VL-MPES-F1E16
VL-MPES-F1E16
    VERSALOGIC
    16 GB MSATA DRIVE MINIPCIE IT
VL-MPES-F1E16 数据手册
Product Data Sheet mSATA Drive Mini PCIe Module VL-MPEs-F1 Actual Size! Overview Highlights The VL-MPEs-F1 is an extremely small and rugged mSATA module based on the industrystandard Mini PCIe module format. Unlike typical I/O expansion boards, Mini PCIe allows additional I/O functions to be added to a system with almost no increase in overall system/ package size. Mini PCIe modules provide a simple, economical, and standardized way to add I/O functions to embedded computer products. ƒƒ Mini PCIe Module Format Small and flexible. ƒƒ Flash Memory Non-volatile storage up to 256 GB. ƒƒ Industrial Temperature Operation -40° to +85°C operation for harsh environments. ƒƒ MIL-STD-202G Qualified for high shock/vibration environments. In a very small package, this board provides up to 256 GB of plug-in flash data storage for almost any embedded system. This non-volatile memory drive provides high-capacity data storage. The drive has an intelligent internal controller which manages interface protocols, data storage, and retrieval. The wear leveling mechanism assures an equal usage of the Flash memory cells to maximize the longevity of the device. The hardware BCH-code ECC detects and corrects internal errors. The voltage detector and power-loss management features prevent data corruption after power-down. This rugged product is designed and tested for full industrial temperature operation (-40º to +85ºC). It also meets MIL-STD-202G specifications for shock and vibration, making it at home in harsh environments. This mSATA board is compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, and Linux. The module utilizes SATA signaling and can be used in any system that supports SATA signaling at the Mini PCIe socket. This 3rd party product has been selected and tested for compatibility with VersaLogic products, compliance with VersaLogic ruggedness requirements, and is backed by VersaLogic’s product warranty, world-class technical support, and 5-year lifecycle guarantee. C O R P O R A T I O N mSATA Drive Product Data Sheet Mini PCIe Module Specifications Ordering Information General Board Size Mini PCIe module (full size): 29.85 x 50.8 x 3.3 mm (1.18 x 2.0 x 0.13”) 3.3V ±5% @ 1.39 W (supplied by the Mini PCIe socket) RoHS Power Requirements Regulatory Compliance Mini PCIe Signal Type Modules up to 32 GB: SATA 3 Gbit/s (1.5 Gbit/s compatible) Modules 64 GB and larger: SATA 6 Gbit/s (3 & 1.5 Gbit/s compatible) Environmental Operating Temperature ◊ Storage Temperature Altitude * Cooling Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Mechanical Shock † -40° to +85°C -40° to +85°C Operating Storage None (fanless) None (free air) To 4,570m (15,000 ft.) To 12,000m (40,000 ft.) 5°C/min. over operating temperature. Less than 90%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g halfsine, 11 msec. duration per axis Device I/O Rotating Drives / Flash / Solid-State Drives For mSATA modules up to 32 GB. SLC NAND Flash. Hardware ECC. Wear leveling. SATA signaling. Bootable. Burst Transfer Up to 300 MB/s Sustained Write Up to 95 MB/s Sustained Read Up to 120 MB/s For mSATA modules 64 GB and larger. pSLC NAND Flash. Hardware ECC. Wear leveling. SATA signaling. Bootable. Burst Transfer Up to 600 MB/s Sustained Write Up to 465 MB/s Sustained Read Up to 555 MB/s Model VL-MPEs-F1E4 VL-MPEs-F1E16 VL-MPEs-F1E32 VL-MPEs-F1E64 VL-MPEs-F1E128 VL-MPEs-F1E256 Function SLC mSATA drive, 4 GB SLC mSATA drive, 16 GB SLC mSATA drive, 32 GB pSLC mSATA drive, 64 GB pSLC mSATA drive, 128 GB pSLC mSATA drive, 256 GB Operating Temp. -40° to +85°C -40° to +85°C -40° to +85°C -40° to +85°C -40° to +85°C -40° to +85°C Accessories Part Number Hardware VL-HDW-108 VL-HDW-110 Description Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs. Mini PCIe module hold-down screws (10) for use with 2.0 mm standoffs. Other VersaLogic Mini PCIe Modules Model VL-MPEe-A1E VL-MPEe-A2E VL-MPEu-C1 VL-MPEe-E4E VL-MPEe-E5E VL-MPEe-E6 VL-MPEe-E6E-P VL-MPEe-U2E VL-MPEe-V5E VL-MPEe-FW1 VL-MPEs-S3E VL-MPEu-G2E VL-MPEu-G3E Function Analog input (12-bit resolution) Analog input (16-bit resolution) Dual CAN Bus Interface Gigabit Ethernet Over Fiber Module Dual Channel Gigabit Ethernet Adapter Gigabit Ethernet Gigabit Ethernet with POE+ Four Serial ports. Twelve GPIO lines. Video Display Adapter. VGA and LVDS interfaces 1394 Firewire Module SATA adapter GPS receiver Advanced GPS receiver Signaling PCIe PCIe USB PCIe PCIe PCIe PCIe PCIe PCIe PCIe SATA USB USB Call VersaLogic Sales at (503) 747-2261 for more information! Software Operating Systems Compatible with most x86 operating systems including Windows, Windows Embedded, and Linux * Extended altitude specifications available upon request † MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact VersaLogic Sales for further information. Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. All other trademarks are the property of their respective owners. Mini PCIe Modules Copyright © 2021 VersaLogic Corporation. All rights reserved. 10/28/21 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | VersaLogic.com C O R P O R A T I O N
VL-MPES-F1E16
物料型号:VL-MPEs-F1
器件简介:VL-MPEs-F1是一款基于Mini PCIe模块格式的极小且坚固的mSATA模块,提供高达256GB的即插即用闪存数据存储。
引脚分配:Mini PCIe模块(全尺寸):29.85 x 50.8 x 3.3 mm (1.18 x 2.0 x 0.13")。
参数特性: - 电源要求:3.3V ±5% @ 1.39 W(由Mini PCIe插座供电) - 工作温度:-40°C至+85°C - 存储温度:-40°C至+85°C - 振动:MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis - 冲击:MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 msec. duration per axis
功能详解: - 非易失性存储器,提供高容量数据存储。
- 内部智能控制器管理接口协议、数据存储和检索。
- 磨损均衡机制确保Flash存储单元的均衡使用,以延长设备的使用寿命。
- 硬件BCH码ECC检测和纠正内部错误。
- 电压检测和断电管理功能防止断电后数据损坏。
应用信息:兼容多种流行的x86操作系统,包括Windows、Windows Embedded和Linux。
封装信息:Mini PCIe模块格式,尺寸为29.85 x 50.8 x 3.3 mm (1.18 x 2.0 x 0.13")。
VL-MPES-F1E16 价格&库存
很抱歉,暂时无法提供与“VL-MPES-F1E16”相匹配的价格&库存,您可以联系我们找货
VL-MPES-F1E16
  • 1+5135.172101+665.61608
