VL-EPMP-34ER
VL-EPMP-34ER
    VERSALOGIC
    WILDCAT PCI-104 DUAL CORE
VL-EPMP-34ER 数据手册
WILDCAT PCI-104 Single Board Computer Highlights PCI-104 Form Factor Industry standard expandable, compact, highly rugged format. Intel Core 2 Duo Processor Up to 2.26 GHz performance. High-performance Video 3D video acceleration (Gen 5.0). Analog and LVDS flat panel outputs. Network Support Gigabit Ethernet with remote boot support. System RAM Up to 4 GB DDR3 RAM for system flexibility. USB I/O Four USB 2.0 ports support keyboard, mouse, and other devices. Device I/O Serial port, dual SATA interface, and HD audio support. Flash Memory MiniBlade socket for high-reliability flash storage. Extended Temperature Version -40º to +85ºC operation for harsh environments. MIL-STD-202G Qualified for high shock / vibration environments. SPX Expansion Supports expansion with versatile SPX add-on I/O modules. ƒƒ Intel® Core™2 Duo processor ƒƒ Dual SATA interface ƒƒ High-performance video ƒƒ HD audio support ƒƒ Gigabit Ethernet ƒƒ MiniBlade™ flash socket ƒƒ DDR3 RAM (up to 4 GB) ƒƒ Extended temp. version ƒƒ USB 2.0 (4 ports) ƒƒ MIL-STD-202G shock/vibe ƒƒ Serial I/O (1 port) ƒƒ SPX™ I/O expansion Overview The Wildcat is an embedded single board computer (SBC) featuring an Intel 2nd generation Core 2 Duo processor. Based on the PCI-104 industry standard form factor, the Wildcat supports the PCI stackable expansion bus on a 4.21” by 3.78” footprint. With its combination of ultra-high performance (up to 2.26 GHz), mid-range power consumption (19.5W typ.), ruggedness, and compact size, the Wildcat is an ideal embedded computer solution for medical, security, defense, transportation, and industrial markets. Potential applications include flight navigation, guidance systems, and evolving applications that rely on fast on-board processing of large amounts of data. Like all VersaLogic products, the Wildcat is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the Wildcat supports serious embedded applications. The Wildcat is fully RoHS compliant. Customization is available, even in low OEM quantities. Details Driven by a 2nd generation Intel Core 2 Duo processor designed specifically for embedded applications, the Wildcat runs up to 2.26 GHz. Enhanced Intel SpeedStep ® technology provides dynamic processor frequency scaling to meet instantaneous performance needs while minimizing power draw and heat dissipation. This allows users to fine-tune the balance of power conservation and performance to suit their application needs. Intel’s GS45 + ICH9M chipset offers graphics core speeds up to 533 MHz for high-end graphics, advanced 3D rendering, high-definition video playback, and media acceleration for video CODECs. Analog VGA and LVDS flat panel video interfaces support flexible display configurations including Extended Desktop, Clone, and Twin display modes. Wildcat’s standard on-board features include gigabit Ethernet, an SO-DIMM socket for up to 4 GB DDR3 RAM, four USB 2.0 ports, one serial port, dual SATA interface, support for HD audio, and a MiniBlade socket for removable flash storage. Support for keyboard, mouse, and other devices is provided via USB. VersaLogic’s SPX expansion interface creates additional access to cost-effective plug-in I/O solutions. Available in both standard (0° to +60°C) and extended (-40° to +85°C) temperature versions; the Wildcat meets MIL-STD-202G specifications for shock and vibration. The Wildcat features transient voltage suppression (TVS) devices on many external connections for enhanced electrostatic discharge (ESD) protection in the field. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com WILDCAT PCI -104 Single Board Computer SPECIF ICATIONS The Wildcat includes an embedded BIOS with OEM enhancements from Phoenix Technologies. The field-reprogrammable BIOS supports custom defaults and the addition of firmbase applications for security processes, remote booting, and other pre-OS software functions. The Wildcat is compatible with a variety of popular operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX. General Chipset Power Requirements Speed 2.26 GHz 2.26 GHz 1.2 GHz 1.2 GHz Operating Temp. 0° to +60°C 0° to +60°C -40° to +85°C -40° to +85°C Conformal Coating None Urethane None Urethane * Special order Accessories Vibration, Random Mechanical Shock Memory Video Wildcat Cable Kit (VL-CKR-WILD) VL-CBR-0401 6.25” ATX to SATA power adapter cable VL-CBR-0701 19.75” SATA cable VL-CBR-1008 ATX to 10-pin power cable 12-pin 2 mm latching / 15-pin VGA adapter cable VL-CBR-1201 VL-CBR-3406 I/O cable set and paddleboard VL-HDW-105 0.6” standoff package (metric thread) Accessories VL-CBR-1401 VL-CBR-1402 VL-CBR-2010 VL-CBR-2011 VL-CBR-2012 VL-CBR-2014 VL-CFA-2A VL-ENCL-5x VL-F23-xxxx VL-HDS35-320 VL-HDW-106 VL-HDW-203 VL-MM7-xxxx VL-SPX-x Mass Storage Cable assembly for (2) SPX modules Cable assembly for (4) SPX modules 20” 18-bit LVDS flat panel cable (Hirose) 20” 18-bit LVDS flat panel cable (JAE) 20” 24-bit LVDS flat panel cable (Hirose) LVDS to VGA adapter board CompactFlash adapter (SATA) Development enclosure MiniBlade module (USB) 320 GB 3.5” SATA hard drive 0.6” standoff package (English thread) PC/104 extractor tool, metal DDR3 SDRAM module SPX expansion modules System Reset & Hardware Monitors Stackable Bus Other I/O Expansion RoHS Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep VL-EPMp-34S (Bottom) Ordering Information Model VL-EPMp-34S VL-EPMp-34SR* VL-EPMp-34E VL-EPMp-34ER* PCI-104 compliant: 107 mm x 96 mm (4.21” x 3.78”) Intel Core 2 Duo (SP9300). Up to 1066 MHz FSB. 6 MB L2 cache. Temperature protected. GS45 + ICH9M +5V running Windows XP with 1 GB RAM, Ethernet, keyboard, and mouse: Model Idle VL-EPMp-34S/R 2.4A (12W) VL-EPMp-34E/R 1.8A (9W) Environmental VL-EPMp-34S (Top) Board Size Processor Network Interface Device I/O Software System RAM Typical Max 3.9A (19.5W) 5.4A (27W) 2.6A (12.8W) 3.3A (16.5W) Watchdog timeout. VCC sensing (resets below 4.7V typ.). PCI: 3.3V signaling, +5V tolerant VersaLogic SPX interface Compliant Model Operating Temperature VL-EPMp-34S/R 0° to +60°C VL-EPMp-34E/R -40° to +85°C -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis One SO-DIMM socket. Up to 4 GB DDR3 SDRAM. General Integrated high-performance video. Intel GMA 4500 MHD graphics core. Analog and flat panel video interfaces support Extended Desktop, Clone, and Twin display modes. Optional video adapter card converts LVDS output to VGA for dual VGA operation. VRAM Up to 512 MB shared DRAM Desktop Display Interface* Standard analog output (VGA) OEM Flat Panel Interface 18/24-bit LVDS interface. CMOS-selectable TFT panel types. Hard Drive Dual SATA interface (Revision 2.0) Flash One MiniBlade socket (USB signaling) Ethernet* One autodetect 10BaseT/100BaseTX/1000BaseT port Network Boot Option Intel boot agent (downloadable) supports PXE protocol. Argon Managed Boot Agent (optional with royalty fee) supports PXE, RPL, NetWare, TCP/IP (DHCP, BOOTP) remote boot protocols. USB* ‡ Four USB 2.0 / 1.1 ports Serial* One RS-232/422/485 selectable port. 16C550 compatible. 460 Kbps. Audio ‡ Digital HD audio via external codec BIOS Phoenix Technologies Embedded BIOS with OEM enhancements. Field reprogrammable. Support for USB keyboard / mouse and USB boot. User-configurable CMOS defaults. Operating Systems Compatible with most x86 operating systems, including Windows, Windows Embedded, Linux, VxWorks, and QNX * TVS protected port (enhanced ESD protection) ‡ Power pins on this port are overload protected Data represents standard operation at +25°C with +5V supply unless otherwise noted. Specifications are subject to change without notification. Intel, Intel Core, and SpeedStep are trademarks of Intel Corp. MiniBlade is a trademark of the SFF-SIG. SPX is a trademark of VersaLogic Corp. All other trademarks are the property of their respective owners. 02/21/13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPMP-34ER 价格&库存
很抱歉,暂时无法提供与“VL-EPMP-34ER”相匹配的价格&库存,您可以联系我们找货
