VL-EPMs-E1
SUMIT™-104 Dual Gigabit Ethernet Module
Dual gigabit Ethernet
PCI Express Mini Card socket
SUMIT and PC/104™ expansion
Extended temp. operation
Highlights
SUMIT and PC/104 Compatible
Supports SUMIT and ISA expansion on a compact, highly
rugged format.
Network Support
Dual gigabit Ethernet ports for high-bandwidth applications or
system redundancy.
PCI Express Mini Card Socket
High-speed, small form factor cards enable additional
wireless functionality.
Extended Temperature Operation
-40° to +85°C operation for harsh environments.
MIL-STD-202G
Qualified for high shock/vibration environments.
Overview
The VL-EPMs-E1 is a SUMIT-based dual gigabit Ethernet (GbE) expansion module with a
PCI Express Mini Card socket. This versatile expansion module is the ideal solution for highbandwidth and/or wireless network applications in a wide range of applications including
defense, aerospace, homeland security, and industrial automation where a small footprint and
extended temperature operation are crucial design factors.
Based on the industry standard PC/104 footprint, the VL-EPMs-E1 features the SUMIT expansion
interface. SUMIT provides a stackable expansion interface that supports both high- and lowspeed signals. This simplifies adding both standard and custom I/O boards to the system. The
VL-EPMs-E1 expansion interfaces include PCIe, USB, LPC, SPI, SMBus, as well as optional
ISA bus support for PC/104 modules.
Like all VersaLogic products, the VL-EPMs-E1 is designed to support OEM applications
where high reliability and long-term availability are required. From application design-in to 5+
guaranteed years of production life, the VL-EPMs-E1 provides a durable embedded computer
solution with an exceptional cost of ownership. The E1 is manufactured and tested to the
highest quality standards and is fully RoHS compliant. Customization is available, even in
low OEM quantities.
Details
The VL-EPMs-E1 is a SUMIT-104 expansion module that provides two gigabit Ethernet channels
based on Intel ® 82574L controllers. Additional system expansion and communications flexibility
is available via the on-board PCI Express Mini Cards socket. The socket is compatible with:
802.11a/b/g Wi-Fi network adapters
GPS radio modules (for global location and precision time stamping)
3G modems
Solid-state flash drives (SSDs)
This GbE module offers low power consumption (3.5 watts) and low thermal dissipation for
heat sensitive applications, as well as transient voltage suppression (TVS) on the Ethernet
connections to protect from power spikes and surges. With an Ethernet buffer of 16 KB RAM,
data is easily stored and retrieved. Extended temperature operation provides reliability in
harsh environments.
VersaLogic Corporation • 12100 SW Tualatin Rd., Tualatin, OR 97062 • (503) 747-2261 • Info@VersaLogic.com • www.VersaLogic.com
VL-EPMs-E1
SPECIF ICATIONS
The VL-EPMs-E1 works with the entire family of industry-standard SUMITbased computer and add-on boards.
General
The VL-EPMs-E1 is compatible with a variety of popular operating systems,
including Windows, Windows Embedded, Linux, VxWorks, and QNX.
Environmental
Board Size
Power Requirements
RoHS
Operating Temperature
Storage Temperature
Thermal Shock
Humidity
Vibration, Sinusoidal
Sweep
Vibration, Random
Mechanical Shock
VL-EPMs-E1b (Top)
VL-EPMs-E1b (Bottom)
Ordering Information
VL-EPMs-E1a........................................Dual GbE, SUMIT-A connector
VL-EPMs-E1b.......................... Dual GbE, SUMIT-AB + ISA connectors
Accessories
VL-CBR-0201........................................... Wi-Fi antenna adapter cable
VL-CBR-ANT01............................................... Wi-Fi (802.11n) antenna
VL-HDW-105...............................0.6” standoff package (metric thread)
VL-HDW-106.............................0.6” standoff package (English thread)
VL-HDW-107.............................................. Metric screw and washer kit
VL-HDW-203............................................. PC/104 extractor tool, metal
VL-WD10-CBN....................PCI Express Mini Card: 802.11g/n wireless
Network
Interface
Ethernet*
Device I/O
Software
Operating Systems
Network Boot Option
PC/104 standard: 90 mm x 96 mm (3.55” x 3.78”)
+5 VDC: 3.5W
Compliant
-40° to +85°C
-40° to +85°C
5°C/min. over operating temperature
Less than 95%, noncondensing
MIL-STD-202G, Method 204, Modified Condition A:
2g constant acceleration from 5 to 500 Hz, 20
minutes per axis
MIL-STD-202G, Method 214A, Condition A:
5.35g rms, 5 minutes per axis
MIL-STD-202G, Method 213B, Condition G:
20g half-sine, 11 ms duration per axis
Dual autodetect 10BaseT/100BaseTX/
1000BaseT ports based on Intel 82574L
Intel boot agent (downloadable): supports PXE
protocol
Latching PCI Express Mini Card interface
with retention screws. PCI Express Mini Card
Specification 1.2 compliant.
Compatible with most x86 operating systems,
VxWorks, and QNX
* TVS protected port (enhanced ESD protection)
Data represents standard operation at +25°C with +5V supply unless otherwise noted. Specifications are
subject to change without notification. PC/104 is a trademark of the PC/104 Consortium. SUMIT is a trademark
of the SFF-SIG. All other trademarks are the property of their respective owners.
SUMIT Resources Needed
Form Factor: SUMIT-104
SUMIT-A
PCIe x1
1
PCIe x4
USB
1
ExpressCard
LPC
SPI / µWire
SMBus / I 2 C
+12V
+5V
ü
+5Vsb
+3.3V
SUMIT-B*
ü
* Optional
02/20/13
很抱歉,暂时无法提供与“VL-EPMS-E1A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2399.720721+311.04950
