Gb/s SATA port supports bootable SATA hard drive. Up to 4 GB soldered-down DDR3L RAM. FLASH (not shown) 1 7 Up to 8 GB of on-board eMMC flash storage. 4 Industrial Temperature Operation -40° to +85°C operation for harsh environments. 3 MIL-STD-202G Qualified for high shock / vibration environments. Software Support Compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks. 5 2 6 VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com Hawk Embedded Processing Unit Specifications General Memory Board Size Heat plate models: 55 x 84 x 22 mm (2.17 x 3.31 x 0.87”) System RAM Weight 102 grams (3.6 oz.) Processor Intel Atom E38xx platform. 512K 8-way L2 cache per core. Intel 64-bit instructions, Virtualization Technology (VT), and new AES instructions. Connection for 3.0V RTC backup battery Video Battery Power Requirements  (@ +12V) § Model Idle Typical Max. S3 0.9W VL-EPU-3310-EAP 5.2W 6.1W 7.0W VL-EPU-3310-EBP 5.5W 6.8W 8.2W 0.9W VL-EPU-3310-EDP 5.9W 7.4W 8.8W 0.9W Input Voltage 8V–17V (nominal 12V operation) System Reset & Hardware Monitors All voltage rails monitored. Watchdog timer with programmable timeout. Push-button sleep, reset, and power. RoHS (2011/65/EU) Regulatory Compliance General VRAM OEM Flat Panel Interface Rotating Drive ‡ Flash / Solid-State Drives ‡ ** Heat plate must be kept below 90°C Airflow Requirements Refer to the VL-EPU-3310 Reference Manual for detailed USB ‡ COM 1 / 2 Mini PCIe Card Socket Supports Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet channels, non-volatile flash data storage, and other plug-in modules (full or half size). USB, SATA, and PCIe signaling. Autodetect mSATA support. Software -40° to +85°C BIOS Cooling Altitude * Fanless heat plate with optional heat sink, fan, heat pipe, and other accessories available Operating To 4,570m (15,000 ft.) Sleep Mode Operating Systems Thermal Shock 5°C/min. over operating temperature Humidity Less than 95%, noncondensing Vibration, Sinusoidal Sweep ¥ Vibration, Random ¥ MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis Mechanical Shock ¥ MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Four USB 2.0 host ports RS-232/422 selectable. 16C550 compatible. 1 Mbps max. Other I/O airflow requirements To 12,000m (40,000 ft.) One autodetect 10BaseT/100BaseTX/1000BaseT port. Latching connector. Network boot option. Device I/O Storage Temperature Storage One SATA 3 Gb/s port. Latching SATA connector. On-board eMMC MLC Flash drive. 0 to 8 GB One microSD socket. Mini PCIe socket with mSATA support Network Interface Ethernet † Ranges shown assume 90% CPU utilization. For detailed thermal information, refer to the VL-EPU-3310 Reference Manual. Integrated high-performance video. Intel Gen-7 graphics core with 4 Execution Units and Turbo Boost. Supports DirectX 11, OpenGL 4.0, VP8, MPEG2, H.264, and VC1. Up to 224 MB shared DRAM Single-channel LVDS interface. 18/24-bit. Up to 1024 x 768 (60 Hz). Mass Storage Environmental Thermal Management Bolt-on heat plate standard. Optional heat sink, fan, heat pipe, and other thermal accessories available. Operating Heat Sink + Temperature ◊ Model Heat Plate** Heat Sink Fan All models -40° to +85°C -40° to +85°C -40° to +85°C 2 GB or 4 GB of soldered-on DDR3L SDRAM. 1333 MT/s. AMI Aptio UEFI BIOS with OEM enhancements. Field reprogrammable. ACPI 3.0. Support for S3 suspend state. Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks § Represents operation at +25°C and +12V supply running Windows 7 with LVDS display, SATA, GbE, COM, and USB keyboard/mouse. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power measured with 95% CPU utilization. †  IEEE 1588 Precision Time Protocol (PTP) compatible ‡  Bootable storage device capability ◊ Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) * Extended altitude specifications available upon request ¥ MIL-STD-202G shock and vibe levels are used to illustrate the extreme ruggedness of this product in general. Testing at higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact VersaLogic Sales for further information. Tailor Hawk to Your Exact Requirements Customization options are available in quantities as low as 100 pieces. ƒƒ Conformal Coating ƒƒ Custom Labeling ƒƒ Revision Locks ƒƒ Custom Cabling ƒƒ BIOS Modifications ƒƒ Connector & I/O Changes ƒƒ Custom Testing ƒƒ BGA Underfill ƒƒ Software and Drivers Specifications are subject to change without notification. Intel and Atom are trademarks of Intel Corp. microSD is a trademark of SD-3C, LLC. All other trademarks are the property of their respective owners. ƒƒ Environmental Screening ƒƒ ApplicationSpecific Testing ƒƒ And more – C O R P O R A T I O N Hawk Product Data Sheet Embedded Processing Unit Ordering Information Model VL-EPU-3310-EAP VL-EPU-3310-EBP VL-EPU-3310-EDP Processor Atom E3815 Atom E3827 Atom E3845 Call VersaLogic Sales at (503) 747-2261 for more information! Cores 1 2 4 Accessories Part Number Cable Kit VL-CKR-HAWK Description Hawk cable kit. Includes VL-CBR-0702, 0804, 0807, 2014, 2015, 5016, and HDW-401. System I/O paddleboard SATA cable – rugged latching 20” Ethernet cable – rugged latching 12” Power adapter cable. ATX12 to Hawk. 12” LVDS to VGA adapter board 24-bit LVDS cable (Hirose) 20” Thermal compound paste. For heat sink attachment. VL-CBR-5016 VL-CBR-0702 VL-CBR-0804 VL-CBR-0807 VL-CBR-2014 VL-CBR-2015 VL-HDW-401 Cables VL-CBR-0401 ATX to SATA power cable, 6.25” VL-CBR-0701 SATA cable 20” VL-CBR-2016 18-bit LVDS cable (JAE) 20” VL-CBR-2031 miniDisplayPort to MiniDisplayPort 36” Solid-State Storage (flash memory) VL-F41-xxxx microSD card (SDIO), SLC, industrial temp. Rotating Drives VL-HDS35-xxx 3.5” hard drive (SATA) Hardware VL-PS-ATX12-300A ATX development power supply VL-HDW-108 Mini PCIe / mSATA hardware kit (metric thread) 2.5 mm Thermal Options VL-HDW-406 Passive Heat Sink. Mounts to product’s heat plate. VL-HDW-411 12V Cooling fan for use with HDW-406 heat sink. VL-HDW-408 Heat Pipe Connector Plate. Mounts to product’s heat plate. VL-HDW-405 Secondary mounting plate. – Flat. 75 x 84 mm. Simplifies installation in many situations. Attaches to heat plate on standard product. Speed 1.46 GHz 1.75 GHz 1.91 GHz RAM 2 GB 2 GB 4 GB eMMC Flash None 4 GB 8 GB Cooling Heat plate Heat plate Heat plate Mini PCIe Modules Part Number Description Network VL-MPEe-W2E Wi-Fi 802.11 a/b/g/n VL-MPEe-E3E Gigabit Ethernet adapter Serial I/O VL-MPEe-U2E Quad serial plus twelve GPIOs Analog & Digital I/O VL-MPEe-A1E Analog input (12-bit resolution) VL-MPEe-A2E Analog input (16-bit resolution) GPS VL-MPEu-G2E GPS receiver Video VL-MPEe-V5E VGA and LVDS Interface Solid-State Storage (flash memory) VL-MPEs-F1Exx mSATA module (4/16/32 GB) (SATA) Adapters VL-MPEs-S3E SATA adapter Form Factor Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Take the Risk out of Embedded Computing Whether it’s selecting the optimum solution for your application, providing expert support during development, or on-time delivery of defect-free products, VersaLogic is here to make sure your project goes smoothly from initial concept through the extended life of your program. Contact VersaLogic today to learn more. Mini PCIe Modules Copyright © 2020 VersaLogic Corporation. All rights reserved. 05/29/20 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com C O R P O R A T I O N
VL-EPU-3310-EBP 价格&库存
很抱歉,暂时无法提供与“VL-EPU-3310-EBP”相匹配的价格&库存,您可以联系我们找货
