VL-MPEE-FW1E
VL-MPEE-FW1E
    VERSALOGIC
    1394 FIREWIRE MODULE
VL-MPEE-FW1E 数据手册
Product Data Sheet FireWire Expansion Mini PCIe Module VL-MPEe-FW1 Actual Size! Overview Highlights The VL-MPEe-FW1 is an extremely small and rugged FireWire module based on the industry-standard Mini PCIe module format. This Mini PCIe module provides an easy and economical way to add FireWire 1394b to an embedded computing solution. This module supports one FireWire 800 (1394b) and one FireWire 400 (1394a) channel operating at extended temperature. ƒƒ 2-channels of 1394 FireWire 6-pin connector FireWire 400 latching. 9-pin connector FireWire 800 right angle. ƒƒ Mini PCIe Module Format Small and flexible. ƒƒ Standard Operating Systems Drivers (Windows, Linux) Typically no additional software drivers needed. This I/O board is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, and Linux. As with all VersaLogic products, the VL-MPEe-FW1 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the VL-MPEe-FW1 provides a durable I/O expansion with an excellent cost of ownership. ƒƒ Industrial Temperature -40° to +85°C operation for harsh environments. ƒƒ PCIe Signaling Compatible with Mini PCIe sockets. ƒƒ MIL-STD-202G Qualified for high shock / vibration environments. ƒƒ 5+ Year production life guarantee C O R P O R A T I O N FireWire Expansion Product Data Sheet Specifications General Board Size Power Requirements Manufacturing Standards Regulatory Compliance Mini PCIe Signal Type Mini PCIe module (full size): 30 mm x 50.95 mm x 6.39 mm 3.3V ±5% @ 0.8W Typical (supplied by the Mini PCIe socket) IPC-A-610 Class 2 RoHS PCI Express Base Specification, Rev 1.1 Environmental Operating Temperature Storage Temperature Altitude Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Mechanical Shock † -40° to +85°C Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.).* The ambient air surrounding the MPEe-FW1 must be at or below +85ºC. -40° to +85°C Operating * To 4,570m (15,000 ft.) Storage To 12,000m (40,000 ft.) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis. MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis. MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 msec. duration per axis. Device I/O Firewire Interface Firewire Connectors # Aux Power 12V 1-channel of FireWire 400 (1394a) 1-channel of FireWire 800 (1394b) One standard 9-pin right angle Firewire 800 connector One 6-pin positive latching 1.5mm pitch connector One 4-pin positive latching 1.5mm pitch connector Ordering Information Model VL-MPEe-FW1E Function 1394 FireWire Module Operating Temp. -40° to +85°C Accessories Part Number Description PC/104 Mini PCIe Carrier Adapters VL-EPM-P2E PC/104-Plus to Dual mini PCIe socket adapter VL-EPMp-P2E PCI-104 to Dual mini PCIe socket adapter Cables VL-CBR-0602 6-pin Latching to 6-pin Firewire 400 Cable, 1.5 m VL-CBR-0403 4-pin 12V Power Cable, 12” Hardware VL-HDW-108 Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs VL-HDW-110 Mini PCIe module hold-down screws (10) for use with 2.0 mm standoffs Other VersaLogic Mini PCIe Modules Model VL-MPEe-A1E VL-MPEe-A2E VL-MPEe-E3E VL-MPEe-U2E VL-MPEe-V5E VL-MPEs-F1Exx VL-MPEs-S3E VL-MPEu-G2E Function Analog input (12-bit resolution) Analog input (16-bit resolution) Gigabit Ethernet adapter Four Serial ports. Twelve GPIO lines Video Display Adapter. VGA and LVDS Interfaces. mSATA drive (4/16/32 GB) SATA adapter GPS receiver Signaling PCIe PCIe PCIe PCIe PCIe SATA SATA USB Call VersaLogic Sales at (503) 747-2261 for more information! Software Drivers ¥ Mini PCIe Module Compatible with most x86 operating systems including Windows, Windows Embedded, and Linux. ¥ Win 7 driver needed to run both ports concurrently - available on VersaLogic.com. # ESD Clamp and Live-Insertion Detect on both ports, turns cable power off during a hot-plug error condition. * For extended altitude information contact VersaLogic Sales Dept. † MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. All other trademarks are the property of their respective owners. Tailor a Module to Your Exact Requirements Product customization is available, even in low quantities. Options include conformal coating, application-specific testing, BOM revision locks, special labeling, and more. Mini PCIe Modules 12/24/15 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | www.VersaLogic.com C O R P O R A T I O N
VL-MPEE-FW1E
物料型号: - 型号:VL-MPEe-FW1E - 功能:1394 FireWire Module - 工作温度:-40°至+85°C
器件简介: VL-MPEe-FW1是一款基于行业标准的Mini PCIe模块格式的极小且坚固的FireWire模块。该Mini PCIe模块提供了一种简单且经济的方法来为嵌入式计算解决方案添加FireWire 1394b。该模块支持一个FireWire 800 (1394b)和一个FireWire 400 (1394a)通道,在扩展温度下运行。
引脚分配: - FireWire 400:6针连接器,具有锁定功能。 - FireWire 800:9针连接器,直角设计。
参数特性: - 支持工业温度范围,适用于恶劣环境。 - 与Mini PCIe插座兼容。 - 支持多种流行的x86操作系统,包括Windows、Windows Embedded和Linux。 - 符合IPC-A-610 Class 2制造标准和RoHS环保标准。 - 遵循PCI Express Base Specification, Rev 1.1信号类型。
功能详解: - 提供两个1394 FireWire通道,包括一个FireWire 400和一个FireWire 800。 - 支持高达5年以上的生产寿命保证。 - 通常不需要额外的软件驱动程序,与标准操作系统兼容。
应用信息: 该模块适用于需要高可靠性和长期可用性的OEM应用,从应用设计支持到5年以上的生产寿命保证,VL-MPEe-FW1提供了耐用的I/O扩展和出色的拥有成本。
封装信息: - 板尺寸:Mini PCIe模块(全尺寸):30 mm x 50.95mm x 6.39 mm - 电源要求:3.3V +5% @0.8W典型值(由Mini PCIe插座供电)
VL-MPEE-FW1E 价格&库存
很抱歉,暂时无法提供与“VL-MPEE-FW1E”相匹配的价格&库存,您可以联系我们找货
VL-MPEE-FW1E
  • 1+1410.557671+182.23306
库存:7
