VL-EPM-19EAK
VL-EPM-19EAK
    VERSALOGIC
    SINGLE BOARD COMPUTER
VL-EPM-19EAK 数据手册
Product Data Sheet Fox PC/104-Plus Single Board Computer Overview Highlights The Fox is a low power embedded computer designed around the PC/104-Plus standard. It is powered by a DMP Vortex86DX2 processor that enables the entire board to typically use less than 6.65W of power. Several I/O interfaces, multiple expansion buses, and thermal management options provide system designers with flexibility and low overall system cost. ƒƒ Industrial temp. (-40° to +85°C) versions ƒƒ Shock & vibration per MIL-STD-202G ƒƒ PC/104™ form factor ƒƒ Low power draw ƒƒ Fanless Operation ƒƒ DMP Vortex CPU ƒƒ Up to 1 GB soldered-on RAM Fox was designed with no moving parts, soldered-on RAM, and tested so it can withstand extreme temperatures, high-impact, and vibration. This single board computer is an ideal choice for applications that require moderate performance, low-power draw, high quality, and long product life. As with all VersaLogic products, the Fox is backed by a five-year warranty, 5+ year off-the-shelf availability guarantee, and expert US-based technical support. Product Life Extension options support availability through the year 2025. ƒƒ PC/104-Plus expansion interface ƒƒ Dual 10/100 Ethernet ƒƒ VGA and LVDS video ƒƒ Mini PCIe / mSATA socket ƒƒ USB 2.0 ports ƒƒ Serial I/O (RS-232/422/485) ƒƒ SATA port ƒƒ MicroSD card socket ƒƒ VersaAPI software support C O R P O R A T I O N Product Data Sheet Features 1 2 DMP Vortex86DX2 32-bit Processor Industrial Temperature Versions Software Support Vortex86DX2 x86 low power processor with integrated I/O and 2D graphics engine. -40° to +85°C operation for harsh environments. Compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, and Linux. Linux support includes VersaAPI software for onboard I/O devices. MIL-STD-202G Video Output Qualified for high shock and vibration environments. LVDS video output for flat panel displays (2a on back side). Standard analog VGA output (2b). Simultaneous output from both ports. 3 Network Support Dual Ethernet interfaces, autodetect 10BaseT / 100BaseTX with network boot capability. 4 RAM (on front and back sides) 10 Up to 1 GB soldered-on memory. 5 SATA One SATA 1.5 Gb/s port supports high-capacity storage (solid-state drives or rotating media). 6 3 Device I/O Four USB 2.0 ports support keyboard, mouse, and other devices (6a). Two RS-232/422/485 and two RS-232 serial ports, three 8254 timer/counters, eight 3.3V digital I/O lines, and USB audio support (6b). 7 Mini PCIe / mSATA Socket 7 9 6b Supports Wi-Fi modems, Ethernet, Analog I/O, Serial ports, GPS, MIL-STD-1553, Ethernet, solid-state mSATA drives, and other plug-in devices 8 2b MicroSD Socket (on back side) Supports removable microSD card solid-state drives 9 4 1 SPI Interface Supports SPI and SPX devices, including low cost analog and digital modules. 6a 5 10 PC/104-Plus Expansion Industry-standard ISA and PCI expansion connectors. 10 11 Main Power Input 5V Input ±5% 11 8 2a 4 Tailor Fox to Your Exact Requirements Customization options are available in quantities as low as 100 pieces. ƒƒ Conformal Coating ƒƒ Custom Labeling ƒƒ Custom Screening ƒƒ Custom Cabling ƒƒ BGA Underfill ƒƒ Connector & I/O Changes ƒƒ BIOS Modifications ƒƒ Application-Specific Testing ƒƒ Software and Drivers ƒƒ And more – ƒƒ Custom Testing ƒƒ Revision Locks Back side VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | info@versalogic.com | VersaLogic.com Fox PC/104-Plus Single Board Computer Specifications General Board Size Weight Processor Input Voltage Power Requirements System Reset & Hardware Monitors Stackable Bus Manufacturing Standards RoHS Memory PC/104 standard: 108 mm x 96 mm (4.23” x 3.77”) 120 grams (4.23 oz.) DMP Vortex86DX2 32-bit 5V +/- 5% Model Idle Typical Max. VL-EPM-19SAK 6.40W 6.73W 7.05W VL-EPM-19SBK 7.05W 7.10W 7.15W VL-EPM-19EAK 6.30W 6.65W 7.00W VL-EPM-19EBK 6.50W 6.78W 7.05W Major voltage rails monitored. Watchdog timer with programmable timeout. CPU temperature monitoring. Push-button reset. PC/104-Plus expansion site IPC-A-610 Class 2 modified RoHS (EU 2015/863) Environmental Operating Temperature Storage Temperature ◊ Altitude Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep ¤ Vibration, Random ¤ Mechanical Shock ¤ System RAM Video General VRAM Desktop Display Interface ‡ OEM Flat Panel Interface # -40° to +85°C Operating* To 4,570m (15,000 ft.) Storage To 12,000m (40,000 ft.) Temp. Range Airflow Requirements Standard 0° to +60°C 0.5 Linear Meters per Second (100 Linear Feet per Minute) Extended -40° to +85°C 0.5 Linear Meters per Second (100 Linear Feet per Minute) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis ‡ TVS protected port (enhanced ESD protection) # Power pins are overload protected ◊ Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) * For extended altitude information contact VersaLogic Sales ¤ MIL-STD-202G shock and vibe levels were used to illustrate the overall ruggedness of this product. Certification at higher levels or different types of shock or vibration methods per the specific requirements of the application is available. Contact VersaLogic Sales for further information. Specifications are subject to change without notification. PC/104 and PC/104-Plus are trademarks of the PC/104 Consortium. All other trademarks are the property of their respective owners. Integrated video controller. Up to 64 MB shared DRAM frame buffer. Standard analog output (VGA). Up to 1920 x 1440 (60 Hz). 32-bit. 2 mm IDC connector. LVDS interface. 18/24-bit. Up to 1024 x 768 (60 Hz). 8 bpp. CMOS-selectable TFT panel types. Support for FPD power control. Mass Storage Rotating Drive / Flash / Solid-State Drives One SATA 1.5 Gb/s port with latching connectors One Mini PCIe / mSATA socket (SATA signaling, bootable) One microSD socket. Supports up to 32 GB. Bootable. Network Interface Ethernet ‡ See Ordering Information for Specific Models Up to 1 GB DDR2 soldered-on memory. Network Boot Option Two autodetect 10BaseT/100BaseTX ports with latching pin headers. Via BIOS extension Device I/O USB # ‡ COM 1 / 2 ‡ COM 3 / 4 ‡ Audio Counter / Timers Digital I/O Four USB 2.0 host ports. RS-232 16C550 compatible. RS-232/422/485 selectable. 16C550 compatible. Optional. Use VL-ADR-01 audio interface. Three 8254 16-bit timers Eight TTL I/O lines (3.3V) Other I/O Mini PCIe / mSATA Socket SPI Interface Full-size Mini PCIe / mSATA socket. Supports Wi-Fi modems, GPS receivers, solid state mSATA drives, and other plug-in modules. Supports SPI and SPX devices. Supports up to two SPX modules. Software BIOS VersaAPI Sleep Mode Operating Systems AMI BIOS. Support for USB keyboard/mouse and USB boot. VersaLogic Application Programming Interface to support on-board I/O devices (Linux only). None Compatible with most x86 operating systems including Windows, Windows Embedded, and Linux. Please contact VersaLogic Technical Support for complete operating system information. Constraints for Windows 7 and Windows Embedded 7 operating systems require a platform with a minimum of 1 GB RAM. C O R P O R A T I O N Fox Product Data Sheet PC/104-Plus Single Board Computer Ordering Information Model VL-EPM-19SAK VL-EPM-19SBK VL-EPM-19EAK VL-EPM-19EBK Nominal CPU Speed 933 MHz 933 MHz 800 MHz 800 MHz Call VersaLogic Sales at (503) 747-2261 for more information! Memory Size 512 MB 1 GB 512 MB 1 GB Accessories Part Number Cable Kit VL-CKR-FOX VL-CBR-4005 VL-CBR-1014 VL-CBR-1008 VL-CBR-1204 VL-CBR-1604 VL-CBR-0702 VL-HDW-105 Cables VL-CBR-0203 VL-CBR-0401 VL-CBR-0503 VL-CBR-0901 VL-CBR-1206 VL-CBR-2014 VL-CBR-2015 VL-CBR-2016 VL-CBR-2017 VL-CBR-2034 Description Development Cable kit for EPM-19. Includes: VL-CBR-4005, 1014 (x2), 1008, 1204, 1604, 0702, and HDW-105. Primary Breakout Cable: 12" 2mm Latching 40-pin to 40-pin 12" Pico-Clasp to dual DB-9 ATX Power Adapter Cable, RoHS 12" 12-pin Pico-Clasp / 15-pin VGA, RoHS 12” Dual Latching Ethernet16-pin Clik-Mate to 2 RJ-45, RoHS 20” SATA cable – rugged latching 0.6" standoff package (metric thread) 6" 2-pin Latching Battery Module, RoHS 6.25" ATX to SATA power cable 0.5 m USB 2.0 Male A to Male Micro-B Cable (for ADR-01) 9” 9-pin Pico-Clasp to Dual SPX Cable, RoHS 18” 12-pin Pico-Clasp / 15-pin VGA, RoHS LVDS to VGA Adaptor Board, RoHS 20" 24-bit LVDS Hirose Cable, RoHS 20" 18-bit LVDS FPD Cable with JAE Connector, RoHS 20” 1-Ch LVDS 20-pin Molex to 1.25mm 20-pin Hirose, RoHS 6” 20-pin (F) ATX to 24-pin (M) ATX adapter cable (use with PS-ATX12-300A) Audio VL-ADR-01 USB to Audio Adapter Solid-State Storage (flash memory) VL-F41-xxxx microSD card (SDIO), SLC, industrial temp. Drives VL-HDS35-xxx 3.5” hard drive (SATA) Hardware VL-PS200-ATX Bench-top / development power supply VL-PS-ATX12-300A ATX development power supply (requires VL-CBR-2034) VL-HDW-106 0.6” standoffs, English thread (four per kit) VL-HDW-108 Mini PCIe / mSATA hardware kit (metric thread) 2.5 mm VL-HDW-112 PC104 (ISA) Spacer VL-HDW-113 PC104 (PCI) Spacer VL-HDW-115 PC104 (blank) Spacer Miscellaneous VL-HDW-111 Half to Full Size Mini PCIe Adapter kit. Metal adapter and screws (2) VL-HDW-203 PC/104 extractor tool (metal) Operating Temp. 0° to +60°C 0° to +60°C -40° to +85°C -40° to +85°C Cooling Heat Sink Heat Sink Heat Sink Heat Sink Expansion Modules Part Number Description Network VL-MPEe-E3E Gigabit Ethernet adapter VL-MPEe-FW1E 1394 FireWire Module Serial I/O VL-MPEe-U2E Quad serial plus twelve GPIOs Analog & Digital I/O VL-MPEe-A1E Analog input (12-bit resolution) VL-MPEe-A2E Analog input (16-bit resolution) VL-SPX-1 Analog Input Module 8-Channels VL-SPX-2 Digital I/O Module 16-lines VL-SPX-4 Analog Output Module 4-channels 12-bit VL-SPX-5 Solid State Switch Module 8-channel GPS VL-MPEu-G2E GPS receiver Video VL-EPM-V7E Video Expansion Module: VGA and LVDS VL-MPEe-V5E VGA and LVDS Interface Solid-State Storage (flash memory) VL-MPEs-F1Exx mSATA module (4/16/32 GB) (SATA) Adapters VL-MPEs-S3E SATA adapter Form Factor Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe SPX SPX SPX SPX Mini PCIe PC/104-Plus Mini PCIe Mini PCIe Mini PCIe Mini PCIe Modules Take the Risk out of Embedded Computing Whether it’s selecting the optimum solution for your application, providing expert support during development, or on-time delivery of defect-free products, VersaLogic is here to make sure your project goes smoothly from initial concept through the extended life of your program. Contact VersaLogic today to learn more. Copyright © 2022 VersaLogic Corporation. All rights reserved. 01/14/22 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | info@versalogic.com | VersaLogic.com C O R P O R A T I O N
VL-EPM-19EAK
物料型号:Fox
器件简介:Fox是一款基于PC/104-Plus标准的低功耗嵌入式计算机。它由DMP Vortex86DX2处理器驱动,整个板卡的典型功耗不到6.65瓦。它设计有多种I/O接口、多个扩展总线和热管理选项,为系统设计者提供了灵活性和低总体系统成本。
引脚分配:Fox具有PC/104-Plus扩展接口、双10/100以太网、VGA和LVDS视频、Mini PCIe/mSATA插座、USB 2.0端口、串行I/O (RS-232/422/485)、SATA端口、MicroSD卡插座等。
参数特性: - 工业温度版本:-40°C至+85°C - 抗冲击和抗振性能符合MIL-STD-202G标准 - PC/104™外形尺寸 - 低功耗 - 无风扇运行 - DMP Vortex CPU - 最多1 GB的焊接RAM
功能详解: - 视频输出:LVDS视频输出和标准模拟VGA输出,支持同时从两个端口输出。 - 网络支持:双以太网接口,自动检测10BaseT/100BaseTX,具备网络启动能力。 - 存储:一个SATA 1.5 Gb/s端口支持高容量存储。 - 设备I/O:四个USB 2.0端口、两个RS-232/422/485和两个RS-232串行端口等。
应用信息:Fox适用于需要中等性能、低功耗、高质量和长产品寿命的应用。
封装信息:Fox提供工业温度版本,能够在恶劣环境下工作,包括高冲击、高振动环境。
VL-EPM-19EAK 价格&库存
很抱歉,暂时无法提供与“VL-EPM-19EAK”相匹配的价格&库存,您可以联系我们找货
