VL-EPM-E2D
VL-EPM-E2D
    VERSALOGIC
    PC/104-PLUS, ET, 10/100, 2 PORT
VL-EPM-E2D 数据手册
C O R P O R A T I O VL-EPM-E2 N PC/104-Plus Ethernet Module ƒƒ Dual 10/100 Ethernet ƒƒ Extended temp. operation ƒƒ Ruggedized version ƒƒ MIL-STD-202G shock / vibe ƒƒ Activity indicators ƒƒ RoHS compliant Overview Highlights PC/104-Plus Form Factor Industry standard form factor stacks with compatible CPUs and expansion modules. Network Support Two on-board 10/100 Ethernet ports. The VL-EPM-E2 is an embedded PC/104-Plus format expansion module featuring highperformance networking capabilities. With two autodetect 10BaseT / 100BaseTX Ethernet ports, industrial temperature operation, and extensive ruggedization, the VL-EPM-E2 is an ideal expansion solution for embedded applications in harsh industrial, energy, defense/aerospace, medical, and robotics environments. Like all VersaLogic products, the VL-EPM-E2 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the VL-EPM-E2 provides a durable embedded computer solution with an excellent cost of ownership. The VL-EPM-E2 is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. Industrial Temperature -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock/vibration environments. Activity Indicators On-board status LEDs with support for external indicators. Details The VL-EPM-E2 is based on the industry standard PC/104-Plus form factor, which provides for simplified plug-in expansion with other PC/104-Plus SBC and expansion modules. The VL-EPM-E2 is available with one or two on-board 10/100 Ethernet ports. The Ethernet controller features auto-negotiation for simplified configuration and each Ethernet port is independently configurable as a separate subnet. The board is available with either standard RJ45 output connectors, or with latching header connectors for high shock or vibration environments. On-board LEDs provide Link/Activity and Speed status for each Ethernet port with an additional header for external LED support. The VL-EPM-E2 is designed and tested for operation over the full industrial temperature range (-40° to +85°C) and meets MIL-STD-202G specifications for mechanical shock and vibration. Software drivers are available for a wide variety of operating systems to provide a complete high-performance networking solution. C O R P O R A T I O N VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com C O R P O R A T I O VL-EPM-E2 PC/104-Plus Ethernet Module N SPECIF ICATIONS General Environmental VL-EPM-E2B (Top) Ordering Information Model VL-EPM-E2A VL-EPM-E2B VL-EPM-E2D Ethernet Ports 1 2 2 Connector(s) RJ45 RJ45 Latching header Accessories Part Number VL-CBR-0804 VL-HDW-105 VL-HDW-106 VL-HDW-203 Description Latching Ethernet adapter cable 0.6” standoff package (metric thread) 0.6” standoff package (English thread) PC/104 board extractor tool (metal) Board Size Power Requirements * System Reset Stackable Bus Manufacturing Standards RoHS Operating Temperature † Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Vibration, Random Mechanical Shock Network Interface Controller Ethernet ‡ Configuration Activity Indicators Software Operating Systems PC/104-Plus standard: 90 mm x 96 mm (3.55” x 3.78”) +5V @ 0.52A (2.6W) max. Reset via PCI interface PC/104-Plus: PCI, ISA (pass-through) IPC-A-610 Class 2 compliant Compliant -40° to +85°C -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Micrel KSZ8841-PMQLI Up to two autodetect 10BaseT / 100BaseTX ports EEPROM (1K) for each Ethernet interface (MAC address, default configuration). Each port independently configurable as separate subnet. On-board Link/Activity and Speed LED for each Ethernet port. Header for external LEDs. Compatible with most x86 operating systems, including Windows, Windows Embedded, Linux, VxWorks, and QNX ** Power specifications represent operation at +25°C with +5V supply running Windows XP with Ethernet ‡ TVS protected (enhanced ESD protection) † Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) Specifications are subject to change without notification. All trademarks are the property of their respective owners. 07/21/14 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPM-E2D
物料型号: - VL-EPM-E2A:1个RJ45接口 - VL-EPM-E2B:2个RJ45接口 - VL-EPM-E2D:2个锁扣式接口
器件简介: VL-EPM-E2是一款嵌入式PC/104-Plus格式的扩展模块,具备高性能的网络功能。它包含两个自动检测的10BaseT/100BaseTX以太网端口,支持工业温度范围操作,并具有广泛的加固特性,适用于恶劣的工业、能源、国防/航空、医疗和机器人环境。
引脚分配: - 基于PC/104-Plus标准,支持与其他PC/104-Plus单板计算机和扩展模块的简化插件扩展。
参数特性: - 工作温度:-40°C至+85°C,满足工业温度范围要求。 - 抗震动和冲击:符合MIL-STD-202G标准。 - 网络接口:基于Micrel KSZ8841-PMQLI控制器,支持多达两个自动检测的10BaseT/100BaseTX端口。 - 活动指示:每个以太网端口都有板载Link/Activity和Speed状态LED,以及外部LED的接口。
功能详解: - VL-EPM-E2提供了两个10/100以太网端口,具有自动协商功能,简化了配置过程。每个以太网端口可以独立配置为不同的子网。 - 提供了标准RJ45输出连接器或适用于高冲击或振动环境的锁扣式连接器。 - 板载LED提供每个以太网端口的Link/Activity和Speed状态,还提供了外部LED支持的额外接口。
应用信息: VL-EPM-E2适用于需要高可靠性和长期可用性的OEM应用,从应用设计支持到5年以上的生产寿命保证,VL-EPM-E2提供了一个耐用的嵌入式计算机解决方案,拥有出色的拥有成本。VL-EPM-E2按照最高质量标准制造和测试,完全符合RoHS标准,并且提供定制服务。
封装信息: - 板尺寸:符合PC/104-Plus标准,尺寸为90 mm x 96 mm (3.55 x 3.78英寸)。 - 电源需求:最大+5V @0.52A (2.6W)。 - 制造标准:IPC-A-610 Class 2合规。 - 环境:存储温度-40至+85°C,湿度小于95%,非凝结。 - 抗震动:MIL-STD-202G, Method 204, Modified Condition A: 2g恒定加速度从5到500 Hz,每个轴20分钟。 - 抗冲击:MIL-STD-202G, Method 213B, Condition G: 20g半正弦波,每个轴11毫秒。
VL-EPM-E2D 价格&库存
很抱歉,暂时无法提供与“VL-EPM-E2D”相匹配的价格&库存,您可以联系我们找货
VL-EPM-E2D
  • 1+2465.083101+318.61004
库存:2
