VL-SPX-1
VL-SPX-1
    VERSALOGIC
    ET, 8 ANALOG INPUT CHANNELS
VL-SPX-1 数据手册
SPX EXPANSION MODULES Simplified I/O Expansion ƒƒ Cost effective I/O expansion ƒƒ Bolts to PC/104 stack (optional) ƒƒ Off-the-shelf and custom modules available Highlights Overview Small Footprint VersaLogic’s SPX expansion modules provide a new level of economy and convenience for routine I/O expansion. Their small size, low cost, and simplified system interface are possible due to high levels of integration and miniaturization that were not previously available. 1.2” x 3.8” size is ideal for space-constrained applications. Industrial Temperature All SPX™ modules designed for -40º to 85ºC operation. Multiple I/O Expansion Up to four SPX modules can be used in each system. Ease of Use Simple cable-based interface. Unlike larger expansion formats such as PC/104, the extremely compact SPX format does not require a stacking connector or a position in the expansion stack. Connected by a single 14-pin cable to any SPX-enabled base board, SPX expansion modules can be mounted in any position, up to two feet from the host. The small (1.2” x 3.8”) SPX modules may optionally be attached to the base board using PC/104 stand-offs. Flexibility Up to four SPX modules can be daisy-chained together to meet targeted I/O requirements at a substantial cost and space savings. Typical functions available include: Custom I/O Functions ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ Mount on expansion stack, or up to two feet away. Custom I/O solutions are quick to develop. RoHS-compliant Standard modules are fully compliant. 8-channel Analog Input 16-bit Digital I/O 4-channel Analog Output CANbus Controller 8-channel Solid State Switch SPX modules can be used with baseboards (single board computers) that include an SPX expansion connector. This includes products such as VersaLogic’s Python and Sidewinder SBCs. SPX modules can also be used with other systems that include an SPI signaling interface. Custom cabling and signaling restrictions may apply when connecting to generic SPI signals. Ordering Information VL-SPX-1..............................8-channel Analog Input, RoHS VL-SPX-2......................................... 16-bit Digital I/O, RoHS VL-SPX-3..................................... CANbus Controller, RoHS VL-SPX-4...........................4-channel Analog Output, RoHS VL-SPX-5.....8-channel 5-24 VDC Solid State Switch, RoHS Accessories VL-CBR-1401 ...........................2-module SPX Cable (RoHS) VL-CBR-1402 .........................4-module SPX Cable (RoHS) VL-HDW-101............................ Standoff Pkg, Metric Thread All VersaLogic SPX modules are fully RoHS-compliant, and are backed by VersaLogic’s standard two-year limited warranty. All SPX modules are rated for extended temperature operation (-40º to 85ºC). Like all VersaLogic products, SPX I/O modules are designed to support OEM applications where high reliability and long-term availability are essential. From ease of application designin to a five year availability guarantee, their quality and longevity provide low-cost, long-term solutions for demanding applications. SPX modules are manufactured to the highest quality standards. In addition to standard off-the-shelf modules, VersaLogic can design custom SPX modules for a nominal fee. SPX VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com SPX EXPANSIONSimplified MODULES I/O Expansion SPX Products Details The SPX platform uses SPI signaling with a defined interconnect using a 14-pin 2 mm cable. This allows a single chip interface between the I/O device and the SPX interface. The simplified system interface means that custom I/O functions are inexpensive and straightforward to implement. Multiple SPX modules, up to four per system, can be used at once. Modules of the same or different I/O type can be daisy-chained together using a single cable with multiple connectors. The modules are connected to the baseboard via a 14-pin cable. External I/O signals are typically connected directly to SPX modules via the onboard screw terminals. The 14-pin SPX interface cable typically provides up to 500mA of fused +5V power for use by the connected modules. Custom modules for most functions are very easy to develop on the SPX platform. Contact VersaLogic for a quote on a custom device. SPX-1 8-channel Analog Input Module ƒƒ 12-bit, single-ended ƒƒ 0 to +4.095V (1 mV per bit) ƒƒ 500 KSPS SPX-2 16-bit Digital I/O Module ƒƒ 3.3V CMOS Interface ƒƒ Bit programmable ƒƒ IRQ generation SPX-3 CANbus Controller ƒƒ CAN V2.0B @ 1 Mb/s ƒƒ Receive buffers, masks and filters SPX-4 4-channel Analog Output Module ƒƒ 12-bit resolution, 5μs settling time ƒƒ 10mA per channel output current ƒƒ 0 to +4.095V (1 mV per bit) SPX-5 8-channel Solid State Switch Module ƒƒ High-side / low-side switches ƒƒ 5.5V–26.5V (externally supplied) ƒƒ 2 channels with PWM inputs Specifications General Individual SPX Modules Two SPX Modules in Use Mechanical Power Requirements +5V only Compatibility ƒƒ SPX expansion connector ƒƒ 3.3V signaling SPI interface, 8 MHz clock max. 24” max cable length. Compliance ƒƒ RoHS ƒƒ SPX expansion module Board Size 30.5 mm x 96 mm (1.2” x 3.775”) Storage Temperature -40º to 85ºC Operating Temperature -40º to 85ºC Thermal Shock 5°C/min over operating temperature Vibration, Sinusoidal Sweep 2g constant acceleration from 5 to 500Hz, 20 minutes per axis, MILSTD-202G, Method 204, Modified Condition A Vibration, Random .02g2/Hz (5.35g rms) 15 minutes per axis, MIL-STD-202G, Method 214A, Condition A Mechanical Shock 30g half-sine, 11 ms duration per axis, MIL-STD-202G, Method 213B, Condition J Humidity Less than 95%, noncondensing Data represents standard operation at 25°C with 5.0V supply unless otherwise noted. Specifications are subject to change without notice. PC/104 is a trademark of the PC/104 Consortium. SPX is a trademark of VersaLogic Corporation. SPX Mechanical Specification 02-15-13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-SPX-1
物料型号:SPX EXPANSION MODULES
器件简介:VersaLogic的SPX扩展模块为常规I/O扩展提供了新的经济和便利水平。
它们的小尺寸、低成本和简化的系统接口是由于之前不可用的高集成度和微型化水平。
引脚分配:SPX平台使用SPI信号,通过14针2毫米电缆定义互连。
参数特性: - 工作温度:-40ºC 至 85ºC - 电源需求:+5V - 存储温度:-40°C 至 85°C - 振动:2g恒定加速度5至500Hz,每轴20分钟 - 机械冲击:30g半正弦波,11毫秒/轴
功能详解: - 可使用多达四个SPX模块,可以串联使用,以满足目标I/O需求。
- 典型功能包括8通道模拟输入、16位数字I/O、4通道模拟输出、CAN总线控制器、8通道固态开关。
应用信息:SPX模块可与包含SPX扩展连接器的基板(单板计算机)一起使用,例如VersaLogic的Python和Sidewinder SBCs。
也可以与包含SPI信号接口的其他系统集成。
封装信息:板尺寸为30.5mm x 96mm (1.2" x 3.8"),SPX模块可以选配PC/104支架固定在基板上。
订购信息和定制模块开发请联系VersaLogic获取报价。
VL-SPX-1 价格&库存
很抱歉,暂时无法提供与“VL-SPX-1”相匹配的价格&库存,您可以联系我们找货
