VL-EPU-2610-EDPN
VL-EPU-2610-EDPN
    VERSALOGIC
    SWAP SYSTEM 1.6 GHZ, 2GB
VL-EPU-2610-EDPN 数据手册
C O R P O R A T I O Falcon N Embedded Processing Unit ƒƒ A complete x86 embedded computer! ƒƒ Intel® Atom™ E6x0T processor ƒƒ Industrial temp. (-40º to +85ºC) ƒƒ Wide input voltage (8V–17V) ƒƒ Extremely small ƒƒ Mini PCIe expansion socket ƒƒ Trusted Platform Module (optional) Highlights Overview Embedded Processing Unit Industrial Temperature Operation The Falcon is an extremely small and rugged embedded computer. It has been engineered and tested to meet the Military and Medical industries’ evolving requirements to develop smaller, lighter, and lower power embedded systems while adhering to stringent regulatory standards. Roughly the size of a credit card and less than one inch thick, the Falcon is the embedded industry’s smallest, lightest, ultra-rugged embedded x86 computer. This embedded computer, equipped with an Intel Atom E6x0T processor, is designed to withstand extreme temperature, impact, and vibration. MIL-STD-202G Details A complete embedded computer in an extremely small / rugged format. Intel Atom E6x0T Processor 1.6 GHz performance. Low power consumption. -40° to +85°C operation for harsh environments. Qualified for high shock / vibration environments. Fanless Operation No moving parts required for CPU cooling. Wide Input Voltage Range Accepts 8 to 17 volts (12V typ.). High-performance Video Graphics core supports MPEG-4 / H.264 and MPEG-2 encoding and decoding. Network Gigabit Ethernet (GbE) with remote boot support. RAM Up to 2 GB soldered-on DDR2 RAM. SATA Supports SATA hard drives and mSATA flash storage options. Mini PCIe Card Socket Supports Wi-Fi modems, GPS, MIL-STD-1553, Ethernet, solid-state storage, and other plug-in devices. Device I/O Four serial ports, four USB ports, Intel High-Definition Audio. Trusted Platform Module (optional) On-board security option defends against attacks from unauthorized hardware and software. Driven by an Intel Atom E6x0T processor, the Falcon provides a lot of performance, lower power consumption (9–11W typical), and a very compact package. The Falcon provides compatibility with a broad range of standard x86 application development tools for reduced development time. The integrated Intel GMA600 graphics core provides hardware-accelerated MPEG-4 / H.264 and MPEG-2 video encoding and decoding. A standard LVDS output supports flat panel displays. An optional adapter converts the LVDS output to VGA. Industry-standard system interfaces include Gigabit Ethernet with network boot capability, four USB 2.0 ports, four serial ports, and Intel High-Definition Audio (HDA). A SATA 3 Gb/s interface supports high-capacity storage. Dual microSD sockets and a Mini PCIe socket with mSATA support provide flexible solid-state drive (SSD) options. The Mini PCIe socket also accommodates plug-in Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet, Firewire, and other mini cards. The Falcon supports an optional Trusted Platform Module (TPM) for applications that require enhanced hardware-level security functions. Designed and tested for industrial temperature (-40º to +85ºC) operation, the rugged Falcon also meets MIL-STD-202G specifications for shock and vibration. Soldered-on RAM and latching SATA, Ethernet, power, and main I/O connectors provide additional ruggedization for use in extremely harsh environments. Heat sink or heat plate versions provide fanless heat dissipation. Falcon is manufactured to IPC-A-610 Class 2 (modified) standards. For extremely-high-reliability applications, IPC-A-610 Class 3 versions are available. A wide input voltage range of 8 to 17 volts (12V typ.) simplifies system power supply requirements. It is fully compatible with 12V automotive applications. Falcon is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks. Product customization is available, even in low quantities. Options include a Trusted Platform Module, conformal coating, BGA underfill, IPC Class 3 assembly, BIOS / splash screen configuration, application specific testing, BOM revision locks, labeling, etc. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com C O R P O R A T I O Falcon Embedded Processing Unit Specifications N General Size Processor Chipset Battery Power Requirements  (@ +12V) § Heat sink models Heat plate models Ordering Information Model VL-EPU-2610-EBPN VL-EPU-2610-ECPN VL-EPU-2610-EDPN VL-EPU-2610-EBKN VL-EPU-2610-ECKN VL-EPU-2610-EDKN VL-EPU-2610-EBPL ¤ VL-EPU-2610-ECPL ¤ VL-EPU-2610-EBKL ¤ VL-EPU-2610-ECKL ¤ Processor Atom E640T Atom E680T Atom E680T Atom E640T Atom E680T Atom E680T Atom E640T Atom E680T Atom E640T Atom E680T Speed 1.0 GHz 1.6 GHz 1.6 GHz 1.0 GHz 1.6 GHz 1.6 GHz 1.0 GHz 1.6 GHz 1.0 GHz 1.6 GHz RAM 1 GB 1 GB 2 GB 1 GB 1 GB 2 GB 1 GB 1 GB 1 GB 1 GB Main I/O Connector Non-latching Non-latching Non-latching Non-latching Non-latching Non-latching Rugged latching Rugged latching Rugged latching Rugged latching Cooling Heat plate Heat plate Heat plate Heat sink Heat sink Heat sink Heat plate Heat plate Heat sink Heat sink Input Voltage System Reset & Hardware Monitors Manufacturing Standards Environmental Regulatory Compliance Operating Temperature Storage Temperature Cooling Airflow Requirements ¤ Special order Accessories Part Number Cables VL-CKR-FALC-N VL-CKR-FALC-L Description Falcon cable kit. Includes VL-CBR-0701, 0804, 0807, 2014, 2015, and 5013. Falcon cable kit – rugged latching. Includes VL-CBR-0702, 0804, 0807, 2014, 2015, and 5014. VL-CBR-0804 12” Ethernet cable - rugged latching VL-CBR-0807 12” power adapter cable. ATX12 to Falcon. VL-CBR-2014 LVDS to VGA adapter board VL-CBR-2015 20” 24-bit LVDS cable (Hirose) VL-CBR-2016 20” 18-bit LVDS cable (JAE) VL-CBR-5013 System I/O paddleboard VL-CBR-5014 System I/O paddleboard – rugged latching VL-CBR-0201 12” Wi-Fi antenna interface cable VL-CBR-0701 20” SATA cable VL-CBR-0702 20” SATA cable - rugged latching Solid-State Storage (flash memory) VL-F29-xxxx mSATA module (SATA), industrial temp. VL-F41-xxxx microSD card (SDIO), SLC, industrial temp. Rotating Drives VL-HDS35-xxx 3.5” hard drive (SATA) Mini PCIe Expansion Cards VL-WD10-CBN 802.11g/n Wi-Fi transceiver module Hardware VL-HDW-107 Mini PCIe / mSATA hardware kit (metric thread) VL-HDW-405 Secondary mounting plate. Simplifies installation in many situations. Attaches to heat sink or heat plate models. VL-PS-ATX12-300A ATX development power supply Miscellaneous VL-CBR-ANT01 802.11n Wi-Fi antenna VL-HDW-401 Thermal compound paste § Represents operation at +25°C and +12V supply running Windows 7 with LVDS display, SATA, GbE, COM, and USB keyboard / mouse. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power measured with 95% CPU utilization. †  IEEE 1588 Precision Time Protocol (PTP) compatible Altitude* Thermal Shock Humidity Vibration, Sinusoidal Sweep ¥ Vibration, Random ¥ Mechanical Shock ¥ Security TPM (optional) Memory System RAM Video General VRAM OEM Flat Panel Interface Mass Storage Rotating Drive ‡ Flash / SSD ‡ Network Interface Device I/O Ethernet † USB ‡  Four USB 2.0 host ports COM 1 RS-232/422 selectable. 16C550 compatible. 1 Mbps max. Handshake lines. RS-232/422 selectable. 16C550 compatible. 1 Mbps max. Four user I/O lines. Independently configurable. Intel High-Definition Audio (HDA) CODEC Supports Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet channels, non-volatile flash data storage, and other plug-in modules (full or half size). USB, SATA, and PCIe signaling. AMI Aptio UEFI BIOS with OEM enhancements. Field reprogrammable. ACPI 3.0. Support for S3 suspend state. Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks COM 2 / 3 / 4 Other I/O GPIO Audio Mini PCIe Card Socket Software BIOS ‡  Bootable storage device capability * Extended altitude specifications available upon request ¥ MIL-STD-202G shock and vibe levels are used to illustrate the extreme ruggedness of this product in general. Testing at higher levels and / or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. Intel and Atom are trademarks of Intel Corp. PCI Express is a registered trademark of PCI-SIG. microSD is a trademark of SD-3C, LLC. All other trademarks are the property of their respective owners. Heat plate models: 55 x 84 x 22 mm (2.17 x 3.31 x 0.87”) Heat sink models: 55 x 84 x 38.5 mm (2.17 x 3.31 x 1.51”) Intel Atom E6x0T platform. 512K 8-way L2 cache. Intel Hyper-Threading Technology (HT), Virtualization Technology (VT). Intel EG20T Platform Controller Hub (PCH) Connection for 3.0V RTC backup battery Model Idle Typical Max. S3 VL-EPU-2610-EBxx 8.2W 9.0W 9.8W 3.4W VL-EPU-2610-ECxx 9.7W 10.6W 11.6W 3.4W VL-EPU-2610-EDxx 9.7W 10.6W 11.6W 3.4W 8V–17V (nominal 12V operation) All voltage rails monitored. Watchdog timer with programmable timeout (1 µS to 10 min.). Push-button sleep, reset, and power. Standard IPC-A-610 Class 2 modified Custom IPC-A-610 Class 3 modified RoHS compliant -40° to +85°C. Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.).* -40° to +85°C Fanless. Heat sink or bolt-down heat plate. Model Temp. Range Airflow Heat plate models -40° to +85°C Zero airflow Heat plate must be kept below 90°C Heat sink models -40° to +60°C Zero airflow +60° to +85°C 300 LFM Operating To 15,000 ft. (4,570m) Storage To 40,000 ft. (12,000m) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Optional support for Intel Trusted Platform Module 1.2 devices. Temperature limitation to 70°C max. Standard 1 GB or 2 GB Special Order 512 MB Soldered-on DDR2 SDRAM. 800 MT/s. Intel GMA600 high-performance graphics core. Advanced 2D / 3D graphics. Hardware-accelerated video encode and decode. Up to 256 MB + 384 MB shared DRAM Single-channel LVDS interface. 18/24-bit. Up to 1280 x 768 (60 Hz). One SATA 3 Gb/s port. Latching SATA connector. Two microSD sockets. Support up to 32 GB each. Mini PCIe socket with mSATA support One autodetect 10BaseT/100BaseTX/1000BaseT port. Latching connector. Network boot option. Sleep Mode Operating Systems VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com 10/13/17
VL-EPU-2610-EDPN 价格&库存
很抱歉,暂时无法提供与“VL-EPU-2610-EDPN”相匹配的价格&库存,您可以联系我们找货
