VL-EPH-V6SA
VL-EPH-V6SA
    VERSALOGIC
    VIDEO DISPLAY CONVERTER
VL-EPH-V6SA 数据手册
Product Data Sheet Display Converter DisplayPort to Dual LVDS Stand-alone Converter Module VL-EPH-V6 Actual Size! Overview Highlights The VL-EPH-V6 module provides a rugged converter from standard mini-DisplayPort video output to LVDS (Low Voltage Differential Signaling) display panel output. It allows system designers the ability to utilize their existing LVDS video panels with the latest embedded computer video output (mini-DisplayPort). ƒƒ DisplayPort to LVDS converter ƒƒ Input: Mini-DisplayPort (1 or 2 lanes) ƒƒ Output: 30-pin LVDS (single- or dual-channel) ƒƒ Rugged bolt-down format As with all VersaLogic products, the VL-EPH-V6 is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to the 5+ year production life guarantee, and a full 5-year warranty, the VL-EPH-V6 provides reliable video conversion for demanding applications. ƒƒ MIL-STD-202G Qualified for high shock / vibration environments ƒƒ 5+ Year production life guarantee Worry-free availability ƒƒ 5-year warranty Tailor a Module to Your Exact Requirements Product customization is available, even in low quantities. Options include conformal coating, application-specific testing, BOM revision locks, special labeling, and more. C O R P O R A T I O N EPH-V6/Display Converter Product Data Sheet Stand-alone Converter Module Ordering Information Model VL-EPH-V6SA Function Video Signal Converter. Mini-DisplayPort to Single- or Dual-Channel LVDS. Operating Temp. 0° to +60°C Supported LVDS Panels Model VL-EPH-V6SA Supported Panel Characteristics Recommended Panels Single channel 18 / 24 bit 800 x 600 (SVGA) LQ121S1LG84 800x600 12.1” 18-bit Single channel 18 / 24 bit 1024 x 768 (XGA) LQ150X1LG91 1024x768 15” 24-bit Single channel 18 / 24 bit 1280 x 800 (SXGA) LQ121K1LG52 1280x800 12.1” 24-bit Dual channel, 16.7M colors, 1920 x 1080 (HD 1080) LG LM230WF3 1920x1080 23” Dual LVDS Other Resolutions and configurations are available! Contact VersaLogic sales at (503) 747-2261 for more information. Specifications General Board Size Mounting Power Requirements Power Input Manufacturing Standards Regulatory Compliance 32 mm x 90 mm (1.26” x 3.55”) 4 mounting points for M3 hardware. Two mounting points align with PC/104 spacing for convenience. 3.3V or 5V ±10% @ 1W Typical 2-pin terminal block or 2-pin latching header. IPC-A-610 Class 2 RoHS Environmental Operating Temperature Storage Temperature Altitude Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Mechanical Shock † 0° to +60°C Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.).* -40° to +85°C Operating * To 4,570m (15,000 ft.) Storage To 12,000m (40,000 ft.) None (free air) LVDS Signal Cable VL-CBR-3003 VL-CBR-3002 VL-CBR-3002 VL-CBR-3001 Backlight Power Cable VL-CBR-0601 VL-CBR-0601 VL-CBR-0601 Accessories Part Number Cables VL-CBR-2031 VL-CBR-3001 VL-CBR-3002 VL-CBR-3003 VL-CBR-0601 Hardware VL-HDW-105 VL-HDW-106 Description Cable 500mm mDP to mDP 20” 2-Ch LVDS 30-pin JAE to 30-pin JAE 20” 1-Ch LVDS 30-pin JAE to 20-pin Hirose 20” 1-Ch LVDS 30-pin JAE to 20-pin JAE 12” 12V 6-pin LED Backlight Cable 0.6” standoff package (metric thread) 0.6” standoff package (English thread) Call VersaLogic Sales at (503) 747-2261 for more information! 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis. MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis. MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 msec. duration per axis. Video Controller Display Input Interface OEM Flat Panel Interface Panel Power NXP PTN3460BS Mini-DisplayPort (1 or 2 lanes) Factory configurable for most LVDS panels. Single- or Dual-channel LVDS interface. Up to 1920 x 1200 18/24-bit Four standard panel selects (refer to “Supported LVDS Panel” table, above) Additional panel support available. 3.3V or 5V supply for Panel (4A max) * For extended altitude information contact VersaLogic Sales Dept. Converter shown mounted on a PC/104 single board computer. † MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. DisplayPort is a registered trademark of the VESA, PC/104 is a registered trademark of the PC/104 Consortium. All other trademarks are the property of their respective owners. 8/06/15 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | www.VersaLogic.com C O R P O R A T I O N
VL-EPH-V6SA
物料型号为VL-EPH-V6,是一款坚固的DisplayPort到双LVDS独立转换模块。
器件简介指出,该模块允许系统设计者使用现有的LVDS视频面板与最新的嵌入式计算机视频输出(mini-DisplayPort)配合使用。
它符合MIL-STD-202G标准,适用于高冲击/振动环境,提供5年以上的生产寿命保证和5年保修期。
引脚分配参数特性包括: - 输入:Mini-DisplayPort(1或2通道) - 输出:30针LVDS(单通道或双通道) - 尺寸:32mm x 90mm(1.26" x 3.55") - 电源需求:3.3V或5V ±10% @ 1W典型 - 电源输入:2针端子块或2针锁扣式头 - 制造标准:IPC-A-610 Class 2 - 环境工作温度:0°C至+60°C
功能详解包括支持多种LVDS面板,如800x600 SVGA、1024x768 XGA、1280x800 SXGA和1920x1080 HD 1080等。
此外,还支持面板电源3.3V或5V供应,最大电流4A。
应用信息强调了VersaLogic产品的定制服务,即使是小批量订单,也可以根据客户需求进行定制。
封装信息包括多种配件,如不同长度和类型的电缆和硬件支架等。
如需更多信息,请联系VersaLogic销售部门。
VL-EPH-V6SA 价格&库存
很抱歉,暂时无法提供与“VL-EPH-V6SA”相匹配的价格&库存,您可以联系我们找货
