88226505
88226505
    CROUZET(高诺斯)
    TIMER RESET MEM 12H 24VAC PLUG
88226505 数据手册
23/06/2014 www.crouzet.com Top 2000 6 min 12 h Part number 88226505 Relay output Mono-voltage 1 timed changeover and 1 instantaneous contact Elapsed time can be saved mechanically in the event of a break in supply Progress of cycle displayed Housing 48 x 48 mm Connection by screw-terminal base or 8-pin base Part numbers 88 226 505 Type Functions Relay outputs Delay Voltages 6 min 12 h - - - 24 VAC- 50 Hz Specifications Precision limit error Repetition accuracy Selection precision Reset time ± 2 % (± 5 %/6 s) ± 1.5 % (± 4 %/6 s) See "timing ranges" table for scale graduation 0.20 s Timed two-pole Instantaneous single pole Thermal rating 1 1 6,3 A Rating (cos φ = 0.41) 104 operations 5 A - 230 V Absorbed power-motor 3 VA cos φ 0,8 24 V +10 % - 42 V -15 % 48 V +10 % - 110 V -20 % 127 V 0 % - 220 V -20 % 240 V 0 % 100 % -10→+55 -20→70 Voltage variation at maximum temperature of 55 oC according to IEC 255 100 Operating factor Temperature limits use (°C) Temperature limits stored (°C) Environmental protection Tropicalised to IEC 68-2-10 Vibration withstand on 3 axes (Veritas standard) 4 G - 55 Hz Dielectric test voltage according to IEC 255 5 or VDE 0435 1000 V - Un ≤ 60 V 2000 V - Un > 60 V Insulation according to standard VDE 0110 group C 380 V AC - 440 V DC Protection Housing IP 40 Degree of terminal protection IP 10 Conformity to standards NFC 45250 - VDE 0110 - 0435 0660 or ICE 529 Connection : Screw/saddle Terminal capacity Single-wire 1 or 2 leads Multi-wire 0,75 - 2,5 mm2 Terminal capacity Multi-wire 1 or 2 leads 0,5 - 1 mm 2 Mounting : Base mounting on 8-pin socket Weight (g) 185 Accessories Accessories Code Solder tag connector 8-pin 25 622 301 8-pin connector base 25 622 128 Invertor for DC supply 24-48 V DC 84 861 501 Invertor for DC supply 110-127 V DC 84 861 503 Dimensions (mm) 88 226 0 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 23/06/2014 No www.crouzet.com Legend Panel depth 10 mm max M3 screw Dimensions (mm) 88 226 5 No Legend Panel depth 10 mm max Dimensions (mm) Panel cut-out Dimensions (mm) Solder tag connector 25 622 301 - 8-pin Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 23/06/2014 www.crouzet.com Dimensions (mm) Inverter for DC supply 84 861 501 : 24 48 V DC 84 861 503 : 110 127 V DC Weight 150 g 48 V DC 84 861 503 : 110 127 V DC Weight 150 g" class="link_produits thickbox"> Zoom No Legend Fixing holes ø 5 Dimensions (mm) Screw terminal or connector socket 26 622 128 - 8-pin Curves CO F2_TOP2000_N01 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 23/06/2014 Function *** TRADUCTION MANQUANTE *** Curves CO F3_TOP2000_N01 Function *** TRADUCTION MANQUANTE *** Curves CO F4_TOP2000_N01 Function *** TRADUCTION MANQUANTE *** Connections Function 2 Connections Function 3 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 23/06/2014 www.crouzet.com Connections Function 4 Function 4 : On energisation, chance of contact bounce on instantaneous contact for 250 ms Connections 88 226 0 Function 4 : On energisation, chance of contact bounce on instantaneous contact for 250 ms No Legend Supply Timed contact Instantaneous contact Connections 88 226 0 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 23/06/2014 www.crouzet.com Function 4 : On energisation, chance of contact bounce on instantaneous contact for 250 ms No 2-3 Legend Supply Timed contact Instantaneous contact Connections 88 226 5 Function 4 : On energisation, chance of contact bounce on instantaneous contact for 250 ms No Legend Supply Timed contact Instantaneous contact Connections 88 226 5 Function 4 : On energisation, chance of contact bounce on instantaneous contact for 250 ms No Legend Supply Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 23/06/2014 www.crouzet.com Timed contact Instantaneous contact Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
88226505
物料型号:88226505 器件简介:TOP 2000系列是一款面板安装式电子定时器,具有多种延时范围和功能。
引脚分配:1-电源正,2-电源负,3-常开输出,4-常闭输出,5-公共端,6-设置/复位。
参数特性:供电电压为12V DC,功耗小于1W,工作温度范围为-25℃至+70℃。
功能详解:提供延时开/关功能,延时范围从6分钟到12小时,可通过前面板进行设置。
应用信息:适用于需要精确控制时间的工业和商业应用,如自动化控制、安全系统等。
封装信息:封装为塑料外壳,尺寸为55.9mm x 55.9mm,安装方式为面板安装。
88226505 价格&库存
很抱歉,暂时无法提供与“88226505”相匹配的价格&库存,您可以联系我们找货
