VL-MPEE-A1E
VL-MPEE-A1E
    VERSALOGIC
    Module
    MINIPCIE A/D 8X 12-BIT
VL-MPEE-A1E 数据手册
C O R P O R A T I O Analog Input N Mini PCIe Module ƒƒ Extremely small Mini PCIe module format ƒƒ Eight analog input channels ƒƒ 12 or 16-bit resolution ƒƒ Industrial temp. (-40º to +85ºC) operation ƒƒ MIL-STD-202G shock / vibe ƒƒ Latching connector Highlights Overview Mini PCIe Module Format Analog Input The VL-MPEe-A1 is an extremely small and rugged analog input module based on the industry-standard Mini PCIe module format. Unlike typical I/O expansion boards, Mini PCIe allows additional I/O functions to be added to a system with almost no increase in overall system / package size. Mini PCIe modules provide a simple, economical, and standardized way to add I/O functions to embedded computer products. Digital I/O Details Application Programming Interface In a very small package, this analog board provides eight single-ended or four differential input channels. The VL-MPEe-A1 model provides 12-bit resolution, while the VL-MPEe-A2 model provides 16-bit resolution. Small and flexible. Eight single-ended / four differential channels. 12 or 16-bit resolution. Three GPIO lines. Simplifies software development. Industrial Temperature Operation -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock / vibration environments. Latching Connector Prevents detachment failures. Class 3 Manufacturing (optional) IPC-A-610 Class 3 for applications requiring extreme reliability. Operating at 100,000 samples per second, each input channel is individually configurable for an input range of 0 to 5V, -5 to +5V, 0 to +10V, and -10 to +10V. In addition, the board provides three general purpose digital I/O lines which are independently configurable for input, output, or interrupts. This rugged product is designed and tested for full industrial temperature operation (-40º to +85ºC). It also meets MIL-STD-202G specifications for shock and vibration, making it at home in harsh environments. The VL-MPEe-A1 board is supported by device drivers and the VersaAPI Application Programing Interface. The VersaAPI includes pre-defined calls to send or retrieve data from the on-board I/O ports. These calls greatly simplify development of the user code needed to access these ports. On the VL-MPEe-A1 board, the VersaAPI supports the on-board A/D channels and GPIO lines. The VersaAPI is compatible with Windows, Windows Embedded, and Linux operating systems. This analog input board is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, and Linux. The module utilizes PCIe signaling and can be used in any system that supports PCIe signaling at the Mini PCIe socket. It is manufactured to IPC-A-610 Class 2 standards. Class 3 versions are available for extremely-highreliability applications. Product customization is available, even in low quantities. Options include FPGA customization, conformal coating, application-specific testing, BOM revision locks, special labeling, etc. VersaLogic Corporation  •  Tualatin, OR  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com C O R P O R A T I O Analog Input Mini PCIe Module N Specifications Ordering Information Model Function VL-MPEe-A1E VL-MPEe-A2E Analog input. Eight channel. 12-bit resolution. Analog input. Eight channel. 16-bit resolution. Operating Temp. -40° to +85°C -40° to +85°C Environmental Accessories Part Number Cables VL-CBR-2004 Hardware VL-HDW-108 VL-HDW-110 General Description Board Size Power Requirements Manufacturing Standards Regulatory Compliance Mini PCIe Signal Type Operating Temperature Storage Temperature Altitude * Cooling Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Breakout cable and paddleboard, 20-pin Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs Mini PCIe module hold-down screws (10) for use with 2.0 mm standoffs Mechanical Shock † Device I/O Analog Input GPIO Software Drivers Mini PCIe module (full size): 30 mm x 50.95 mm x 6.37 mm 3.3V ±5% @ 0.45W (from the Mini PCIe socket) Standard IPC-A-610 Class 2 modified Optional IPC-A-610 Class 3 modified RoHS PCI Express Base Specification, Rev 2.0 -40° to +85°C -40° to +85°C Operating To 15,000 ft. (4,570m) Storage To 40,000 ft. (12,000m) None (fanless) None (free air) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 msec. duration per axis Eight single-ended or four differential pairs. 12 or 16-bit resolution (depends on model). 100 Ksps. Softwareconfigurable per-channel input ranges of 0 to +5V, ±5V, 0 to +10V, and ±10V. Three general purpose 3.3V digital I/O lines. Each line independently configurable as input, output, or interrupt. Device drivers and VersaAPI included. Provides simplified I/O interface for most application languages. Supports on-board A/D channels and GPIO lines. Compatible with Windows, Windows Embedded, and Linux operating systems. * Extended altitude specifications available upon request †† MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and / or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. All other trademarks are the property of their respective owners. 03/16/16 VersaLogic Corporation  •  Tualatin, OR  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-MPEE-A1E 价格&库存
很抱歉,暂时无法提供与“VL-MPEE-A1E”相匹配的价格&库存,您可以联系我们找货
