VL-EPMS-M1C
VL-EPMS-M1C
    VERSALOGIC
    Module
    SATA,MSATAANDUSBMODULE
VL-EPMS-M1C 数据手册
VL-EPMs-M1 SUMIT™ USB / SATA™ / PCIe / mSATA™ Adapter ƒƒ PCIe Mini Card socket (optional) ƒƒ USB 2.0 (3 or 4 ports) ƒƒ SATA (1 or 2 drives) ƒƒ mSATA flash site (optional) ƒƒ Industrial temp. operation ƒƒ MIL-STD-202G shock / vibe Highlights PCIe Mini Card Socket (optional) Supports Wi-Fi modems, GPS receivers, flash data storage, and other plug-in devices. USB Up to four USB 2.0 ports support keyboard, mouse, and other devices. SATA Supports bootable SATA hard drive and mSATA flash storage options. Industrial Temperature -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock / vibration environments. SUMIT  Rugged industry-standard format. Overview The VL-EPMs-M1 expansion modules provide access to a variety of I/O ports in SUMIT-based embedded systems. With a full industrial temperature rating and extensive ruggedization, the VLEPMs-M1 is an ideal solution for SUMIT-based applications that require USB, SATA, PCI Express, and mSATA capabilities. See the Ordering Information section for available models and the port combinations that they provide. The VL-EPMs-M1 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to the 5+ year production life guarantee, the VL-EPMs-M1 provides a rugged embedded computer solution with an excellent cost of ownership. The VL-EPMs-M1 is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. Details Based on the SUMIT standard, the VL-EPMs-M1 supports SUMIT and PC/104™ stackable expansion buses on an industry-standard 90 mm x 96 mm (3.55” x 3.78”) expansion module. ƒƒ The VL-EPMs-M1 provides up to four USB ports: two via standard Type A connectors and two via a 10-pin connector. ƒƒ The on-board SATA controller supports two SATA drives. Utilizing a standard latching right angle SATA connector, the VL-EPMs-M1 is compatible with traditional rotating drives, as well as solidstate drives (SSDs). The on-board BIOS extension supports system booting from a SATA device. ƒƒ An optional mSATA interface provides high-throughput, low-latency flash storage capabilities utilizing small form factor mSATA SSDs. ƒƒ An optional PCI Express Mini Card socket accommodates plug-in Wi-Fi modems, GPS receivers, flash data storage, and other cards. Designed for full industrial (-40° to +85°C) temperature operation, the VL-EPMs-M1 is built to withstand thermal extremes. The VL-EPMs-M1 boards also meet MIL-STD-202G specifications for mechanical shock and vibration for use in harsh environments. Transient voltage suppression (TVS) devices on all USB channels provide enhanced electrostatic discharge (ESD) protection for the system. The VL-EPMs-M1 is compatible with a variety of popular operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX using standard software drivers. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com VL-EPMs-M1 SUMIT USB / SATA / PCIe / mSATA Adapter SPECIF ICATIONS Ordering Information Model General USB Type A Conn. USB Pin- SATA Header Ports Conn. PCIe mSATA Stackable Bus Mini Card Site Connectors Socket VL-EPMs-M1A VL-EPMs-M1B 2 1 2 2 2 2 – Y – – VL-EPMs-M1C 2 2 1 – Y SUMIT-A SUMIT-AB, ISA SUMIT-A Environmental Accessories Part Number Description Cables VL-CBR-0201 Wi-Fi antenna interface cable VL-CBR-0401 6.25” ATX to SATA cable VL-CBR-0701 19.75” SATA cable VL-CBR-0702 19.75” SATA cable, latching VL-CBR-1013 Dual USB transition cable Drives VL-HDS35-xxx 3.5” hard drive (SATA) SSDs VL-F29-xxxx mSATA module (SATA) PCIe Mini Cards VL-WD10-CBN 802.11 g / n Wi-Fi transceiver module Antennas VL-CBR-ANT-01 802.11 n Wi-Fi antenna Mounting Hardware VL-HDW-105 0.6” standoff package (metric thread) VL-HDW-106 0.6” standoff package (English thread) PCIe Mini Card / mSATA hardware kit (metric thread) VL-HDW-107 Miscellaneous VL-HDW-203 PC/104 extractor tool, metal Board Size Power Requirements  (+5V) * Stackable Bus Manufacturing Standards RoHS Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Vibration, Random Mechanical Shock Mass Storage Hard Drive Device I/O Flash USB † ‡ Other I/O Software PCI Express Mini Card Socket (optional) Operating Systems PC/104 standard: 90 mm x 96 mm (3.55” x 3.78”) Idle With USB 1.15W 3.36W With Dual SATA 12.54W With PCIe Wi-Fi 4.16W SUMIT, ISA (optional, pass-through only) IPC-A-610 Class 2 compliant Compliant -40° to +85°C -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Two SATA (Revision 2.0) ports. Bootable. Latching right angle SATA connectors. Optional PCIe Mini Card socket or mSATA interface Model USB 2.0 / 1.1 Ports VL-EPMs-M1A / C 4 VL-EPMs-M1B 3 Supports Wi-Fi modems, GPS receivers, non-volatile flash data storage, and other plug-in modules Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX using standard software drivers ** Power specifications represent typical power draw at +25°C with +5V supply running Windows XP ††TVS protected port (enhanced ESD protection) ‡‡Power pins on this port are overload protected Specifications are subject to change without notification. SUMIT is a trademark of the SFF-SIG. PC/104 is a trademark of the PC/104 Consortium. SATA and mSATA are trademarks of the Serial ATA International Organization. All other trademarks are the property of their respective owners. SUMIT Resources Form Factor: SUMIT-ISM (Legacy Type 1) SUMIT-A SUMIT-B PCIe x1 1 1 PCIe x4 – USB 4 ExpressCard – LPC – SPI / µWire – SMBus / I 2 C SMBus +12V – +5V ü ü +5Vsb – – +3.3V – – SUMIT-A: Bottom only on VL-EPMs-M1A / C SUMIT-AB: Top and bottom on VL-EPMs-M1B SMBus: VL-EPMs-M1B only 02/20/13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPMS-M1C 价格&库存
很抱歉,暂时无法提供与“VL-EPMS-M1C”相匹配的价格&库存,您可以联系我们找货
