VL-EPM-32T
VL-EPM-32T
    VERSALOGIC
    SBC PENTIUM M745 1.0 GHZ MAX 1GB
VL-EPM-32T 数据手册
CHEETAH PC/104-Plus Single Board Computer  1.0 GHz Pentium M processor  Extreme Graphics 2 video  High-speed DDR RAM  CompactFlash socket  10/100 Ethernet  Extended temp. operation  RoHS-compliant Highlights Overview High-performance Processor The Cheetah single board computer reaches a new level of sophistication for embedded product technology, integrating very high performance with an expanded feature set on the compact and rugged PC/104-Plus form factor. The advanced design of the Pentium M processor makes it suitable for a wide range of higher-end applications such as security systems, telematics, UAVs, and sophisticated communications equipment. Pentium M 1.0 GHz performance with low power draw. Extreme Graphics 2 Video Very high speed rendering and MPEG-2 support. SO-DIMM Memory Socket Accommodates up to 1 GB of DDR RAM. On-board I/O Two USB 2.0 ports, two COM ports (one 232/422/485 configurable), IDE interface, LPT port, audio. TVS Protection Enhanced ESD resistance. CompactFlash Socket Removable storage device has no moving parts. Watchdog Timer Provides hardware-level safety control for application run-away conditions. An impressive amount of functionality is packed into the 2-board set, including 10/100 Ethernet, two USB 2.0 ports, two COM ports, LPT, IDE, audio, and high-resolution video output. It includes a CompactFlash socket for on-board bootable media storage, TVS devices on the user I/O for enhanced ESD protection, and a watchdog timer to control application run-away conditions. The Cheetah accommodates up to 1 GB DDR system RAM in a high-retention SO-DIMM socket. Like all VersaLogic products, this small, powerful SBC is designed to support OEM applications where high reliability and long-term availability are required. From application design-in to 5+ years production life, its quality and longevity provide a cost-effective, long-term solution. The Cheetah is manufactured and tested to the highest quality standards and is backed by a two-year limited warranty. Customization is available in as few as 100 pieces. 400 MHz processor-side bus Details Embedded BIOS The Cheetah’s Pentium M processor provides outstanding performance of 1.0 GHz while drawing less than 12 watts of power. The processor and chipset solution relies on three separate chips: the processor, a graphics and memory controller hub that provides fast RAM access and video output, and an I/O hub that provides PCI, IDE, USB, and audio functionality. Improved system throughput. OEM embedded features. Field-upgradeable. Customization available. PC/104-Plus Form Factor Compact module is ideal for space-constrained applications. RoHS-compliant Meet EU Directive 2002/95/EC. The Extreme Graphics 2 video built into the chipset offers outputs for LVDS flat panels and analog (CRT) monitors at resolutions up to 2048 x 1536. It supports 24-bit color, very fast rendering, and MPEG-2 decoding for full motion video. Video RAM is allocated from system memory (up to 64 MB). With two COM ports, two USB ports (2.0), 10/100 Ethernet, LPT port, and IDE interface, the Cheetah offers more I/O options than other similar-sized SBCs. In addition, PC/104 and PC/104-Plus connectors provide support for many off-the-shelf expansion boards for added system functionality with minimal space requirements. The Cheetah also includes a number of reliability-enhancing features such as a watchdog timer and TVS devices. VersaLogic Corporation  •  4211 West 11th Ave., Eugene, OR 97402  •  (541) 485-8575  •  Fax (541) 485-5712  •  info@VersaLogic.com  •  www.VersaLogic.com CHEETAH PC/104-Plus Single Board Computer The Cheetah features a General Software Embedded BIOS with OEM enhancements. The field-reprogrammable BIOS supports custom defaults and CMOS settings. Optional firmware and firmbase applications for security processes, remote booting, and other pre-OS software functions are supported. The Cheetah is compatible with a variety of popular operating systems, including Windows, QNX, VxWorks, and Linux. General Specifications Processor Chipset Power Requirements System Reset Bus Speed Compatibility Mechanical Board Size Storage Temperature Operating Temperature Vibration, Sinusoidal Sweep Vibration, Random Mechanical Shock Memory Flash Interface Ordering Information VL-EPM-32t.................. Intel Pentium M 1.0 GHz, Extended Temp. (RoHS) Humidity System RAM Interface Video General Accessories VL-CBR-0501*.................................................USB transition cable (RoHS) VL-CBR-0803* . ......................................Audio cable, stereo in/out (RoHS) VL-CBR-1008* ........................................ ATX power adapter cable (RoHS) VL-CBR-1201* . ........................................... SVGA connector cable (RoHS) VL-CBR-2010.......................................LVDS Cable, HIROSE style (RoHS) VL-CBR-2011............................................... LVDS Cable, JAE style (RoHS) VL-CBR-2501.......................................Floppy connector converter (RoHS) VL-CBR-4405* . .......................................2 mm to 0.1” IDE adapter (RoHS) VL-CBR-4406* . ............................................... 2.5” IDE drive cable (RoHS) VL-CBR-8001*...............................Primary user I/O breakout cable (RoHS) VL-CKR-CHEE............................................. Development cable kit (RoHS) VL-CDD-IDE1................................................ IDE CD-RW, DVD-ROM drive VL-CFM-xxx.............................................................. CompactFlash module VL-CF-CLIP1....................................................CompactFlash retention clip VL-ENCL-4.............................................VersaTainer Ruggedized enclosure VL-ENCL-5...............................................................Development enclosure VL-FDD-144U.....................................................................USB floppy drive VL-HDD35-xxx............................................................... 3.5” IDE hard drive VL-HDW-101* . ........................................Mounting standoffs, metric thread VL-MM5D-xxx.................................................................. DDR RAM module VL-DEV-CD-L2................................. Debian Linux Board Support Package Desktop Display Interface* OEM Flat Panel Interface Network Interface Ethernet* Network Boot Option Device I/O USB*‡ IDE Interface COM 1 Interface* COM 2 Interface* LPT Interface* Audio Software Other* Operating Systems * Included in VL-CKR-CHEE cable kit BIOS Intel Pentium M 855GME +5.0V only: 12W (EPM-32t) Watchdog timeout VCC sensing (resets below 4.70V typ.) CPU PSB: 400 MHz PCI, PC/104-Plus: 33 MHz PC/104: 8 MHz PC/104: footprint compatible. PC/104-Plus: supports 3.3V PCI signaling (2.2 compliant). Dual board set, 3.55” x 3.78” (90 mm x 96 mm) with 0.2” (5 mm) overhangs in the designated connector areas. -40° to +85°C -40° to +85°C (EPM-32t) 2g constant acceleration from 5 to 500Hz, 20 minutes per axis, MIL-STD-202G, Method 204, Modified Condition A .02g2/Hz (5.35g rms), 15 minutes per axis, MIL-STD-202G, Method 214A, Condition A 30g half-sine, 11 ms duration per axis, MIL-STD-202G, Method 213B, Condition J Less than 95%, noncondensing. One 200-pin SO-DIMM socket. Up to 1 GB of 266 MHz PC2100 or 333 MHz PC2700 compatible DDR RAM. CompactFlash socket (type I or II) with DMA support. Extreme Graphics 2 chip set. Uses up to 64 MB system memory. Full motion video, MPEG-2 decoder, 3-D, edge smoothing and ultra-fast rendering. Standard analog display interface supports 24-bit color and resolutions up to 2048 x 1536. LVDS flat panel interface supports 24-bit color and resolutions up to 1024 x 768. 10/100 Ethernet port. Auto-detect. Argon Managed Boot Agent. Supports PXE, RPL, NetWare, TCP/IP (DHCP, BOOTP) remote boot protocols. Two ports USB 2.0 / 1.1 protocol. Single channel PCI-based. Up to 2 IDE devices. ATA 100 compatible. (CompactFlash is on a separate channel) RS-232, 16C550 compatible. 115K baud max. RS-232/422/485,16C550 compatible, 460K baud max. Bi-directional/EPP/ECP/floppy mode compatible. AC’97 PCI compatible. Stereo line in. Stereo line out. Keyboard and PS/2 mouse port. Compatible with most x86 operating systems, including WinCE/XP/XPe, QNX, VxWorks, and Linux. General Software’s Embedded BIOS with OEM Enhancements. Field reprogrammable. Support for USB keyboard/mouse and USB boot. *TVS protected port (Enhanced ESD protection). ‡ Power pins on this port are protected with a self-resetting fuse. Data represents standard operation at 25°C with 5.0V supply unless otherwise noted. Specifications are subject to change without notice. PC/104 is a trademark of the PC/104 Consortium. 06-08-10 VersaLogic Corporation  •  4211 West 11th Ave., Eugene, OR 97402  •  (541) 485-8575  •  Fax (541) 485-5712  •  info@VersaLogic.com  •  www.VersaLogic.com
VL-EPM-32T 价格&库存
很抱歉,暂时无法提供与“VL-EPM-32T”相匹配的价格&库存,您可以联系我们找货
