VL-EBX-18EBK
VL-EBX-18EBK
    VERSALOGIC
    VORTEX86DX2 CPU 800MHZ ET 1GB
VL-EBX-18EBK 数据手册
Product Data Sheet Anaconda EBX Single Board Computer Overview Highlights The Anaconda is a moderate performance, low power embedded computer designed on a standard EBX form factor. It is powered by a DMP Vortex86DX2 processor that enables the entire board to use less than 7W (typ.). Several I/O interfaces, multiple expansions buses, and thermal management options provide systems designers with flexibility and lower overall system cost. ƒƒ Industrial temp. (-40° to +85°C) versions ƒƒ Shock & vibration per MIL-STD-202G ƒƒ EBX™ form factor ƒƒ Low power draw ƒƒ Fanless Operation ƒƒ DMP Vortex DX2 CPU ƒƒ Up to 2 GB soldered-on RAM ƒƒ PC/104-Plus expansion Anaconda was designed with no moving parts, soldered-on RAM, and ready to withstand high shock and vibration. Industrial temperature versions are available. This Single Board Computer is an ideal choice for applications that require high quality, lowpower, and long product life. As with all VersaLogic products, the Anaconda is backed by a five-year warranty, 5+ year off-the-shelf availability guarantee, and expert US-based technical support. Product Life Extension options support availability through the year 2025. ƒƒ Dual 10/100 Ethernet ƒƒ VGA and LVDS video ƒƒ Mini PCIe / mSATA socket ƒƒ USB 2.0 ports (5) ƒƒ Serial I/O (RS-232/422/485) ƒƒ SATA port ƒƒ Digital I/O (32 lines) ƒƒ Analog Input (8 chan.) ƒƒ VersaAPI software support C O R P O R A T I O N Product Data Sheet Features 1 DMP Vortex86DX2 32-bit Processor Vortex86DX2 x86 low power processor with integrated I/O and 2D graphics engine. 2 Video Output LVDS video output for flat panel displays. Standard analog VGA output. Simultaneous output from both ports. 3 Network Support 10 SPI Interface Industrial Temperature Versions Supports SPI and SPX devices, including low cost analog and digital modules. 11 PC/104 Expansion Industry-standard PC/104-Plus expansion site. Software Support 12 Power Input Compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, and Linux. Linux support includes VersaAPI software for onboard I/O devices. Wide input 9 to 15V or 5V. Jumper selectable. RAM 5 Up to 2 GB soldered-on memory. 5 8 6b 9 Analog + Digital I/O 7a 11 2 On-board data acquisition support. Eight analog inputs (7a) and thirty-two digital I/O lines (7b). 8 12 Device I/O Five USB 2.0 ports support keyboard, mouse, and other devices (6a). Two RS-232/422/485 and two RS-232 serial ports, and three 8254 timer/ counters (6b). 7 3 SATA One SATA 1.5 Gb/s port supports high-capacity storage (solid-state drives or rotating media). 6 MIL-STD-202G Qualified for high shock and vibration environments. Dual Ethernet interfaces, autodetect 10BaseT / 100BaseTX with network boot capability. 4 -40° to +85°C operation for harsh environments. 7b 1 MicroSD Socket Supports removable microSD card solid-state drives. 9 Mini PCIe / mSATA Socket Supports Wi-Fi modems, Ethernet, Analog I/O, Serial ports, GPS, MIL-STD-1553, Ethernet, solid-state mSATA drives, and other plug-in devices. 4 10 11 6a Tailor Anaconda to Your Exact Requirements Customization options are available in quantities as low as 100 pieces. ƒƒ Conformal Coating ƒƒ Custom Labeling ƒƒ Custom Screening ƒƒ Custom Cabling ƒƒ BGA Underfill ƒƒ Connector & I/O Changes ƒƒ BIOS Modifications ƒƒ Application-Specific Testing ƒƒ Software and Drivers ƒƒ And more – ƒƒ Custom Testing ƒƒ Revision Locks VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com Anaconda EBX Single Board Computer Specifications General Video Board Size EBX standard: 5.75” x 8” (146 mm x 203 mm) General Integrated video controller. Processor DMP Vortex86DX2 32-bit VRAM Up to 64 MB shared DRAM frame buffer. Input Voltage 5V +/- 5% or wide input: 9 to 15V (12V nominal). Jumper selectable. Model Idle Typical Max. VL-EBX-18SAK 5.5W 5.8W 6.0W VL-EBX-18SBK 6.0W 6.5W 7.0W VL-EBX-18SCK 6.0W 6.8W 7.5W VL-EBX-18EAK 5.5W 5.8W 6.0W VL-EBX-18EBK 6.0W 6.5W 7.0W VL-EBX-18ECK 6.0W 6.3W 6.5W All voltage rails monitored. Watchdog timer with programmable timeout. CPU temperature monitoring. Push-button reset. PC/104-Plus expansion site Desktop Display Interface ‡ OEM Flat Panel Interface # Standard analog output (VGA). Up to 1920 x 1440 (60 Hz). 32-bit. 2 mm IDC connector. LVDS interface. 18/24-bit. Up to 1024 x 768 (60 Hz). 8 bpp. CMOS-selectable TFT panel types. Support for FPD power control. Standard IPC-A-610 Class 2 modified Special Order IPC-A-610 Class 3 modified RoHS (EU 2015/863) Network Boot Option Power Requirements § System Reset & Hardware Monitors Stackable Bus Manufacturing Standards RoHS Environmental Operating Temperature ◊ Storage Temperature 0° to +60°C or -40° to +85°C See Ordering Information for Specific Models -40° to +85°C Altitude Operating * To 4,570m (15,000 ft.) Storage To 12,000m (40,000 ft.) Airflow Requirements Temp. Range Airflow Requirements Standard 0° to 0.5 Linear Meters per Second +60°C (100 Linear Feet per Minute) Extended -40° to 0.5 Linear Meters per Second (100 Linear Feet per Minute) +85°C Thermal Shock 5°C/min. over operating temperature Mass Storage Rotating Drives / Flash / Solid-State Drives Network Interface Ethernet ‡ USB # ‡ Five USB 2.0 host ports. COM 1 / 2 ‡ RS-232 16C550 compatible. COM 3 / 4 ‡ RS-232/422/485 selectable. 16C550 compatible. Analog Input Digital I/O Eight channels. 12-bit. Single-ended and/or differential pairs. 100 Ksps. 0 to 5V, ±5V, 0 to +10V, and ±10V Thirty-two TTL I/O lines 3.3V. Independently configurable. Audio Optional. Use VL-ADR-01 audio interface. Counter/Timers Three 8254 16-bit timers AT Peripherals # PS/2 Keyboard and mouse port. Other I/O Mini PCIe / mSATA Socket Less than 95%, noncondensing Vibration, Sinusoidal Sweep ¤ Vibration, Random ¤ MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis SPI Interface Up to 2 GB DDR2 soldered-on memory. Sleep Mode Memory System RAM § Represents operation at +25°C and +12V running Windows 7 with on-board, VGA display, SATA, Ethernet, COM, and USB keyboard/mouse. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power measured with 95% CPU utilization. ‡ TVS protected port (enhanced ESD protection) # Power pins are overload protected Two autodetect 10BaseT/100BaseTX ports with RJ45 connectors. Via BIOS extension Device I/O Humidity Mechanical Shock ¤ One SATA 1.5 Gb/s port with latching connector. One Mini PCIe / mSATA socket (SATA signaling, bootable) One microSD socket. Supports up to 32 GB. Bootable. Full-size Mini PCIe / mSATA socket. Supports Wi-Fi modems, GPS receivers, solid state mSATA drives, and other plug-in modules. Supports SPI and SPX devices. Supports up to four SPX modules. Software BIOS VersaAPI Operating Systems AMI BIOS. Support for USB keyboard/mouse and USB boot. VersaLogic Application Programming Interface to support on-board I/O devices (Linux only). None Compatible with most x86 operating systems including Windows, Windows Embedded, and Linux. Please contact VersaLogic Technical Support for complete operating system information. Constraints for Windows 7 and Windows Embedded 7 operating systems require a platform with a minimum of 1 GB RAM. ◊ Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) * For extended altitude information contact VersaLogic Sales Dept. ¤ MIL-STD-202G shock and vibe levels were used to illustrate the overall ruggedness of this product. Certification at higher levels or different types of shock or vibration methods per the specific requirements of the application is available. Contact VersaLogic Sales for further information. Specifications are subject to change without notification. EBX and PC/104-Plus are trademarks of the PC/104 Consortium. All other trademarks are the property of their respective owners. C O R P O R A T I O N Anaconda Product Data Sheet EBX Single Board Computer Expansion Modules Ordering Information Model VL-EBX-18SAK VL-EBX-18SBK VL-EBX-18SCK VL-EBX-18EAK VL-EBX-18EBK VL-EBX-18ECK Nominal Speed 933 MHz 933 MHz 933 MHz 800 MHz 800 MHz 800 MHz Memory Size 512 MB 1 GB 2 GB 512 MB 1 GB 2 GB Operating Temp. † 0° to +60°C 0° to +60°C 0° to +60°C -40° to +85°C -40° to +85°C -40° to +85°C Cooling Heat Sink Heat Sink Heat Sink Heat Sink Heat Sink Heat Sink † Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) Other configurations are possible. Please contact VersaLogic Sales at (503) 747-2261 to discuss requirements! Accessories Part Number Cable Kit VL-CKR-ANACON VL-CBR-5009 VL-CBR-4004 VL-CBR-2022 VL-CBR-1201 VL-CBR-0702 VL-HDW-105 Cables VL-CBR-0401 VL-CBR-1203 VL-CBR-1401 VL-CBR-1402 VL-CBR-2014 VL-CBR-2015 VL-CBR-2016 VL-CBR-2017 VL-CBR-2034 Description Development Cable kit for EBX-18. Includes: VL-CBR-5009, 4004 (x2), 2022, 1201, 0702, and HDW-105 (x2) Primary Breakout Cable: 18" 2mm Latching 50-pin to 50-pin 12” 2mm 40 pin to 40 pin IDC cable 12” ATX to 10-pin power adapter cable 12-pin to 15-pin VGA 20" SATA cable – rugged latching 0.6” standoff package (metric thread) Part Number Description Network VL-MPEe-W2E Wi-Fi 802.11 a/b/g/n VL-MPEe-E3E Gigabit Ethernet adapter Serial I/O VL-MPEe-U2E Quad serial plus twelve GPIOs Analog & Digital I/O VL-MPEe-A1E Analog input (12-bit resolution) VL-MPEe-A2E Analog input (16-bit resolution) VL-SPX-1 Analog Input Module 8-Channels VL-SPX-2 Digital I/O Module 16-lines VL-SPX-4 Analog Output Module 4-channels 12-bit VL-SPX-5 Solid State Switch Module 8-channel GPS VL-MPEu-G2E GPS receiver Video VL-EPM-V7E Video Expansion Module: VGA and LVDS VL-MPEe-V5E VGA and LVDS Interface Solid-State Storage (flash memory) VL-MPEs-F1Exx mSATA module (4/16/32 GB) (SATA) Adapters VL-MPEs-S3E SATA adapter Form Factor Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe SPX SPX SPX SPX Mini PCIe PC/104-Plus Mini PCIe Mini PCIe Mini PCIe 6.25" ATX to SATA power cable 12” ATX 12V power adapter cable (12-pins) 6" 14-pin cable assembly for (2) SPX modules 12" 14-pin cable assembly for (4) SPX modules LVDS to VGA Adapter board 20” 24-bit LVDS flat panel cable (Hirose) 20” 18-bit LVDS flat panel cable (JAE) 20” 24-bit LVDS 20-pin 1mm (Hirose) to 1.25mm (Hirose) 6” 20-pin (F) ATX to 24-pin (M) ATX adapter cable (use with PS-ATX12-300A) Audio VL-ADR-01 USB to Audio Adapter Solid-State Storage (flash memory) VL-F41-xxxx microSD card (SDIO), SLC, industrial temp. Drives VL-HDS35-xxx 3.5” hard drive (SATA) Hardware VL-PS-ATX12-300A Bench-top / development power supply VL-HDW-106 0.6” standoffs, English thread (four per kit) VL-HDW-108 Mini PCIe / mSATA hardware kit (metric thread) 2.5 mm VL-HDW-112 PC104 (ISA) Spacer VL-HDW-113 PC104 (PCI) Spacer VL-HDW-115 PC104 (blank) Spacer Miscellaneous VL-HDW-111 Half to Full Size Mini PCIe Adapter kit. Metal adapter and screws (2) VL-HDW-203 PC/104 extractor tool (metal) Mini PCIe Modules Take the Risk out of Embedded Computing Whether it’s selecting the optimum solution for your application, providing expert support during development, or on-time delivery of defect-free products, VersaLogic is here to make sure your project goes smoothly from initial concept through the extended life of your program. Contact VersaLogic today to learn more. Copyright © 2022 VersaLogic Corporation. All rights reserved. 01/11/22 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com C O R P O R A T I O N
VL-EBX-18EBK
物料型号: - 型号包括VL-EBX-18SAK、VL-EBX-18SBK、VL-EBX-18SCK、VL-EBX-18EAK、VL-EBX-18EBK和VL-EBX-18ECK,分别对应不同的主频、内存大小和工作温度范围。
器件简介: - Anaconda是一款中等性能、低功耗的嵌入式计算机,采用标准EBX板型设计。它由DMP Vortex86DX2处理器提供动力,整个板的功耗低于7瓦(典型值)。该单板计算机无需风扇运行,具有高达2GB的焊接RAM,支持多种I/O接口和扩展总线,提供灵活的热管理选项。
引脚分配: - 提供了丰富的I/O接口,包括双10/100以太网、VGA和LVDS视频、5个USB 2.0端口、串行I/O(RS-232/422/485)、SATA端口、32路数字I/O和8路模拟输入。
参数特性: - 基于DMP Vortex86DX2 32位处理器,具有集成I/O和2D图形引擎。支持LVDS和VGA视频输出,双以太网接口,2GB焊接内存,SATA 1.5 Gb/s端口,5个USB 2.0端口,2个RS-232/422/485和2个RS-232串行端口,8路模拟输入和32路数字I/O线。
功能详解: - 支持多种流行的x86操作系统,包括Windows、Windows Embedded和Linux。Linux支持包括VersaAPI软件以支持板上I/O设备。
应用信息: - Anaconda适用于需要高质量、低功耗和长寿命产品的应用,如工业控制、医疗设备、交通系统等。
封装信息: - 遵循EBX标准尺寸:5.75" x 8" (146 mm x 203 mm),提供工业温度版本,能在-40°C至+85°C下工作。
VL-EBX-18EBK 价格&库存
很抱歉,暂时无法提供与“VL-EBX-18EBK”相匹配的价格&库存,您可以联系我们找货
VL-EBX-18EBK
  • 1+5059.489291+655.80614
库存:10
