VL-EPMS-U1B
VL-EPMS-U1B
    VERSALOGIC
    6CHANSERIALI/OCARDSUMIT
VL-EPMS-U1B 数据手册
VL-EPMs-U1 SUMIT™-104 Serial Communications + GPS Receiver Highlights SUMIT Compatible Highly rugged SUMIT-104 format. Serial I/O Up to six serial ports enable communication with multiple peripheral devices. On-board GPS Receiver Optional 12-channel GPS module supports NMEA 0183, TSIP, TAIP, and DGPS protocols. Extended Temperature Operation -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock/vibration environments. ƒƒ Serial I/O (up to 6 ports) ƒƒ Extended temp. operation ƒƒ GPS versions ƒƒ MIL-STD-202G shock/vibe ƒƒ ISA versions ƒƒ RoHS compliant Overview The VL-EPMs-U1 module provides advanced serial communications and Global Positioning System (GPS) capabilities in embedded systems. Based on the SUMIT-104 form factor, the VL-EPMs-U1 supports SUMIT and PC/104™ stackable expansion buses. With a compact rugged form factor and low power consumption (700 mW typ.), the VL-EPMs-U1 is well suited to size, weight, and power constrained applications. A full industrial temperature rating and certification to MIL-STD-202G specifications for shock and vibration ensure reliable operation in harsh, mobile, and/or remote environments. Like all VersaLogic products, the VL-EPMs-U1 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the VL-EPMs-U1 provides a durable embedded computer solution with an excellent cost of ownership. The VL-EPMs-U1 is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. Details With up to six serial ports, the VL-EPMs-U1 provides traditional hardwired serial I/O functions for legacy communications. RS-232 serial ports operate in 4-wire mode at 115 Kbps; RS-485 mode adds auto-direction control and high-speed 460 Kbps transmission. When equipped with the optional Trimble® Lassen® iQ GPS receiver, the VL-EPMs-U1 delivers complete position, velocity, and time (PVT) data for use in host applications. The Lassen iQ provides simultaneous 12-channel operation for stable satellite tracking and aided GPS startup for fast initial signal acquisition. Dual GPS signal sensitivity modes enable reliable tracking in difficult environments with weak satellite signals. GPS data is available in popular NMEA, TSIP, TAIP, or DGPS protocols. The GPS data is accessed through two on-board serial ports. An antenna with interface cabling is available for evaluation, testing, and software development. Designed for full industrial (-40° to +85°C) temperature operation; the VL-EPMs-U1 is built to withstand thermal extremes and meets MIL-STD-202G specifications for mechanical shock and vibration. Transient voltage suppression (TVS) devices on the serial port I/O lines provide enhanced electrostatic discharge (ESD) protection for the system. Fault protection on the GPS antenna guards against open and short circuits. Based on an industry standard 16C550 I/O controller, the VL-EPMs-U1 is fully compatible with a variety of popular operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX using standard serial I/O software drivers. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com VL-EPMs-U1 SUMIT-104 Serial Communications + GPS Module SPECIF ICATIONS General Environmental VL-EPMs-U1D (Top) Ordering Information Model VL-EPMs-U1A VL-EPMs-U1B VL-EPMs-U1C VL-EPMs-U1D* VL-EPMs-U1E VL-EPMs-U1F* VL-EPMs-U1G* VL-EPMs-U1H* Serial Channels 4 6 4 6 2 4 2 4 Board Size Power Requirements Stackable Bus RoHS Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Vibration, Random GPS – – – – Y Y Y Y Stackable Bus SUMIT-A SUMIT-A SUMIT-AB + ISA[b] SUMIT-AB + ISA[b] SUMIT-A SUMIT-A SUMIT-AB + ISA[b] SUMIT-AB + ISA[b] Mechanical Shock Device I/O COM 1 / 2 Interface [c] COM 3 / 4 Interface [c / d] COM 5 / 6 Interface [c] GPS [a] Module Update Rate Accuracy * Special order Accessories Optional Accessories VL-CBR-2001 12” 20-pin socket / (2) DB-9M cable VL-CBR-ANT02 GPS antenna VL-HDW-105 0.6” standoff package (metric thread) VL-HDW-106 0.6” standoff package (English thread) PC/104 extractor tool, metal VL-HDW-203 Acquisition Protocols Antenna[f] Software Operating Systems PC/104 standard: 90 mm x 96 mm (3.55” x 3.78”) +5V @ 140 mA (700 mW) SUMIT-104: SUMIT-A, SUMIT-B [a ], ISA [a / b] Compliant -40° to +85°C -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis RS-232. 16C550 compatible. 115 Kbps. RS-232/422/485 selectable. 16C550 compatible. 460 Kbps. RS-232/422/485 selectable. 16C550 compatible. 460 Kbps. Trimble Lassen iQ GPS module: L1 (1575.42 MHz) frequency, C/A code, 12-channel, continuous tracking receiver TSIP @ 1 Hz; NMEA @ 1 Hz; TAIP @ 1 Hz Horizontal: < 5 meters (50%), < 8 meters (90%) Altitude: < 10 meters (50%), < 16 meters (90%) Velocity: 0.06 m/s PPS (static): ±50 ns Reacquisition: < 2 sec (90%) Hot Start[e]: < 10 sec (50%), < 13 sec (90%) NMEA 0183 v3.0, TSIP, TAIP, and DGPS (RTCM SC-104) Supports active antennas with HFL, MCX, or SMA connectors Compatible with most x86 operating systems, including Windows, Windows Embedded, Linux, VxWorks, and QNX [a] Optional.  [b] Pass-through only.  [c] TVS protected port (enhanced ESD protection).  [d] Serial ports 3 and 4 are optionally utilized by the GPS receiver.  [e] Hot start implies last position, time, almanac, and ephemeris are saved by backup power.  [f] Fault protected (open and short circuit). Data represents standard operation at +25°C with +5V supply unless otherwise noted. Specifications are subject to change without notification. PC/104 is a trademark of the PC/104 Consortium. SUMIT is a trademark of the SFF-SIG. Trimble and Lassen are registered trademarks of Trimble Navigation Ltd. All other trademarks are the property of their respective owners. SUMIT Resources Form Factor: SUMIT-104 (Legacy Type 1) SUMIT-A SUMIT-B [a] PCIe x1 – – PCIe x4 – USB – ExpressCard – LPC 1 SPI / µWire – SMBus / I 2 C – +12V – +5V ü ü – – +5Vsb +3.3V – – 02/20/13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPMS-U1B 价格&库存
很抱歉,暂时无法提供与“VL-EPMS-U1B”相匹配的价格&库存,您可以联系我们找货
