VL-EPHS-S1E
VL-EPHS-S1E
    VERSALOGIC
    SUMIT-MICRO, ET, 2 SATA
VL-EPHS-S1E 数据手册
VL-EPHs-S1 SUMIT-micro™ SATA Adapter ƒƒ Supports two SATA drives ƒƒ Standard and RAID modes ƒƒ Full industrial temperature operation ƒƒ MIL-STD-202G shock/vibe Highlights SUMIT-micro Form Factor Small footprint board expands any SUMIT™-based system. SATA Interface Supports two SATA drives and includes RAID 0 (Fast) and RAID 1 (Safe) operation. Industrial Temperature -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock/vibration environments. Overview The VL-EPHs-S1 expansion module provides SATA interface capabilities for any SUMIT-based embedded system. With a small footprint, simplified interface, and extensive ruggedization, the VL-EPHs-S1 is an ideal solution for all SUMIT systems that require SATA capabilities. The VL-EPHs-S1 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to the 5+ year production life guarantee, the VL-EPHs-S1 provides a rugged embedded computer solution with an excellent cost of ownership. The VL-EPHs-S1 is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. Details The VL-EPHs-S1 expansion module is a 90 mm x 32 mm (3.54” x 1.26”) mezzanine “SUMIT-micro” card that provides SATA signals via the PCIe lane of the SUMIT-A connector. It mounts to the top of the SUMIT stack using two hardware standoffs. The on-board SATA controller supports two SATA drives in normal, RAID 0 (Fast), or RAID 1 (Safe) configuration. The two standard latching SATA connectors are compatible with traditional rotating drives, as well as solid-state SATA drives. An EEPROM BIOS extension enables booting from a SATA device. Designed for full industrial (-40° to +85°C) temperature operation; the VL-EPHs-S1 meets MIL-STD202G specifications for mechanical shock and vibration for use in harsh environments. The VL-EPHs-S1 is compatible with a variety of popular operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com VL-EPHs-S1 SUMIT-micro SATA Adapter SPECIF ICATIONS Ordering Information Model VL-EPHs-S1E SATA Ports 2 General Operating Temp. -40° to +85°C Accessories Part Number Description Cables VL-CBR-0701 19.75” SATA cable VL-CBR-0702 19.75” SATA cable, latching Drives VL-HDS35-xxx 3.5” hard drive (SATA) Mounting Hardware VL-HDW-105 0.6” standoff package (metric thread) VL-HDW-106 0.6” standoff package (English thread) Miscellaneous VL-HDW-201 Board extraction tool Stackable Bus SUMIT Environmental Board Size Power Requirements * Stackable Bus Manufacturing Standards RoHS Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Vibration, Random Mechanical Shock Mass Storage SATA Interface Software BIOS Operating Systems SUMIT-micro: 32 mm x 90 mm (1.26” x 3.54”) +5V@0.21A (1W) typ. (via SUMIT connector) SUMIT (top of stack only) IPC-A-610 Class 2 compliant RoHS (2002/95/CE) compliant -40° to +85°C -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Two SATA (Revision 2.0) ports. Bootable via BIOS extension. Latching right angle SATA connectors. Support for RAID 0 (Fast) and RAID 1 (Safe). EEPROM BIOS extension to enable booting from a SATA device Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX ** Power specifications represent typical power draw at +25°C with +5V supply running Windows XP Specifications are subject to change without notification. SUMIT is a trademark of the SFF-SIG. SUMIT-micro is a trademark of VersaLogic Corp. All other trademarks are the property of their respective owners. SUMIT Resources Form Factor: SUMIT-micro SUMIT-A PCIe x1 1 PCIe x4 USB – ExpressCard – LPC – SPI / µWire – SMBus / I 2 C – +12V – +5V ü – +5Vsb +3.3V – SUMIT-B 02/15/13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPHS-S1E
物料型号:VL-EPHs-S1
器件简介:VERSALOGIC公司生产的SUMIT-micro™ SATA适配器,支持两个SATA驱动器,包括标准和RAID模式,适用于全工业温度范围,并且符合MIL-STD-202G的抗冲击和抗振动标准。
引脚分配:该模块是一个90 mm x 32 mm (3.54” x 1.26”)的“SUMIT-micro”卡,通过SUMIT-A连接器的PCIe通道提供SATA信号。
参数特性: - 支持两个SATA驱动器,包括RAID 0(快速)和RAID 1(安全)操作。
- 工业温度范围:-40°C至+85°C。
- 符合MIL-STD-202G标准,适用于高冲击/振动环境。
- 功耗:典型+5V@0.21A(1W)。
功能详解: - 提供SATA接口能力,适用于任何基于SUMIT的嵌入式系统。
- 支持OEM应用,要求高可靠性和长期可用性。
- 兼容多种流行的操作系统,包括Windows、Windows Embedded、Linux、VxWorks和QNX。
应用信息:适用于需要SATA功能的SUMIT系统,特别是在恶劣环境下需要高可靠性和长期可用性的OEM应用。
封装信息:SUMIT-micro封装,尺寸为32 mm x 90 mm (1.26” x 3.54”),通过SUMIT堆叠顶部的两个硬件支撑点安装。
VL-EPHS-S1E 价格&库存
很抱歉,暂时无法提供与“VL-EPHS-S1E”相匹配的价格&库存,您可以联系我们找货
