VL-EPHS-P1E
VL-EPHS-P1E
    VERSALOGIC
    SUMIT TO MINI PCIE
VL-EPHS-P1E 数据手册
VL-EPHs-P1 SUMIT-micro™ Mini PCIe Adapter ƒƒ PCIe Mini Card socket ƒƒ Full industrial temperature operation ƒƒ MIL-STD-202G shock / vibe Highlights PCIe Mini Card Socket Supports Wi-Fi modems, GPS receivers, MIL-STD-1553, solid-state storage, and other plug-in devices. Industrial Temperature -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock / vibration environments. SUMIT-micro Form Factor Small footprint board expands any SUMIT™-based system. Overview The VL-EPHs-P1 expansion module provides Mini PCIe socket expansion for any SUMIT-based embedded system. With a small footprint, simplified interface, and extensive ruggedization, the cost-effective VL-EPHs-P1 provides versatile PCI Express® Mini Card expansion for small form factor embedded systems. As with all VersaLogic products, the VL-EPHs-P1 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the VL-EPHs-P1 provides a durable embedded computer solution with an excellent cost of ownership. The VL-EPHs-P1 is fully RoHS compliant. Details The VL-EPHs-P1 expansion module is a 90 mm x 32 mm (3.54” x 1.26”) SUMIT-micro format card that utilizes the PCIe and USB lanes of the SUMIT-A connector to provide a Mini PCIe socket for embedded system expansion. The card mounts to the top of the SUMIT stack and is secured via two mounting holes using standard hardware standoffs. The versatile PCIe Mini Card socket accommodates plug-in Wi-Fi modems, GPS receivers, MIL-STD-1553, solid-state storage, and other plug-in devices. The VL-EPHs-P1 is compatible with full-sized Mini PCIe cards and supports both USB and PCIe connectivity. Half-sized Mini PCIe cards can be supported by special order. Four on-board LEDs provide Activity status for the Mini Card socket. Designed for full industrial temperature (-40° to +85°C) operation, the rugged VL-EPHs-P1 meets MIL-STD-202G specifications for mechanical shock and vibration for use in harsh environments. Product customization is available, even in low OEM quantities. Customization options include conformal coating, revision locks, custom labeling, customized testing and screening, etc. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com VL-EPHs-P1 SUMIT-micro Mini PCIe Adapter SPECIF ICATIONS General Board Size SUMIT-micro: 32 mm x 90 mm (1.26” x 3.54”) With PCIe Wi-Fi (Max.) Power Requirements (+5V) * With PCIe Wi-Fi (Idle) 1.25W Environmental VL-EPHs-P1E (Top) Ordering Information Model VL-EPHs-P1E Mini PCIe Sockets 1 Operating Temp. -40° to +85°C Stackable Bus SUMIT Vibration, Random Mechanical Shock Accessories Part Number Cables VL-CBR-0201 Mini PCIe Cards VL-WD10-CBN Hardware VL-HDW-105 VL-HDW-106 VL-HDW-107 Miscellaneous VL-CBR-ANT-01 Stackable Bus RoHS Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Description Wi-Fi antenna interface cable Mini PCIe Socket General Compatibility 802.11g/n Wi-Fi transceiver module Status Indicators 1.65W SUMIT (top of stack only) RoHS (2002/95/CE) compliant -40° to +85°C -40° to +85°C None (free air within operating temperature range) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Mini PCIe socket supports Wi-Fi modems, GPS receivers, MIL-STD-1553, non-volatile flash data storage, and other plug-in modules Compatible with full- and half-sized Mini PCIe cards. Supports USB and PCIe signaling. PCIe 1.1 transfer rate of 2.5 GT/s max. On-board LEDs indicate card status for socket 0.6” standoff package (metric thread) 0.6” standoff package (English thread) Mini PCIe card hardware kit (metric thread) ** Power specifications represent typical power draw at +25°C with +5V supply running Windows XP with an Intel 5300 Wi-Fi Link card. Maximum power is measured during file transfer over Wi-Fi. Results will vary depending upon Mini PCIe card in use. 802.11n Wi-Fi antenna Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. SUMIT is a trademark of the SFF-SIG. SUMIT-micro is a trademark of VersaLogic Corp. All other trademarks are the property of their respective owners. SUMIT Resources Form Factor: SUMIT-micro SUMIT-A PCIe x1 1 PCIe x4 USB 1 ExpressCard – LPC – SPI / µWire – SMBus / I 2 C – +12V – +5V ü – +5Vsb +3.3V – SUMIT-B • VL-EPMs-21 single board computer • VL-EPHs-B1A USB I/O module • VL-CBR-1013 transition cable 02/15/13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPHS-P1E
1. 物料型号: - 型号:VL-EPHs-P1E
2. 器件简介: - VL-EPHs-P1是一款SUMIT-micro Mini PCIe适配器,提供Mini PCIe插座扩展,适用于任何基于SUMIT的嵌入式系统。它具有小尺寸、简化的接口和广泛的加固功能,为小型嵌入式系统提供多功能的PCI Express® Mini Card扩展。
3. 引脚分配: - 该模块是一个90 mm x 32 mm (3.54” x 1.26”)的SUMIT-micro格式卡,利用SUMIT-A连接器的PCIe和USB通道提供Mini PCIe插座,用于嵌入式系统扩展。
4. 参数特性: - 操作温度范围:-40°C至+85°C,适用于恶劣环境。 - 符合MIL-STD-202G标准,适用于高冲击/振动环境。 - 兼容全尺寸和半尺寸Mini PCIe卡,支持USB和PCIe信号。 - PCIe 1.1传输速率最高为2.5 GT/s。
5. 功能详解: - 提供Mini PCIe插座,支持Wi-Fi调制解调器、GPS接收器、MIL-STD-1553、固态存储等插件设备。 - 四个板上LED提供Mini Card插座的活动状态指示。
6. 应用信息: - 适用于需要高可靠性和长期可用性的OEM应用,从应用设计支持到5年以上的生产寿命保证,VL-EPHs-P1提供了具有出色拥有成本的耐用嵌入式计算机解决方案。
7. 封装信息: - 封装:SUMIT-micro,尺寸为32 mm x 90 mm (1.26 x 3.54英寸)。 - 可堆叠总线:SUMIT(仅堆叠顶部)。
VL-EPHS-P1E 价格&库存
很抱歉,暂时无法提供与“VL-EPHS-P1E”相匹配的价格&库存,您可以联系我们找货
