VL-EPMS-E1B
VL-EPMS-E1B
    VERSALOGIC
    SUMIT+PC/104, ET, GBE, 2 PORT
VL-EPMS-E1B 数据手册
VL-EPMs-E1 SUMIT™-104 Dual Gigabit Ethernet Module ƒƒ Dual gigabit Ethernet ƒƒ PCI Express Mini Card socket ƒƒ SUMIT and PC/104™ expansion ƒƒ Extended temp. operation Highlights SUMIT and PC/104 Compatible Supports SUMIT and ISA expansion on a compact, highly rugged format. Network Support Dual gigabit Ethernet ports for high-bandwidth applications or system redundancy. PCI Express Mini Card Socket High-speed, small form factor cards enable additional wireless functionality. Extended Temperature Operation -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock/vibration environments. Overview The VL-EPMs-E1 is a SUMIT-based dual gigabit Ethernet (GbE) expansion module with a PCI Express Mini Card socket. This versatile expansion module is the ideal solution for highbandwidth and/or wireless network applications in a wide range of applications including defense, aerospace, homeland security, and industrial automation where a small footprint and extended temperature operation are crucial design factors. Based on the industry standard PC/104 footprint, the VL-EPMs-E1 features the SUMIT expansion interface. SUMIT provides a stackable expansion interface that supports both high- and lowspeed signals. This simplifies adding both standard and custom I/O boards to the system. The VL-EPMs-E1 expansion interfaces include PCIe, USB, LPC, SPI, SMBus, as well as optional ISA bus support for PC/104 modules. Like all VersaLogic products, the VL-EPMs-E1 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in to 5+ guaranteed years of production life, the VL-EPMs-E1 provides a durable embedded computer solution with an exceptional cost of ownership. The E1 is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. Details The VL-EPMs-E1 is a SUMIT-104 expansion module that provides two gigabit Ethernet channels based on Intel ® 82574L controllers. Additional system expansion and communications flexibility is available via the on-board PCI Express Mini Cards socket. The socket is compatible with: ƒƒ ƒƒ ƒƒ ƒƒ 802.11a/b/g Wi-Fi network adapters GPS radio modules (for global location and precision time stamping) 3G modems Solid-state flash drives (SSDs) This GbE module offers low power consumption (3.5 watts) and low thermal dissipation for heat sensitive applications, as well as transient voltage suppression (TVS) on the Ethernet connections to protect from power spikes and surges. With an Ethernet buffer of 16 KB RAM, data is easily stored and retrieved. Extended temperature operation provides reliability in harsh environments. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com VL-EPMs-E1 SUMIT™-104 Dual Gigabit Ethernet Module SPECIF ICATIONS The VL-EPMs-E1 works with the entire family of industry-standard SUMITbased computer and add-on boards. General The VL-EPMs-E1 is compatible with a variety of popular operating systems, including Windows, Windows Embedded, Linux, VxWorks, and QNX. Environmental Board Size Power Requirements RoHS Operating Temperature Storage Temperature Thermal Shock Humidity Vibration, Sinusoidal Sweep Vibration, Random Mechanical Shock VL-EPMs-E1b (Top) VL-EPMs-E1b (Bottom) Ordering Information VL-EPMs-E1a........................................Dual GbE, SUMIT-A connector VL-EPMs-E1b.......................... Dual GbE, SUMIT-AB + ISA connectors Accessories VL-CBR-0201........................................... Wi-Fi antenna adapter cable VL-CBR-ANT01............................................... Wi-Fi (802.11n) antenna VL-HDW-105...............................0.6” standoff package (metric thread) VL-HDW-106.............................0.6” standoff package (English thread) VL-HDW-107.............................................. Metric screw and washer kit VL-HDW-203............................................. PC/104 extractor tool, metal VL-WD10-CBN....................PCI Express Mini Card: 802.11g/n wireless Network Interface Ethernet* Device I/O PCI Express Mini Card Software Operating Systems Network Boot Option PC/104 standard: 90 mm x 96 mm (3.55” x 3.78”) +5 VDC: 3.5W Compliant -40° to +85°C -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Dual autodetect 10BaseT/100BaseTX/ 1000BaseT ports based on Intel 82574L Intel boot agent (downloadable): supports PXE protocol Latching PCI Express Mini Card interface with retention screws. PCI Express Mini Card Specification 1.2 compliant. Compatible with most x86 operating systems, including Windows, Windows Embedded, Linux, VxWorks, and QNX * TVS protected port (enhanced ESD protection) Data represents standard operation at +25°C with +5V supply unless otherwise noted. Specifications are subject to change without notification. PC/104 is a trademark of the PC/104 Consortium. SUMIT is a trademark of the SFF-SIG. All other trademarks are the property of their respective owners. SUMIT Resources Needed Form Factor: SUMIT-104 SUMIT-A PCIe x1 1 PCIe x4 USB 1 ExpressCard – LPC – SPI / µWire – SMBus / I 2 C – +12V – +5V ü +5Vsb +3.3V – – SUMIT-B* – – ü – – * Optional 02/20/13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPMS-E1B 价格&库存
很抱歉,暂时无法提供与“VL-EPMS-E1B”相匹配的价格&库存,您可以联系我们找货
VL-EPMS-E1B
  • 1+4758.355551+615.83790
库存:77
