VL-MPEE-U2E
VL-MPEE-U2E
    VERSALOGIC
    Module
    MINIPCIE SERIAL + GPIO
VL-MPEE-U2E 数据手册
C O R P O R A T I O Serial + GPIO N Mini PCIe Module ƒƒ Extremely small Mini PCIe module format ƒƒ Four RS-232/422/485 ports ƒƒ Twelve general purpose I/O lines ƒƒ Three indicator LEDs ƒƒ Industrial temp. (-40º to +85ºC) operation ƒƒ MIL-STD-202G shock / vibe ƒƒ Latching connectors Highlights Overview Mini PCIe Module Format Serial I/O The VL-MPEe-U2 is an extremely small and rugged I/O module based on the industry-standard Mini PCIe module format. Unlike typical I/O expansion boards, Mini PCIe allows additional I/O functions to be added to a system with almost no increase in overall system / package size. Mini PCIe modules provide a simple, economical, and standardized way to add I/O functions to embedded computer products. Digital I/O Details User LEDs In a very small package, this board provides four serial ports, twelve general purpose I/O lines, and three indicator LEDs. Small and flexible. Four serial ports that support RS-232, RS-422, and RS-485 interfaces. Twelve general purpose I/O lines. Two user LEDs for use with GPIO pins. Application Programming Interface Simplifies software development Industrial Temperature Operation -40° to +85°C operation for harsh environments. MIL-STD-202G This serial plus GPIO module provides a traditional serial I/O interface for legacy communication. The serial ports operate in 4-wire mode with auto-direction control and baud rates up to 400 Kbps. Each port can be independently configured (hard jumpered) for RS-232, RS-422, or RS-485 operation. The twelve GPIO lines are independently configurable as an input or output. GPIO inputs can be set for normal or inverted level, and optionally set to generate an interrupt. GPIO outputs can be set to be normal HIGH or LOW state, or open drain. Qualified for high shock / vibration environments. The on-board indicator LEDs include one power indicator and two user LEDs that can be jumpered to GPIO pins. Latching Connectors This rugged product is designed and tested for full industrial temperature operation (-40º to +85ºC). It also meets MIL-STD-202G specifications for shock and vibration. Latching connectors provide additional ruggedization, making it at home in harsh environments. Prevents detachment failures. Class 3 Manufacturing (optional) IPC-A-610 Class 3 for applications requiring extreme reliability. The VL-MPEe-U2 board includes device drivers and the VersaAPI Application Programing Interface. The VersaAPI includes pre-defined calls to send or retrieve data from the on-board I/O ports. These calls greatly simplify development of the user code needed to access these ports. On the VL-MPEe-U2 board, the VersaAPI supports the on-board GPIO lines. The VersaAPI is compatible with Windows, Windows Embedded, and Linux operating systems. This I/O board is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX. The module utilizes PCIe signaling and can be used in any system that supports PCIe signaling at the Mini PCIe socket. It is manufactured to IPC-A-610 Class 2 standards. Class 3 versions are available for extremely-highreliability applications. Product customization is available, even in low quantities. Options include conformal coating, applicationspecific testing, BOM revision locks, special labeling, etc. VersaLogic Corporation  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com C O R P O R A T I O Serial + GPIO Mini PCIe Module N Specifications Ordering Information Model Function VL-MPEe-U2E Four serial ports. Twelve GPIO lines. Operating Temp. -40° to +85°C Accessories Part Number Cables VL-CBR-1014 VL-CBR-1502 Hardware VL-HDW-108 VL-HDW-110 General Environmental Description 12” dual-channel serial cable. Latching 10-pin connector to dual D-sub (9-pin). 12” GPIO cable and paddleboard with 15-position screw terminal Board Size Power Requirements Manufacturing Standards Regulatory Compliance Mini PCIe Signal Type Operating Temperature Storage Temperature Altitude * Cooling Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs Mini PCIe module hold-down screws (10) for use with 2.0 mm standoffs Mechanical Shock † Device I/O COM 1 / 2 / 3 / 4 Interface Software GPIO LEDs Drivers Mini PCIe module (full size): 30 mm x 50.95 mm x 6.39 mm 3.3V ±5% @ 0.25W (supplied by the Mini PCIe socket) Standard IPC-A-610 Class 2 modified Optional IPC-A-610 Class 3 modified RoHS PCI Express Base Specification, Rev 2.0 -40° to +85°C -40° to +85°C Operating To 15,000 ft. (4,570m) Storage To 40,000 ft. (12,000m) None (fanless) None (free air) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 msec. duration per axis RS-232/422/485 selectable. 16C550 compatible. 400 Kbps max. Twelve general purpose I/O lines One power indicator. Two user LEDs. Device drivers and VersaAPI included. Provides simplified I/O interface for most application languages. Supports onboard GPIO lines. Compatible with Windows, Windows Embedded, and Linux operating systems. * Extended altitude specifications available upon request †† MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and / or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. All other trademarks are the property of their respective owners. 03/16/16 VersaLogic Corporation  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-MPEE-U2E 价格&库存
很抱歉,暂时无法提供与“VL-MPEE-U2E”相匹配的价格&库存,您可以联系我们找货
