VL-MPES-S3E
VL-MPES-S3E
    VERSALOGIC
    MINIPCIE EXPAN BOARD SATA
VL-MPES-S3E 数据手册
C O R P O R A T I O SATA Adapter N Mini PCIe Module ƒƒ Extremely small Mini PCIe module format ƒƒ SATA adapter ƒƒ Industrial temp. (-40º to +85ºC) operation ƒƒ MIL-STD-202G shock / vibe ƒƒ Latching connector Highlights Overview Mini PCIe Module Format SATA Adapter The VL-MPEs-S3 is an extremely small and rugged SATA adapter module based on the industry-standard Mini PCIe module format. Unlike typical I/O expansion boards, Mini PCIe allows additional I/O functions to be added to a system with almost no increase in overall system / package size. Mini PCIe modules provide a simple, economical, and standardized way to add I/O functions to embedded computer products. Industrial Temperature Operation Details Small and flexible. Provides one SATA channel from host system. -40° to +85°C operation for harsh environments. In a very small package, this SATA adapter board provides access to one SATA port from the host system. MIL-STD-202G This SATA adapter supports high-capacity storage (rotating media or solid-state drives) at up to 3 Gbit/s. Latching Connector This rugged product is designed and tested for full industrial temperature operation (-40º to +85ºC). It also meets MIL-STD-202G specifications for shock and vibration. Class 3 Manufacturing (optional) This SATA adapter is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX. Qualified for high shock / vibration environments. Prevents detachment failures. IPC-A-610 Class 3 for applications requiring extreme reliability. The module utilizes SATA signaling and can be used in any system that supports SATA signaling at the Mini PCIe socket. It is manufactured to IPC-A-610 Class 2 standards. Class 3 versions are available for extremely-highreliability applications. Product customization is available, even in low quantities. Options include conformal coating, applicationspecific testing, BOM revision locks, special labeling, etc. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com C O R P O R A T I O SATA Adapter Mini PCIe Module N Specifications Ordering Information Model Function VL-MPEs-S3E SATA adapter Operating Temp. -40° to +85°C Accessories Part Number Cables VL-CBR-0702 Hardware VL-HDW-108 VL-HDW-110 General Environmental Description 20” SATA cable. Latching. Board Size Power Requirements Manufacturing Standards Regulatory Compliance Mini PCIe Signal Type Operating Temperature Storage Temperature Altitude * Cooling Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs Mini PCIe module hold-down screws (10) for use with 2.0 mm standoffs Mechanical Shock † Device I/O Rotating Drives / Flash / Solid-State Drives Mini PCIe module (full size): 30 mm x 50.95 mm x 6.87 mm None. Does not provide power to SATA drive. Standard IPC-A-610 Class 2 modified Optional IPC-A-610 Class 3 modified RoHS SATA Rev 2.6 – 3 Gbit/s -40° to +85°C -40° to +85°C Operating To 15,000 ft. (4,570m) Storage To 40,000 ft. (12,000m) None (fanless) None (free air) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 msec. duration per axis One SATA port from host. Up to 3 Gbit/s performance. Latching SATA connector. * Extended altitude specifications available upon request †† MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and / or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. All other trademarks are the property of their respective owners. • Falcon EPU • VL-MPEe-U2 Module Other VersaLogic Mini PCIe Modules Model VL-MPEe-A1E VL-MPEe-A2E VL-MPEe-FW1 VL-MPEe-E3E VL-MPEe-U2E VL-MPEe-W2E VL-MPEs-F1E VL-MPEu-G2E Function Analog input (12-bit resolution) Analog input (16-bit resolution) 1394 Firewire Module, Industrial Temp. Gigabit Ethernet adapter Quad serial plus twelve GPIOs Wi-Fi 802.11 a/b/g/n mSATA drive (4/16/32 GB) GPS receiver Signaling PCIe PCIe PCIe PCIe PCIe PCIe SATA USB VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com 03/16/16
VL-MPES-S3E
物料型号: VL-MPEs-S3
器件简介: VL-MPEs-S3是一款基于Mini PCIe模块格式的超小型且坚固的SATA适配器模块。它提供了一个从主机系统访问的SATA端口,支持高达3 Gbit/s的高容量存储(旋转介质或固态驱动器)。
引脚分配: 文档中没有提供具体的引脚分配信息。
参数特性: - 尺寸: Mini PCIe模块(全尺寸): 30 mm x 50.95 mm x 6.87 mm - 工作温度: -40°C 至 +85°C - 存储温度: -40°C 至 +85°C - 符合MIL-STD-202G标准,适用于高冲击/振动环境 - SATA信号速率: 3 Gbits
功能详解: - 提供一个SATA通道 - 支持工业温度范围 - 符合MIL-STD-202G标准 - 带有锁定机制的连接器,防止意外脱落
应用信息: - 适用于需要极端可靠性的应用,如工业环境 - 兼容多种流行的x86操作系统,包括Windows、Windows Embedded、Linux、VxWorks和QNX
封装信息: - 制造标准为IPC-A-610 Class 2,可选IPC-A-610 Class 3 - 提供产品定制服务,包括涂层、特定应用测试、BOM修订锁定、特殊标签等
VL-MPES-S3E 价格&库存
很抱歉,暂时无法提供与“VL-MPES-S3E”相匹配的价格&库存,您可以联系我们找货
