VL-EPMP-V7E
VL-EPMP-V7E
    VERSALOGIC
    SBC PCI104 VID MOD MINIPCIE SKT
VL-EPMP-V7E 数据手册
Product Data Sheet VL-EPM-V7 PC/104-Plus™ Video and I/O Expansion Module Overview Highlights The VL-EPM-V7 module provides video and I/O expansion capabilities for PC/104-Plus embedded systems. It provides VGA and LVDS display outputs to PC/104-Plus embedded systems. An on-board Mini PCIe socket accommodates plug-in modules such as A/D convertors, Ethernet, Wi-Fi modems, MIL-STD-1553, and other devices. ƒƒ Industrial Temperature -40° to +85°C operation for harsh environments. ƒƒ Latching Connector Prevents detachment failures. ƒƒ PC/104-Plus Rugged industry-standard form factor. ƒƒ Mini PCIe I/O expansion Mini PCIe socket supports A/D convertors, Ethernet, Wi-Fi modems, MIL-STD-1553, and other plug-in devices. With a full industrial temperature rating and rugged construction, the VL-EPM-V7 is an ideal solution for embedded video applications in harsh, mobile, and/or remote environments. This I/O board is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, and Linux. As with all VersaLogic products, the VL-EPM-V7 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the VL-EPM-V7 provides a durable video expansion with an excellent cost of ownership. ƒƒ Video Outputs Analog VGA and/or LVDS (simultaneous / independent). ƒƒ Standard Operating System Drivers (Windows, Linux) No additional drivers needed. ƒƒ MIL-STD-202G Qualified for high shock /  vibration environments. ƒƒ 5+ Year Production Life Guarantee C O R P O R A T I O N VL-EPM-V7 Product Data Sheet Specifications General Board Size Power Requirements (+5V) * Stackable Bus Manufacturing Standards RoHs PC/104 standard: 90 mm x 96 mm (3.55” x 3.78”) Idle Typical Max. 3.28W 3.33W 3.38W PC/104-Plus: PCI, ISA (pass-through only) IPC-A-610 Class 2 compliant RoHS (EU 2015/863) Environmental Operating Temperature Storage Temperature Altitude Cooling Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Mechanical Shock † -40° to +85°C Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.).* -40° to +85°C Operating * To 15,000 ft. (4,570m) Storage To 40,000 ft. (12,000m) None (fanless) None (free air) 5°C/min. over operating temperature. Less than 95%, noncondensing. MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis. MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis. MIL-STD-202G, Method 213B, Condition G: 20g halfsine, 11 msec. duration per axis. Video Controller VRAM Desktop Display Interface OEM Flat Panel Interface Silicon Motion SM750. 2D Graphic Accelerator Video core with 128-bit 2D graphic engine. Supports a single display, two cloned displays, or two simultaneous independent displays. 16MB DDR SDRAM (32-bit) embedded in SM750 controller. Analog output (VGA). Up to 1920 x 1080 16-bit. PC/104-Plus Video Expansion Module Ordering Information Stackable Model VGA LVDS Bus VL-EPM-V7E Y Y PC/104-Plus VL-EPMp-V7E Y Y PCI-104 Mini PCIe Socket Support 1 (PCIe Signaling) 1 (PCIe Signaling) Operating Temp. -40° to +85°C -40° to +85°C Accessories Part Number Cables VL-CBR-1204 VL-CBR-1206 VL-CBR-2014 VL-CBR-2015 VL-CBR-2016 Hardware VL-HDW-105 VL-HDW-106 VL-HDW-108 Miscellaneous VL-HDW-203 Description 12” VGA Interface Cable, 12-pin PicoClasp Cable to 15-pin VGA, ET, RoHS 18” 12-pin Pico-Clasp / 15-pin VGA, RoHS LVDS to VGA Adaptor Board, ET, RoHS 20" 24-bit LVDS Hirose Cable, RoHS 20" 18-bit LVDS FPD Cable with JAE Connector, RoHS 0.6" standoff package (metric thread) 0.6" standoff package (English thread) Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs PC/104 extractor tool (metal) VersaLogic Mini PCIe Modules Model VL-MPEe-A1E VL-MPEe-A2E VL-MPEe-E3E VL-MPEe-U2E VL-MPEe-W2E Function Analog input (12-bit resolution) Analog input (16-bit resolution) Gigabit Ethernet adapter Four Serial ports. Twelve GPIO lines Wi-Fi 802.11 a/b/g/n Signaling PCIe PCIe PCIe PCIe PCIe Call VersaLogic Sales at (503) 747-2261 for more information! Single-channel LVDS interface. Up to 1280 x 1024 18/24-bit. Software BIOS Operating Systems On-board SPI-based video BIOS supports VESA standard graphics modes. Compatible with most x86 operating systems including Windows, Windows Embedded, and Linux. * For extended altitude information contact VersaLogic Sales Dept. † MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. PC/104 and PC/104-Plus are trademarks of the PC/104 Consortium. VESA is a trademark of the Video Electronics Standards Association. All other trademarks are the property of their respective owners. Tailor a Module to Your Exact Requirements Mini PCIe Modules Product customization is available, even in low quantities. Options include conformal coating, application-specific testing, BOM revision locks, special labeling, and more. 04/13/21 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com C O R P O R A T I O N
VL-EPMP-V7E 价格&库存
很抱歉,暂时无法提供与“VL-EPMP-V7E”相匹配的价格&库存,您可以联系我们找货
