VL-EPM-P2E
VL-EPM-P2E
    VERSALOGIC
    PC/104-PLUS, ET
VL-EPM-P2E 数据手册
C O R P O R A T I O VL-EPM-P2 N PC/104™ Dual Mini PCIe Adapter ƒƒ Dual Mini PCIe sockets ƒƒ Full industrial temperature operation ƒƒ MIL-STD-202G shock / vibe Overview Highlights Mini PCIe Sockets Two Mini PCIe sockets support A/D convertors, Ethernet, Wi-Fi modems, MIL-STD-1553, solid-state storage, and other plug-in devices. The VL-EPMx-P2 expansion module provides dual Mini PCIe socket expansion for any PC/104-Plus or PCI-104 embedded system. With a small footprint and industrial temperature operation, the VL-EPMx-P2 provides versatile PCI Express ® Mini Card expansion for small form factor embedded systems. MIL-STD-202G As with all VersaLogic products, the VL-EPMx-P2 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the VL-EPMx-P2 provides a durable embedded computer solution with an excellent cost of ownership. The VL-EPMx-P2 is fully RoHS compliant. PC/104 Form Factor Details Industrial Temperature -40° to +85°C operation for harsh environments. Qualified for high shock / vibration environments. Rugged industry-standard form factor. Based on PC/104 standards, the VL-EPM-P2 supports PCI and ISA stackable expansion buses on an industry-standard 90 mm x 96 mm (3.55” x 3.78”) expansion module. The VL-EPMp-P2 supports PCI stackable expansion. Using a reverse PCI to PCI Express bridge, the VL-EPMx-P2 provides off-the-shelf PC/104-Plus and PCI-104 systems with full access to high-speed Mini PCIe devices. The two on-board Mini PCIe sockets accommodate plug-in modules such as A/D convertors, Ethernet, Wi-Fi modems, MIL-STD-1553, solid-state storage, and other devices. The VL-EPMx-P2 is compatible with full-sized Mini PCIe cards. Half-sized Mini PCIe cards can be supported by special order. Four on-board LEDs provide Activity status for each Mini PCIe socket. Designed for full industrial temperature (-40° to +85°C) operation, the rugged VL-EPMx-P2 meets MIL-STD-202G specifications for mechanical shock and vibration for use in harsh environments. Product customization is available, even in low OEM quantities. Customization options include conformal coating, revision locks, custom labeling, customized testing and screening, etc. C O R P O R A T I O N VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com C O R P O R A T I O VL-EPM-P2 PC/104 Dual Mini PCIe Adapter N SPECIF ICATIONS Ordering Information Model VL-EPM-P2E VL-EPMp-P2E* Mini PCIe Sockets 2 2 Operating Temp. -40° to +85°C -40° to +85°C Stackable Bus PCI, ISA PCI General * Special Order Product – Contact VersaLogic Sales for minimum order quantities and lead time. Environmental Accessories Part Number Hardware VL-HDW-105 VL-HDW-106 VL-HDW-107 Miscellaneous VL-CBR-ANT-01 VL-HDW-203 Description 0.6” standoff package (metric thread) 0.6” standoff package (English thread) Mini PCIe card hardware kit (metric thread) RoHS Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Vibration, Random 802.11n Wi-Fi antenna PC/104 extractor tool (metal) Mechanical Shock Mini PCIe Socket Expansion Modules Part Number Network VL-MPEe-W2E Description Form Factor Wi-Fi 802.11 a/b/g/n Mini PCIe VL-MPEe-E3E Gigabit Ethernet adapter Mini PCIe Serial I/O VL-MPEe-U2E Quad serial plus twelve GPIOs Analog & Digital I/O VL-MPEe-A1E Analog input (12-bit resolution) VL-MPEe-A2E Analog input (16-bit resolution) Video VL-MPEe-V5E VGA and LVDS Interface Board Size Power Requirements  (+5V) † Stackable Bus Mini PCIe Mini PCIe Mini PCIe Mini PCIe General Compatibility Status Indicators PC/104 standard: 90 mm x 96 mm (3.55” x 3.78”) With PCIe Wi-Fi (Idle) 4.55W With PCIe Wi-Fi (Max.) 4.71W VL-EPM-P2 PC/104-Plus: PCI Bus, ISA Bus (pass-through only) VL-EPMp-P2 PCI-104: PCI Bus Compliant -40° to +85°C -40° to +85°C None (free air within operating temperature range) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Two Mini PCIe sockets support A/D converters, Ethernet, Wi-Fi modems, MIL-STD-1553, nonvolatile flash data storage, and other plug-in modules Compatible with full- and half-sized Mini PCIe cards. Supports standard PCIe signaling. USB and SATA signaling not supported. On-board LEDs indicate card status for each socket † Power specifications represent typical power draw at +25°C with +5V supply running Windows XP with an Intel 5300 Wi-Fi Link card. Maximum power is measured during file transfer over Wi-Fi. Results will vary depending upon Mini PCIe card in use. Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. PC/104, PCI-104 and PC/104-Plus are trademarks of the PC/104 Consortium. All other trademarks are the property of their respective owners. 02/28/22 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPM-P2E 价格&库存
很抱歉,暂时无法提供与“VL-EPM-P2E”相匹配的价格&库存,您可以联系我们找货
VL-EPM-P2E
  • 1+2968.544411+385.76992
库存:16
