VL-EPU-2610-EBPN
VL-EPU-2610-EBPN
    VERSALOGIC
    SWAP SYSTEM 1.0 GHZ, 1GB
VL-EPU-2610-EBPN 数据手册
C O R P O R A T I O Falcon N Embedded Processing Unit ƒ A complete x86 embedded computer! ƒ Intel® Atom™ E6x0T processor ƒ Industrial temp. (-40º to +85ºC) ƒ Wide input voltage (8V–17V) ƒ Extremely small ƒ ƒ Trusted Platform Module (optional) Highlights Overview Embedded Processing Unit The Falcon is an extremely small and rugged embedded computer. It has been engineered and tested to meet the Military and Medical industries’ evolving requirements to develop smaller, lighter, and lower power embedded systems while adhering to stringent regulatory A complete embedded computer in an extremely small / rugged format. Intel Atom E6x0T Processor Industrial Temperature Operation embedded industry’s smallest, lightest, ultra-rugged embedded x86 computer. This embedded computer, equipped with an Intel Atom E6x0T processor, is designed to withstand extreme temperature, impact, and vibration. MIL-STD-202G Details 1.6 GHz performance. Low power consumption. -40° to +85°C operation for harsh environments. Driven by an Intel Atom E6x0T processor, the Falcon provides a lot of performance, lower Fanless Operation No moving parts required for CPU cooling. Wide Input Voltage Range Accepts 8 to 17 volts (12V typ.). compatibility with a broad range of standard x86 application development tools for reduced development time. High-performance Video The integrated Intel GMA600 graphics core provides hardware-accelerated MPEG-4 / H.264 and MPEG-2 video encoding and decoding. A standard LVDS output supports flat panel displays. An optional adapter converts the LVDS output to VGA. Network four USB 2.0 ports, four serial ports, and Intel High-Definition Audio (HDA). A SATA 3 Gb/s Graphics core supports MPEG-4 / H.264 and MPEG-2 encoding and decoding. Gigabit Ethernet (GbE) with remote boot support. RAM Up to 2 GB soldered-on DDR2 RAM. SATA accommodates plug-in Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet, Firewire, and other mini cards. The Falcon supports an optional Trusted Platform Module (TPM) for applications that require enhanced hardware-level security functions. Designed and tested for industrial temperature (-40º to +85ºC) operation, the rugged Falcon Mini PCIe Card Socket Supports Wi-Fi modems, GPS, MIL-STD-1553, Ethernet, solid-state storage, and other plug-in devices. latching SATA, Ethernet, power, and main I/O connectors provide additional ruggedization Device I/O heat dissipation. Falcon is manufactured to IPC-A-610 Class 2 (modified) standards. For extremely-high-reliability applications, IPC-A-610 Class 3 versions are available. Trusted Platform Module (optional) A wide input voltage range of 8 to 17 volts (12V typ.) simplifies system power supply requirements. It is fully compatible with 12V automotive applications. unauthorized hardware and software. Falcon is compatible with a variety of popular x86 operating systems including Windows, Product customization is available, even in low quantities. Options include a Trusted Platform Module, conformal coating, BGA underfill, IPC Class 3 assembly, BIOS / splash screen VersaLogic Corporation  12100 SW Tualatin Rd., Tualatin, OR  97062  (503) 747-2261  Info@VersaLogic.com  www.VersaLogic.com C O R P O R A T I O Falcon Embedded Processing Unit Specifications N General Size Heat plate models: 55 x 84 x 22 mm (2.17 x 3.31 x 0.87”) Processor Intel Atom E6x0T platform. 512K 8-way L2 cache. Intel Hyper-Threading Technology (HT), Virtualization Technology (VT). Intel EG20T Platform Controller Hub (PCH) Chipset Battery Power Requirements  (@ +12V) § Heat plate models Ordering Information Model VL-EPU-2610-EBPN VL-EPU-2610-ECPN VL-EPU-2610-EDPN VL-EPU-2610-EBKN VL-EPU-2610-ECKN VL-EPU-2610-EDKN Processor Atom E640T Atom E680T Atom E680T Atom E640T Atom E680T Atom E680T Atom E640T Atom E680T Atom E640T Atom E680T Speed 1.0 GHz 1.6 GHz 1.6 GHz 1.0 GHz 1.6 GHz 1.6 GHz 1.0 GHz 1.6 GHz 1.0 GHz 1.6 GHz RAM 1 GB 1 GB 2 GB 1 GB 1 GB 2 GB 1 GB 1 GB 1 GB 1 GB Main I/O Connector Non-latching Non-latching Non-latching Non-latching Non-latching Non-latching Rugged latching Rugged latching Rugged latching Rugged latching Input Voltage System Reset & Hardware Monitors Cooling Heat plate Heat plate Heat plate Manufacturing Standards Environmental Heat plate Heat plate Regulatory Compliance Operating Temperature Storage Temperature Cooling Airflow Requirements Special order Accessories Part Number Cables VL-CKR-FALC-N VL-CKR-FALC-L Description Altitude* 2014, 2015, and 5014. VL-CBR-0804 12” Ethernet cable - rugged latching VL-CBR-0807 12” power adapter cable. ATX12 to Falcon. VL-CBR-2014 LVDS to VGA adapter board VL-CBR-2015 20” 24-bit LVDS cable (Hirose) VL-CBR-2016 20” 18-bit LVDS cable (JAE) VL-CBR-5013 System I/O paddleboard VL-CBR-5014 System I/O paddleboard – rugged latching VL-CBR-0201 12” Wi-Fi antenna interface cable VL-CBR-0701 20” SATA cable VL-CBR-0702 20” SATA cable - rugged latching Solid-State Storage (flash memory) VL-F29-xxxx mSATA module (SATA), industrial temp. VL-F41-xxxx microSD card (SDIO), SLC, industrial temp. Rotating Drives VL-HDS35-xxx 3.5” hard drive (SATA) Mini PCIe Expansion Cards VL-WD10-CBN 802.11g/n Wi-Fi transceiver module Hardware VL-HDW-107 VL-HDW-405 Secondary mounting plate. Simplifies installation in many situations. VL-PS-ATX12-300A Miscellaneous VL-CBR-ANT01 VL-HDW-401 ATX development power supply Humidity Vibration, Sinusoidal Sweep ¥ Vibration, Random ¥ ¥ Security TPM (optional) Memory System RAM Video General VRAM OEM Flat Panel Interface †  IEEE 1588 Precision Time Protocol (PTP) compatible Rotating Drive ‡ Flash / SSD ‡ Network Interface Device I/O Ethernet † One autodetect 10BaseT/100BaseTX/1000BaseT port. USB ‡  Four USB 2.0 host ports COM 1 RS-232/422 selectable. 16C550 compatible. COM 2 / 3 / 4 RS-232/422 selectable. 16C550 compatible. 1 Mbps max. Four user I/O lines. Independently configurable. Intel High-Definition Audio (HDA) CODEC Supports Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet channels, non-volatile flash data storage, and other plug-in modules (full or half size). USB, SATA, and PCIe signaling. AMI Aptio UEFI BIOS with OEM enhancements. Field reprogrammable. ACPI 3.0. Support for S3 suspend state. Compatible with most x86 operating systems including GPIO Audio Other I/O ‡  Bootable storage device capability * Extended altitude specifications available upon request ¥ MIL-STD-202G shock and vibe levels are used to illustrate the extreme ruggedness of this product in general. Testing at higher levels and / or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Model Temp. Range Airflow Heat plate models -40° to +85°C Zero airflow Heat plate must be kept below 90°C -40° to +60°C Zero airflow +60° to +85°C 300 LFM Operating To 15,000 ft. (4,570m) Storage To 40,000 ft. (12,000m) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Optional support for Intel Trusted Platform Module 1.2 devices. Temperature limitation to 70°C max. Standard 1 GB or 2 GB Special Order 512 MB Soldered-on DDR2 SDRAM. 800 MT/s. Intel GMA600 high-performance graphics core. Advanced 2D / 3D graphics. Hardware-accelerated video encode and decode. Up to 256 MB + 384 MB shared DRAM Single-channel LVDS interface. 18/24-bit. Up to 1280 x 768 (60 Hz). One SATA 3 Gb/s port. Latching SATA connector. Mass Storage 802.11n Wi-Fi antenna Thermal compound paste § Represents operation at +25°C and +12V supply running Windows 7 with LVDS display, SATA, GbE, COM, and USB keyboard / mouse. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power measured with 95% CPU utilization. Model Idle Typical Max. S3 VL-EPU-2610-EBxx 8.2W 9.0W 9.8W 3.4W VL-EPU-2610-ECxx 9.7W 10.6W 11.6W 3.4W VL-EPU-2610-EDxx 9.7W 10.6W 11.6W 3.4W 8V–17V (nominal 12V operation) All voltage rails monitored. Watchdog timer with programmable timeout (1 µS to 10 min.). Push-button sleep, reset, and power. Standard Custom IPC-A-610 Class 3 modified RoHS compliant -40° to +85°C. Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.).* -40° to +85°C Software BIOS Sleep Mode Operating Systems the property of their respective owners. VersaLogic Corporation  10/13/17 12100 SW Tualatin Rd., Tualatin, OR  97062  (503) 747-2261  Info@VersaLogic.com  www.VersaLogic.com
VL-EPU-2610-EBPN 价格&库存
很抱歉,暂时无法提供与“VL-EPU-2610-EBPN”相匹配的价格&库存,您可以联系我们找货
