VL-EPM-V4E
VL-EPM-V4E
    VERSALOGIC
    PC/104-PLUS,ET, VIDEO, 8 MB VRAM
VL-EPM-V4E 数据手册
VL-EPM-V4 PC/104-Plus Video Expansion Module ƒƒ SiS™ Volari™ Z9M GPU ƒƒ 8 MB VRAM ƒƒ Analog VGA and LVDS output ƒƒ Industrial temp. operation ƒƒ MIL-STD-202G shock / vibe Highlights PC/104-Plus™ Rugged industry-standard form factor. Video Analog VGA and LVDS video output. Industrial Temperature -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock / vibration environments. Overview The VL-EPM-V4 expansion module provides video capabilities for PC/104-Plus embedded systems. With a full industrial temperature rating and rugged construction, the VL-EPM-V4 is an ideal solution for embedded video applications in harsh, mobile, and/or remote environments. The VL-EPM-V4 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to the 5+ year production life guarantee, the VL-EPM-V4 provides a rugged embedded computer solution with an excellent cost of ownership. The VL-EPM-V4 is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. Details Based on the PC/104-Plus standard, the VL-EPM-V4 supports PCI and ISA stackable expansion buses on an industry-standard 90 mm x 96 mm (3.55” x 3.78”) expansion module. Utilizing an SiS Volari Z9M GPU for high-performance graphics capabilities, the VL-EPM-V4 provides analog VGA and LVDS video output (simultaneous). The on-board video BIOS supports VESA™ standard graphics modes. The VL-EPM-V4 can be used as a development tool for VersaLogic’s headless (no video output) Tomcat and Newt single board computers or to provide a secondary video output for any PC/104-Plus embedded system. The Z9M GPU features advanced power reduction (throttling) and power down (sleep) controls, which can be accessed in various ways depending on the operating system in use. Designed for full industrial temperature operation (-40° to +85°C), the VL-EPM-V4 is built to withstand thermal extremes. The VL-EPM-V4 board also meets MIL-STD-202G specifications for mechanical shock and vibration for use in harsh environments. The VL-EPM-V4 is compatible with a variety of popular operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX using standard software drivers. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com VL-EPM-V4 PC/104-Plus Video Expansion Module Specifications Ordering Information Model VL-EPM-V4E VGA Y LVDS Y Operating Temp. -40° to +85°C General 0.22A (1.10W) Accessories Part Number Cables VL-CBR-1201 VL-CBR-2010 VL-CBR-2011 Hardware VL-HDW-105 VL-HDW-106 Miscellaneous VL-HDW-203 Description Board Size PC/104 standard: 90 mm x 96 mm (3.55” x 3.78”) Typical Max Power Requirements (+5V)* Idle Environmental 12-pin 2 mm (latching) / 15-pin VGA adapter 20" 18-bit LVDS flat panel (Hirose) 20" 18-bit LVDS flat panel (JAE) 0.6" standoff package (metric thread) 0.6” standoff package (English thread) PC/104™ extractor tool, metal Video Software 0.30A (1.48W) 0.37A (1.85W) Stackable Bus Manufacturing Standards RoHS Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep PC/104-Plus: PCI, ISA (pass-through only) IPC-A-610 Class 2 compliant Compliant -40° to +85°C -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis Vibration, Random MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis Mechanical Shock MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Controller SiS Volari Z9M. 64-bit 2D graphics engine. VRAM Integrated 8 MB DDR SDRAM Desktop Display Analog output (VGA). 16/24-bit. Up to 1280 x Interface 1024 (24-bit) or 1920 x 1200 (16-bit). OEM Flat Panel Interface Single-channel LVDS interface. Up to 1280 x 1024 (18-bit). BIOS On-board SPI-based video BIOS supports VESA standard graphics modes Operating Systems Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX using standard software drivers *  Power specifications represent operation at +25°C with +5V supply running Windows XP. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power is measured with 50% GPU utilization. Specifications are subject to change without notification. PC/104 and PC/104-Plus are trademarks of the PC/104 Consortium. SiS and Volari are trademarks of Silicon Integrated Systems Corp. VESA is a trademark of the Video Electronics Standards Association. All other trademarks are the property of their respective owners. 02/20/13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPM-V4E
物料型号:VL-EPM-V4 器件简介:VL-EPM-V4是一款PC/104-Plus视频扩展模块,专为嵌入式系统提供视频功能,支持恶劣、移动或远程环境中的嵌入式视频应用。
引脚分配:基于PC/104-Plus标准,支持PCI和ISA堆叠扩展总线,尺寸为90 mm x 96 mm。
参数特性:-40°C至+85°C的工业温度操作,符合MIL-STD-202G标准,支持高冲击/振动环境。
功能详解:使用SiS Volari Z9M GPU,提供高性能图形能力,支持模拟VGA和LVDS视频输出(可同时使用),板上视频BIOS支持VESA标准图形模式。
应用信息:适用于需要高可靠性和长期可用性的OEM应用,支持Windows Embedded、Linux、VxWorks和QNX操作系统。
封装信息:PC/104标准尺寸,兼容多种操作系统,使用标准软件驱动。
以上信息摘自VersaLogic公司提供的VL-EPM-V4数据手册。
VL-EPM-V4E 价格&库存
很抱歉,暂时无法提供与“VL-EPM-V4E”相匹配的价格&库存,您可以联系我们找货
VL-EPM-V4E
  • 1+3070.199121+398.35580
