VL-CKR-RAVEN
VL-CKR-RAVEN
    VERSALOGIC
    RAVENCABLEKIT
VL-CKR-RAVEN 数据手册
Product Data Sheet Raven Embedded Processing Unit 95 x 95 x 27 mm (3.7 x 3.7 x 1.1”) Overview Highlights The Raven is a compact, rugged board-level embedded computer. It has been engineered and tested to meet the military and medical industries’ evolving requirements to develop smaller, lighter, and lower power embedded systems while adhering to stringent regulatory standards. Approximately four inches square and one inch thick, the Raven is a member of the VersaLogic family of small, light, ultra-rugged embedded x86 computers. This embedded computer, equipped with an Intel Atom E38xx “Bay Trail” processor, is designed to withstand extreme temperature, impact, and vibration. ƒƒ A complete x86 embedded computer ƒƒ -40° to +85°C operating temperature ƒƒ Trusted Platform Module (TPM) security chip ƒƒ Shock & vibration per MIL-STD-202G ƒƒ 4th Generation Intel® Atom™ “Bay Trail” processor -- E3845 (quad core) or -- E3827 (dual core) or -- E3815 (single core) ƒƒ Compact (95 x 95 x 27 mm) ƒƒ Up to 4 GB DDR3L soldered-on RAM ƒƒ Dual Gigabit Ethernet ƒƒ DisplayPort++ and LVDS video output Available in single-, dual-, and quad-core versions, the Raven provides great performance and I/O features, moderate power consumption (6 to 8W typical depending on model), and a compact package. The Raven provides compatibility with a broad range of standard x86 application development tools for reduced development time. A wide input voltage range of 8 to 30 volts simplifies system power supply requirements. The Raven is fully compatible with 12 or 24V vehicle applications. In addition, Reverse Voltage Protection, and Over Voltage Protection enhances field durability and reliability. ƒƒ Dual Mini PCIe Sockets ƒƒ USB 3.0 port, USB 2.0 ports ƒƒ Serial I/O ports, SATA, Digital I/O ƒƒ eMMC Flash. Up to 8 GB ƒƒ Analog Inputs (8 chan.) ƒƒ Wide input power regulation -- 8 to 30 volt DC input -- 12 and 24 volt system compatible -- Over and reverse-voltage protection ƒƒ Fanless versions ƒƒ Customization available ƒƒ VersaAPI software support continued   C O R P O R A T I O N Product Data Sheet Overview ...continued Designed and tested for industrial temperature (-40º to +85ºC) operation, the rugged Raven also meets MIL-STD-202G specifications for shock and vibration. Soldered-on RAM and latching SATA, Ethernet, power, and main I/O connectors provide additional ruggedization for use in harsh environments. Raven is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks. Product customization is available, even in low OEM quantities. Options include conformal coating, BGA underfill, BIOS / splash screen configuration, application specific testing, BOM revision locks, custom labeling, etc.  Features 1 2 Wide Range Voltage Input RAM (not shown) Accepts 8 to 30 volts DC with OVP, reverse polarity protection, and RF noise filtering. Up to 4 GB soldered-down DDR3L RAM. Qualified for high shock / vibration environments. FLASH (not shown) Software Support High-performance Video Integrated Intel Gen 7 graphics core supports DirectX 11, OpenGL 4, and H.264, MPEG-2 encoding/decoding. Mini DisplayPort (2a) and LVDS video outputs (2b). LVDS backlight control (2c). 3 4 Up to 8 GB of on-board eMMC flash storage. SATA Compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks. Industrial Temperature Operation -40° to +85°C operation for harsh environments. 7a Network Dual Gigabit Ethernet (GbE). One port with remote boot support. MIL-STD-202G 8 6 2c 7b 3 Gb/s SATA port supports bootable SATA hard drive. 5 Mini PCIe Card Sockets Dual full-sized sockets. Supports A/D, Wi-Fi modems, GPS, MIL-STD-1553, Ethernet, flash data storage with auto-detect mSATA flash storage support, and other mini PCIe modules. 6 2b 7c MicroSD Socket Supports removable microSD card solid-state drives. 7 Industrial I/O 9 5 5 One USB 3.0 port (7a) and four USB 2.0 ports (7b) support keyboard, mouse, and other devices. Eight 3.3V digital I/O lines (7b). Four RS-232/422/485 serial ports (7c), three 8254 timer/counters, and I2C support. 8 Analog On-board data acquisition support. Eight multi-range analog inputs. 9 3 7c SPI Interface Supports SPI and SPX devices, including low cost analog and digital modules. 1 Intel Atom “Bay Trail” Processor 4 (not shown) Up to 1.9 GHz clock rate. Quad-, dual-, or single-core options. Low power consumption. Tailor Raven to Your Exact Requirements Fanless Operation Customization options are available in quantities as low as 100 pieces. No moving parts required for CPU cooling in most configurations. ƒƒ Conformal Coating ƒƒ Custom Cabling ƒƒ Connector & I/O Changes ƒƒ Custom Testing Trusted Platform Module (not shown) On-board TPM security chip can lock out unauthorized hardware and software. ƒƒ Custom Labeling ƒƒ BIOS Modifications ƒƒ Software and Drivers ƒƒ Environmental Screening 2a ƒƒ Revision Locks ƒƒ Application-Specific Testing ƒƒ And more – VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com Raven Embedded Processing Unit Specifications General Mass Storage Board Size 95 x 95 x 27 mm (3.74 x 3.74 x 01.08”) Rotating Drive ¥ One SATA 3 Gb/s port. Latching SATA connector. Weight 200 grams (7.05 oz.) On-board eMMC MLC Flash drive. 0 to 8 GB Processor Intel Atom E38xx platform. 512K 8-way L2 cache per core. Intel 64-bit instructions, Virtualization Technology (VT), and new AES instructions. Connection for 3.0V RTC backup battery Flash / Solid-State Drives ¥ Battery Power Requirements  (@ +12V) † Input Voltage Model Idle Typical Max. S3 5.8W 6.0W 6.2W 1.1W VL-EPU-3312-EBP 6.4W 6.8W 7.2W 1.1W VL-EPU-3312-EDP 6.7W 7.8W 8.9W 1.1W VL-EPU-3312-EAP 8V – 30V DC Mini PCIe socket with mSATA support Network Interface Ethernet ‡ Environmental USB ‡§ One USB 3.0 / 2.0 port and four USB 2.0 host ports COM Interface ‡ Four RS-232/422/485 selectable. 16C550 compatible. RS-232 115 Kbps – RS-422/485 460 Kbps max. Eight TTL I/O Lines 3.3V. Independently configurable. Ranges shown assume 90% CPU utilization. For detailed thermal information, refer to the VL-EPU-3312 Reference Manual. ** Heat plate must be kept below 90°C Airflow Requirements Refer to the VL-EPM-3312 Reference Manual for detailed airflow requirements. Storage Temperature -40° to +85°C Altitude * Operating To 4,570m (15,000 ft.) Storage To 12,000m (40,000 ft.) Thermal Shock 5°C/min. over operating temperature Humidity Less than 95%, noncondensing Vibration, Sinusoidal Sweep ¤ Vibration, Random ¤ MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis Mechanical Shock ¤ MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Security TPM Intel Trusted Platform Module 1.2 device. Atmel – AT97SC3204-U2MA-10 Memory System RAM Digital I/O Analog Input I2C Eight channels. 12-bit. Single-ended. 500 Ksps. Independently configurable +/- 0.64V to +/- 10.24V high input impedance inputs Single I2C interface Counter / Timers Three 8254 compatible Programmable Interval Timers (PITs) VersaLogic SPI Interface Supports SPI and SPX devices. Supports up to two SPX modules. Mini PCIe Card Socket Full size Socket #1 Thermal Management Bolt-on heat plate standard. Optional heat sink, fan, heat pipe, and other thermal accessories available. Operating Model Heat Plate** Heat Sink Heat Sink + Fan Temperature ◊ All models -40° to +85°C -40° to +85°C -40° to +85°C 2 GB or 4 GB of soldered-on DDR3L SDRAM. Two autodetect 10BaseT/100BaseTX/1000BaseT port. Latching connector. One port with network boot option. Device I/O Input Protections Over-voltage protection. Self resetting when input falls to a safe level. Reverse voltage input protection to -30V. RF noise filtering (900 MHz, 2.5/5 GHz) – Minimum of 30 dB RF attenuation above 100 MHz. Transient voltage protection (inductive kickback / lightning) clamp at ~+60V / -40V – MSL level 1, per J-STD-020, LF maximum peak of 260 °C System Reset & All voltage rails monitored. Watchdog timer with Hardware Monitors programmable timeout. Push-button reset and power. Regulatory Compliance RoHS (2011/65/EU) One microSD socket. Bootable Full size Socket #2 Supports Wi-Fi modems, GPS receivers, MIL-STD-1553, Ethernet channels, non-volatile flash data storage, and other plug-in modules. USB, SATA, and PCIe signaling. Autodetect mSATA support. PCIe and USB 2.0 signaling Software BIOS Sleep Mode Operating Systems AMI Aptio UEFI BIOS with OEM enhancements. Field reprogrammable. ACPI 3.0. Support for S3 suspend state. Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks † Represents operation at +25°C and +12V supply running Windows 7 with LVDS display, SATA, GbE, COM, and USB keyboard/mouse. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power measured with 95% CPU utilization. ◊ Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) * Extended altitude specifications available upon request ‡ TVS protected port (enhanced ESD protection) § Power pins on this port are overload protected ¥  Bootable storage device capability ¤ MIL-STD-202G shock and vibe levels are used to illustrate the extreme ruggedness of this product in general. Testing at higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact VersaLogic Sales for further information. Specifications are subject to change without notification. Intel and Atom are trademarks of Intel Corp. microSD is a trademark of SD-3C, LLC. All other trademarks are the property of their respective owners. Video General VRAM Integrated high-performance video. Intel Gen-7 graphics core with 4 Execution Units and Turbo Boost. Supports DirectX 11, OpenGL 4, VP8, MPEG2, H.264, and VC1. Up to 224 MB shared DRAM DisplayPort Interface § Mini DisplayPort++ output. 24-bit. Up to 2560 x 1600. Supports DisplayPort and HDMI signaling (Video and Audio outputs). OEM Flat Panel Single-channel LVDS interface. 18/24-bit. Interface Up to 1024 x 768 (60 Hz). Backlight control signals. C O R P O R A T I O N Raven Product Data Sheet Embedded Processing Unit Ordering Information Model VL-EPU-3312-EAP VL-EPU-3312-EBP VL-EPU-3312-EDP Processor E3815 E3827 E3845 Call VersaLogic Sales at (503) 747-2261 for more information! Cores 1 2 4 Accessories Part Number Cable Kit VL-CKR-BB12 Description Raven/Owl cable kit. Includes VL-CBR-0702, 1014 (x2), 1604, 2004, 2032, 0809, 4005, HDW-401, and 108. System I/O paddleboard SATA cable – rugged latching 20” Dual Ethernet cable, 16-pin Clik-Mate to 2 RJ-45 – rugged latching, 12” I/O screw terminal paddleboard, and cable, Latching, 12" miniDisplayPort to VGA adapter, 6” Power adapter cable, 12V medium-power. ATX12 to Raven. 12” RS232 Dual channel cable 2xDsub (9-pin), Latching, 12” Thermal compound paste. For heat sink attachment. Mini PCIe / mSATA hardware kit (metric thread) 2.5 mm (10ea) VL-CBR-4005 VL-CBR-0702 VL-CBR-1604 VL-CBR-2004 VL-CBR-2032 VL-CBR-0809 VL-CBR-1014 x2 VL-HDW-401 VL-HDW-108 Cables VL-CBR-0203 2-pin Latching Battery Module, 6" VL-CBR-0401 ATX to SATA power cable, 6.25” VL-CBR-0503 USB 2.0 Male A to Male Micro-B Cable, 0.5 m VL-CBR-0701 SATA cable, 20” VL-CBR-0901 Pico-Clasp to Dual SPX Cable, 9-pin. 9” VL-CBR-1015 USB 3.0 Micro A plug to 3.0 Micro B plug, 1 m VL-CBR-2014 LVDS to VGA adapter board VL-CBR-2015 24-bit LVDS 1mm Hirose Cable, 20” VL-CBR-2016 18-bit LVDS cable (JAE), 20” VL-CBR-2017 LVDS 24-bit 1.25 mm Hirose Cable, 20" VL-CBR-0404 LED Back Light, 3-pin Pico-Clasp / 4-pin IDE Power to 6-pin 12V, 0.5 m VL-CBR-2031 miniDisplayPort to miniDisplayPort, 36” VL-CBR-2033 miniDisplayPort to HDMI active adapter, 6” Audio VL-ADR-01S USB to Audio Adapter Solid-State Storage (flash memory) VL-F41-xxxx microSD card (SDIO), SLC, industrial temp. Hardware VL-PS-ATX12-300A ATX development power supply VL-HDW-111 Half to Full Size Mini PCIe Adapter kit. Metal adapter and screws (2) Thermal Options VL-HDW-416 Passive Heat Sink. Mounts to heat plate on standard product 95 x 95 x 10.5 mm VL-HDW-415 12V Cooling fan for optional use with HDW-416 heat sink. VL-HDW-408 Heat Pipe Connector Plate. Mounts to heat plate on standard product. Speed 1.46 GHz 1.75 GHz 1.91 GHz RAM 2 GB 2 GB 4 GB eMMC Flash None 4 GB 8 GB Cooling Heat plate Heat plate Heat plate Mini PCIe Modules Part Number Description Network VL-MPEe-E5E Dual Gigabit Ethernet adapter VL-MPEe-E4E Gigabit Ethernet over Fiber adapter VL-MPEe-E3E Gigabit Ethernet adapter VL-MPEe-FW1E FireWire adapter Serial I/O VL-MPEe-U2E Quad serial plus twelve GPIOs Analog & Digital I/O VL-MPEe-A1E Analog input (12-bit resolution) VL-MPEe-A2E Analog input (16-bit resolution) GPS VL-MPEu-G2E GPS receiver VL-MPEu-G3E Advanced GPS receiver Video VL-MPEe-V5E VGA and LVDS Interface Solid-State Storage (flash memory) VL-MPEs-F1Exx mSATA module (4/16/32 GB) (SATA) Adapters VL-MPEs-S3E SATA adapter Form Factor Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Mini PCIe Modules Take the Risk out of Embedded Computing Mini PCIe Modules Whether it’s selecting the optimum solution for your application, lending expertise during development, or on-time delivery of defect-free products, VersaLogic is here to make sure your project goes smoothly from initial concept through the extended life of your program. Contact us today to learn more. ISO 9001:2015 Certified Copyright © 2019 VersaLogic Corporation. All rights reserved. 08/08/19 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com C O R P O R A T I O N
VL-CKR-RAVEN
物料型号: - VL-EPU-3312-EAP:Intel Atom E3815单核,1.46 GHz,2 GB RAM,无eMMC Flash,使用热板散热。 - VL-EPU-3312-EBP:Intel Atom E3827双核,1.75 GHz,2 GB RAM,4 GB eMMC Flash,使用热板散热。 - VL-EPU-3312-EDP:Intel Atom E3845四核,1.91 GHz,4 GB RAM,8 GB eMMC Flash,使用热板散热。
器件简介: Raven是一款紧凑型、坚固的板级嵌入式计算机,专为军事和医疗行业的严格要求设计,以开发更小、更轻、功耗更低的嵌入式系统,同时遵守严格的监管标准。Raven搭载了Intel Atom E38xx “Bay Trail”处理器,能够在极端温度、冲击和震动下工作。
引脚分配: - 提供了丰富的I/O接口,包括USB 3.0端口、USB 2.0端口、串行I/O端口、SATA、数字I/O以及eMMC Flash。还支持双Mini PCIe插槽。
参数特性: - 工作温度范围为-40°C至+85°C,符合MIL-STD-202G标准,适用于高冲击/震动环境。 - 集成Intel Gen 7图形核心,支持DirectX 11、OpenGL 4和H.264、MPEG-2编码/解码。 - 双千兆以太网端口,其中一个支持远程启动。 - 支持3 Gb/s SATA端口,用于启动SATA硬盘。 - 双全尺寸Mini PCIe插槽,支持多种mini PCIe模块。
功能详解: Raven支持多种流行的x86操作系统,包括Windows、Windows Embedded、Linux和VxWorks。产品可以根据客户需求定制,包括敷形涂层、BGA底部填充、BIOS/启动屏幕配置等。
应用信息: Raven适用于需要在恶劣环境下运行的应用,如车载系统、医疗设备等。它的设计允许在广泛的输入电压范围内工作,简化了系统电源供应要求。
封装信息: Raven的封装尺寸为95 x 95 x 27 mm(3.7 x 3.7 x 1.1英寸)。根据不同型号,可以选择不同的散热解决方案,包括热板、散热器、风扇和热管等。
VL-CKR-RAVEN 价格&库存
很抱歉,暂时无法提供与“VL-CKR-RAVEN”相匹配的价格&库存,您可以联系我们找货
