VL-EPU-3311-EDP
VL-EPU-3311-EDP
    VERSALOGIC
    SBC ATOM BAY TRAIL QUAD 1.91GZ
VL-EPU-3311-EDP 数据手册
Product Data Sheet Overview ...continued Industry-standard system interfaces include dual Gigabit Ethernet with network boot capability, a USB 3.0 port, four USB 2.0 ports, and two serial ports. A SATA 3 Gb/s interface supports high-capacity storage. On-board eMMC Flash, a microSD socket and a Mini PCIe socket with mSATA support provide flexible solid-state drive (SSD) options. A second Mini PCIe socket also accommodates plug-in A/D, Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet, Firewire, and other mini cards. Designed and tested for industrial temperature (-40º to +85ºC) operation, the rugged Osprey also meets MIL-STD-202G specifications for shock and vibration. Soldered-on RAM and latching SATA, Ethernet, power, and main I/O connectors provide additional ruggedization for use in extremely harsh environments. A wide input voltage range of 8 to 17 volts (12V typ.) greatly simplifies system power supply requirements. It is fully compatible with 12V automotive applications. Osprey is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks. Product customization is available, even in low quantities. Options include conformal coating, BGA underfill, BIOS / splash screen configuration, application specific testing, BOM revision locks, custom labeling, etc.  Features 1 Wide Input Voltage Range Intel Atom “Bay Trail” Processor FLASH Accepts 8 to 17 volts (12V typ.). 2 High-performance Video Integrated Intel Gen 7 graphics core supports DirectX 11, OpenGL 4, and H.264, MPEG-2 encoding/ decoding. LVDS (2a) and DisplayPort++ (2b ) video outputs; both outputs support multiple display modes including Extended Desktop and Clone. (2c). 3 Network Embedded Processing Unit Up to 8 GB of on-board eMMC flash storage. Industrial Temperature Operation -40° to +85°C operation for harsh environments. MIL-STD-202G A complete embedded computer in an extremely small/rugged format. Qualified for high shock / vibration environments. Fanless Operation Software Support No moving parts required for CPU cooling in most configurations. Dual Ethernet interfaces, autodetect 10BaseT / 100BaseTX / 1000BaseT. One port with remote boot support. 4 Up to 1.9 GHz clock rate. Quad-, dual-, or single-core options. Low power consumption. RAM Compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks. Up to 4 GB soldered-down DDR3L RAM. SATA 3 Gb/s SATA port supports bootable SATA hard drive. 5 Mini PCIe Card Sockets 6 8 7b Full-(5a) and half-(5b) sized sockets. Supports Wi-Fi modems, GPS, MIL-STD-1553, Ethernet, flash data storage with auto-detect mSATA flash storage support, and other mini PCIe modules. 3 2b MicroSD Socket Supports removable microSD card solid-state drives. 7 Industrial I/O One USB 3.0 port (7a )) and four USB 2.0 ports (7b) support keyboard, mouse, and other devices. Eight 3.3V digital I/O lines, three 8254 timer/counters and I2C support. 8 7a 6 5b 5a 4 Serial Communications Dual RS-232/422/485 serial ports. 1 2c 2a VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com Osprey Embedded Processing Unit Specifications General Memory Board Size 55 x 95 x 27.5 mm (2.17 x 3.74 x 1.08”) System RAM Weight 140 grams (4.93 oz.) Processor Intel Atom E38xx platform. 512K 8-way L2 cache per core. Intel 64-bit instructions, Virtualization Technology (VT), and new AES instructions. Connection for 3.0V RTC backup battery Video Battery Power Requirements  (@ +12V) † Model Idle Typical Max. S3 VL-EPU-3311-EAP 5.3W 5.9W 6.5W 1.2W VL-EPU-3311-EBP 5.8W 6.8W 7.7W 1.2W VL-EPU-3311-EDP 6.1W 7.3W 8.5W 1.2W Input Voltage 8V–17V (nominal 12V operation) System Reset & Hardware Monitors All voltage rails monitored. Watchdog timer with programmable timeout. Push-button sleep, reset, and power. RoHS (2011/65/EU) Regulatory Compliance Environmental Thermal Management Bolt-on heat plate standard. Optional heat sink, fan, heat pipe, and other thermal accessories available. Operating Heat Sink + Temperature ◊ Model Heat Plate** Heat Sink Fan All models -40° to +85°C -40° to +85°C -40° to +85°C Ranges shown assume 90% CPU utilization. For detailed thermal information, refer to the VL-EPU-3311 Reference Manual. ** Heat plate must be kept below 90°C Airflow Requirements Refer to the VL-EPU-3311 Reference Manual for detailed airflow requirements. Storage Temperature -40° to +85°C Cooling Altitude * Fanless heat plate with optional heat sink, fan, heat pipe, and other accessories available Operating To 4,570m (15,000 ft.) Thermal Shock 5°C/min. over operating temperature Humidity Less than 95%, noncondensing Vibration, Sinusoidal Sweep ¤ Vibration, Random ¤ MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis Storage Mechanical Shock ¤ To 12,000m (40,000 ft.) MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis 2 GB or 4 GB of soldered-on DDR3L SDRAM. 1333 MT/s. General Integrated high-performance video. Intel Gen-7 graphics core with 4 Execution Units and Turbo Boost. Supports DirectX 11, OpenGL 4, VP8, MPEG2, H.264, and VC1. VRAM Up to 224 MB shared DRAM DisplayPort Interface § Mini DisplayPort++ output. 24-bit. Up to 2560 x 1600. Supports DisplayPort and HDMI signaling (Video and Audio outputs). OEM Flat Panel Single-channel LVDS interface. 18/24-bit. Interface Up to 1024 x 768 (60 Hz). Mass Storage Rotating Drive ¥ Flash / Solid-State Drives ¥ One SATA 3 Gb/s port. Latching SATA connector. On-board eMMC MLC Flash drive. 0 to 8 GB One microSD socket. Mini PCIe socket with mSATA support Network Interface Ethernet ‡ Two autodetect 10BaseT/100BaseTX/1000BaseT ports. Latching connector. One port with network boot option. Device I/O USB ‡§ COM 1 / 2 Interface ‡ Digital I/O I2C Counter / Timers One USB 3.0 / 2.0 port and four USB 2.0 host ports RS-232/422/485 selectable. 16C550 compatible. RS-232 115 Kbps – RS-422/485 460 Kbps max. Eight TTL I/O Lines 3.3V. Independently configurable. Single I2C interface Three 8254 compatible Programmable Interval Timers (PITs). Mini PCIe Card Socket Full size Supports Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet channels, non-volatile flash data storage, and other plug-in modules (full or half size). USB, SATA, and PCIe signaling. Autodetect mSATA support. Half size PCIe and USB 2.0 signaling Software BIOS Sleep Mode Operating Systems AMI Aptio UEFI BIOS with OEM enhancements. Field reprogrammable. ACPI 3.0. Support for S3 suspend state. Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks † Represents operation at +25°C and +12V supply running Windows 7 with LVDS display, SATA, GbE, COM, and USB keyboard/mouse. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power measured with 95% CPU utilization. ◊ Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) Tailor Osprey to Your Exact Requirements * Extended altitude specifications available upon request Customization options are available in quantities as low as 100 pieces. § Power pins on this port are overload protected ƒƒ Conformal Coating ƒƒ Custom Labeling ƒƒ Revision Locks ƒƒ Custom Cabling ƒƒ BIOS Modifications ¤ MIL-STD-202G shock and vibe levels are used to illustrate the extreme ruggedness of this product in general. Testing at higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact VersaLogic Sales for further information. ƒƒ Connector & I/O Changes ƒƒ Custom Testing ƒƒ BGA Underfill ƒƒ Software and Drivers ƒƒ Environmental Screening ƒƒ ApplicationSpecific Testing ƒƒ And more – ‡ TVS protected port (enhanced ESD protection) ¥  Bootable storage device capability Specifications are subject to change without notification. Intel and Atom are trademarks of Intel Corp. microSD is a trademark of SD-3C, LLC. All other trademarks are the property of their respective owners. C O R P O R A T I O N Osprey Product Data Sheet Embedded Processing Unit Ordering Information Model VL-EPU-3311-EAP VL-EPU-3311-EBP VL-EPU-3311-EDP Processor Atom E3815 Atom E3827 Atom E3845 Call VersaLogic Sales at (503) 747-2261 for more information! Cores 1 2 4 Accessories Part Number Cable Kit VL-CKR-BB11 VL-CBR-4005 VL-CBR-0702 VL-CBR-1604 VL-CBR-2032 VL-CBR-0809 VL-CBR-1014 VL-HDW-401 VL-HDW-108 Cables VL-CBR-0203 VL-CBR-0401 VL-CBR-0503 VL-CBR-0701 VL-CBR-1015 VL-CBR-2014 VL-CBR-2015 VL-CBR-2016 VL-CBR-2017 VL-CBR-0404 Description Osprey/Harrier cable kit. Includes VL-CBR-0702, 1014, 1604, 2032, 0809, 4005, HDW-401, and 108. System I/O paddleboard SATA cable – rugged latching, 20” Dual Ethernet cable, 16-pin Clik-Mate to 2 RJ-45 – rugged latching, 12” miniDisplayPort to VGA adapter, 6” Power adapter cable, 12V medium-power. ATX12 to Osprey,12” RS-232 Dual channel cable 2xDsub (9-pin), Latching, 12” Thermal compound paste. For heat sink attachment. Mini PCIe / mSATA hardware kit (metric thread) 2.5 mm (10 ea) 2-pin Latching Battery Module, 6" ATX to SATA power cable, 6.25” USB 2.0 Male A to Male Micro-B Cable, 0.5 m SATA cable, 20” USB 3.0 Micro A plug to 3.0 Micro B plug, 1 m LVDS to VGA adapter board 24-bit LVDS 1mm Hirose Cable, 20” 18-bit LVDS cable (JAE), 20” LVDS 24-bit 1.25 mm Hirose Cable, 20" LED Back Light, 3-pin Pico-Clasp / 4-pin IDE Power to 6-pin 12V, 0.5 m miniDisplayPort to MiniDisplayPort, 36” miniDisplayPort to HDMI adapter, requires DP++ port, 6” VL-CBR-2031 VL-CBR-2033 Audio VL-ADR-01S USB to Audio Adapter , -25° to +85°C Solid-State Storage (flash memory) VL-F41-xxxx microSD card (SDIO), SLC, industrial temp. Hardware VL-PS-ATX12-300A ATX development power supply Thermal Options VL-HDW-406 Passive Heat Sink. Mounts to heat plate on standard product. VL-HDW-411 12V Cooling fan for optional use with HDW-406 heat sink. VL-HDW-405 Mounting Adaptor Plate - Flat. 75 x 84 mm. Simplifies installation in many situations. Attaches to heat plate on standard product. VL-HDW-408 Heat Pipe Connector Plate. Mounts to heat plate on standard product. Speed 1.46 GHz 1.75 GHz 1.91 GHz RAM 2 GB 2 GB 4 GB eMMC Flash None 4 GB 8 GB Cooling Heat plate Heat plate Heat plate Mini PCIe Modules Part Number Description Network VL-MPEe-E5E Dual Gigabit Ethernet adapter VL-MPEe-E4E Gigabit Ethernet over Fiber adapter VL-MPEe-E3E Gigabit Ethernet adapter VL-MPEe-FW1E FireWire adapter Serial I/O VL-MPEe-U2E Quad serial plus twelve GPIOs Analog & Digital I/O VL-MPEe-A1E Analog input (12-bit resolution) VL-MPEe-A2E Analog input (16-bit resolution) GPS VL-MPEu-G2E GPS receiver VL-MPEu-G3E Advanced GPS receiver Video VL-MPEe-V5E VGA and LVDS Interface Solid-State Storage (flash memory) VL-MPEs-F1Exx mSATA module (4/16/32 GB) (SATA) Adapters VL-MPEs-S3E SATA adapter Form Factor Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Take the Risk out of Embedded Computing Mini PCIe Modules Whether it’s selecting the optimum solution for your application, providing expert support during development, or on-time delivery of defect-free products, VersaLogic is here to make sure your project goes smoothly from initial concept through the extended life of your program. Contact VersaLogic today to learn more. Copyright © 2020 VersaLogic Corporation. All rights reserved. 07/15/20 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com C O R P O R A T I O N
VL-EPU-3311-EDP
物料型号: - 型号:VL-EPU-3311
器件简介: - Osprey是一款极小且坚固耐用的嵌入式计算机,专为军事和医疗行业设计,满足更小、更轻、更低功耗的嵌入式系统需求,同时遵循严格的监管标准。Osprey是VersaLogic家族中最小的超坚固嵌入式x86计算机之一,尺寸略大于信用卡,厚度为一英寸。这款计算机配备了英特尔Atom E38xx“Bay Trail”处理器,能够承受极端的温度、冲击和震动。高级特性包括USB 3.0、双Mini PCIe插槽和DisplayPort++视频输出。
引脚分配: - 双Gigabit以太网口、USB 3.0端口、四个USB 2.0端口、两个串行端口、SATA、eMMC Flash、MicroSD卡槽、全尺寸Mini PCIe插槽(带mSATA支持)、半尺寸Mini PCIe插槽。
参数特性: - 操作温度范围:-40°C至+85°C - 抗冲击和震动:符合MIL-STD-202G标准 - 处理器:第四代英特尔Atom™处理器(“Bay Trail”)- E3845(四核)、E3827(双核)或E3815(单核) - 内存:最高4GB DDR3L焊盘RAM - 视频输出:DisplayPort++和LVDS - 网络:双千兆以太网 - USB端口:USB 3.0端口、USB 2.0端口 - 串行I/O端口:双RS-232/422/485串行端口 - SATA:eMMC Flash(最高8GB) - 微SD卡槽:支持可移动微SD卡固态驱动器
功能详解: - 集成英特尔Gen-7图形核心,提供硬件加速的MPEG-4/H.264和MPEG-2视频编码和解码。DisplayPort++和标准LVDS视频输出支持多种显示模式,包括扩展桌面和克隆。可选适配器将LVDS输出转换为VGA。 - 工业标准系统接口,包括双千兆以太网(支持网络启动)、USB 3.0端口、四个USB 2.0端口和两个串行端口。SATA 3 Gb/s接口支持高容量存储。板载eMMC Flash、微SD插槽和带mSATA支持的Mini PCIe插槽提供灵活的固态硬盘(SSD)选项。 - 设计和测试用于工业温度(-40º至+85ºC)操作,坚固耐用的Osprey也符合MIL-STD-202G标准,适用于冲击和震动。焊盘RAM和带锁扣的SATA、以太网、电源和主I/O连接器为在极其恶劣的环境中使用提供了额外的加固。8至17伏(12V典型)的宽输入电压范围大大简化了系统电源供应要求。完全兼容12V汽车应用。
应用信息: - Osprey与多种流行的x86操作系统兼容,包括Windows、Windows Embedded、Linux和VxWorks。产品定制服务可用,甚至在低至100件的数量上。选项包括敷形涂层、BGA底部填充、BIOS/启动画面配置、特定应用测试、BOM修订锁定、定制标签等。
封装信息: - 板尺寸:55x95x27.5mm(2.17x3.74x1.08"),重量:140克(4.93盎司)。无需风扇即可为CPU散热,大多数配置中不需要移动部件。
VL-EPU-3311-EDP 价格&库存
很抱歉,暂时无法提供与“VL-EPU-3311-EDP”相匹配的价格&库存,您可以联系我们找货
VL-EPU-3311-EDP
  • 1+15386.553731+1999.78805
库存:6
