VL-ENCL-4P1
VL-ENCL-4P1
    VERSALOGIC
    ENCL -4A4 4A6 & A48 END PLATE
VL-ENCL-4P1 数据手册
VersaTainer Ruggedized PC/104 Enclosure Ruggedized enclosure for PC/104 and PC/104-Plus modules. Features • • Larger than other “can” type enclosures Rugged single-piece extruded body • Internal module vibration mount • External isolating shock mount • Heat-dissipating fins • 4”, 6” and 8” lengths • Accommodates VersaLogic’s Jaguar CPU module Description The VersaTainer is a compact, rugged enclosure for PC/104 modules. Larger than the popular Can-Tainer, it provides generous internal space for connector and cabling requirements. With its solid one-piece extruded body, the VersaTainer provides an extremely high degree of physical protection for PC/104 systems during operation or transport. Available in several lengths to accommodate smaller or larger systems, each VersaTainer enclosure includes: • • • • • VersaTainer body in selected length Rubber mounting rails Power connector end plate End plate for VersaLogic Jaguar or Panther cable kit I/O Anti-shock mounting pad Ordering Information VL-ENCL-4A4 .......4” VersaTainer (holds 5 modules) VL-ENCL-4A6 .......6” VersaTainer (holds 8 modules) VL-ENCL-4A8 .....8” VersaTainer (holds 11 modules) VL-ENCL-4P1 ........Blank end plate, 1/16” aluminum The VersaTainer features anti-vibration and shock mounting systems both internally and externally. Internally all PC/104 modules are isolated using corner support on compressionmounted rubber rails. Externally the entire enclosure is connected to its mounting point through a full-length rubber shock pad. For environments with airborne contaminants, the VersaTainer features 8-screw end plates with fan filters. Specifications subject to change without notice. Can-Tainer is a trademark of Tri-M Engineering. VersaTainer is a trademark of VersaLogic Corp. DOC-05-113 R1 3888 Stewart Road, Eugene, OR 97402 • (541) 485-8575 • Fax (541) 485-5712 • info@versalogic.com • www.versalogic.com
VL-ENCL-4P1 价格&库存
很抱歉,暂时无法提供与“VL-ENCL-4P1”相匹配的价格&库存,您可以联系我们找货
