PCM-3724
PCM-3724
    VERSALOGIC
    EXP DIGITAL I/O 48-BIT PC/104
PCM-3724 数据手册
PCM-3724 48-channel Digital I/O Module 48-channel digital I/O module with fully buffered I/O lines. Features • 48 programmable I/O lines • Fully buffered high-current TTL lines • Rising/falling edge interrupt triggering • Output status readback • Opto 22 I/O rack plug compatible • Jumper selectable interrupts Description The PCM-3724 provides 48 fully buffered digital input/output lines. It features Intel 8255 Mode 0 software compatibility for use with all popular software drivers. The two 50-pin I/O connectors are plug compatible with Opto 22 type I/O racks. The PCM-3724 provides the reliability of fully buffered inputs and outputs and high drive capacity at a cost comparable with non-buffered boards. The module’s 48 bits are divided into six 8-bit I/O ports. Each port is software configurable as an input or an output. Two hardware interrupt lines are also available. Ordering Information PCM-3724 . . . . . . . . . 48-Channel Digital I/O Module VL-HDW-101 . . . . . . . . Standoff Pkg. Metric Thread * All required cables are included with card Specifications Specifications are typical at 25°C with 5.0V supply unless otherwise noted. Board Size: 3.55" x 3.775" (PC/104 standard) Storage Temperature: – 20° to +85° C Free Air Operating Temperature: 0° C to +60° C Power requirement: +5V @ 90 ma typ. Digital output Logic level 0: 0.5V max. (@ 24 ma sink) Logic level 1: 2.0V min. (@ 15 ma source) Digital input Logic level 0: 0.8V max. Logic level 1: 2.0V min. Connectors: Two Opto 22 compatible 50-pin .1” headers Compatibility: PC/104 Opto 22 type I/O racks Specifications are subject to change without notice. PC/104 and the PC/104 logo are trademarks of the PC/104 Consortium. 3888 Stewart Road, Eugene, OR 97402 • (800) 824-3163 • Fax (541) 485-5712 • Info@VersaLogic.com • www.VersaLogic.com
PCM-3724 价格&库存
很抱歉,暂时无法提供与“PCM-3724”相匹配的价格&库存,您可以联系我们找货
PCM-3724
  • 1+6016.208291+778.73546
