84871304
84871304
    CROUZET(高诺斯)
    HDI-L 120VAC
84871304 数据手册
Wiha Quality Tools Go To Image Index Germany 194 Go To Numerical Index Toll Free: (800) 494-6104 Hex Bits The ideal multi-purpose bits for all around quality & performance SHOP Made in Germany - Production Quality 713 Impact resistant modified CVM, tool steel, hardened High resistant to wear and tear for a long tool life Suitable for all applications Hardness HRC 59-61 Suitable for both manual and machine applications Wiha MagicRing Insert Bits SHOP 713 Hex Metric Insert Bits, 1/4” Item No. mm mm pkg. lbs. 713 03 1.5 25 10 .12 713 06 2.0 25 10 .12 713 08 2.5 25 10 .12 713 09 3.0 25 10 .12 713 12 4.0 25 10 .12 713 15 5.0 25 10 .14 713 18 6.0 25 10 .14 713 21 8.0 25 10 .20 713 24 10.0 25 10 .27 SHOP SHOP I N D E X 713 Hex Inch Insert Bits, 1/4” Item No. Inch mm pkg. lbs. 713 29 .050 25 10 .12 713 26 1/16 25 10 .12 713 28 5/64 25 10 .12 713 30 3/32 25 10 .12 713 33 7/64 25 10 .12 713 36 1/8 25 10 .12 713 39 9/64 25 10 .12 713 42 5/32 25 10 .12 713 45 3/16 25 10 .13 713 48 7/32 25 10 .13 713 51 1/4 25 10 .13 713 53 5/16 25 10 .20 713 56 3/8 25 10 .25 Screw Holding Hex Bits 713 MagicRing Metric Insert Bits, 1/4” Item No. mm mm pkg. lbs. 713 04 3.0 25 1 .01 713 07 4.0 25 1 .01 713 10 5.0 25 1 .01 713 11 6.0 25 1 .01 713 MagicRing Inch Insert Bits, 1/4” Item No. Inch mm pkg. lbs. 713 43 1/8 25 1 .01 713 46 9/64 25 1 .01 713 49 5/32 25 1 .01 713 52 3/16 25 1 .01 713 54 7/32 25 1 .01 713 58 1/4 25 1 .01 Hex Inch Insert Bit Packs, 1” CVM S2 modified tool steel. Item No. Inch mm lbs. 2 Bit Pack 713 59 .050 25 .03 713 60 1/16 25 .03 713 61 5/64 25 .03 713 62 3/32 25 .03 713 63 7/64 25 .03 713 64 1/8 25 .03 713 65 9/64 25 .03 713 66 5/32 25 .04 713 67 3/16 25 .04 713 68 7/32 25 .04 713 69 1/4 25 .04 713 73 5/16 25 .05 713 87 3/8 25 .06 733 Hex Metric Insert Bit Packs, 1” CVM S2 modified tool steel. Item No. mm mm lbs. 733 01 1.5 25 .03 733 02 2.0 25 .03 733 03 2.5 25 .03 733 04 3.0 25 .03 733 05 4.0 25 .03 733 06 5.0 25 .03 733 07 6.0 25 .04 733 08 8.0 25 .05 733 09 10.0 25 .06 SHOP 2 Bit Pack SHOP SHOP 713 96 Hex Inch Insert Bit Packs, 1” CVM S2 modified tool steel. Extra hard with natural finish. Exact fit machined tips. 6 pc. bit pack. 713 96 Set includes the following bits: Hex Inch Sizes: 1/16, 3/32, 1/8, 5/32 wt. .13 3/16, 1/4” x 1” (25mm) 713 97 Hex Metric Insert Bit Packs, 1” CVM S2 modified tool steel. Extra hard with natural finish. Exact fit machined tips. 6 pc. bit pack. 713 97 Set includes the following bits: Hex Metric Sizes: wt. .21 2.0, 2.5, 3.0, 4.0, 5.0, 6.0 SHOP PREVIOUS NEXT Go To Numerical Index Go To Image Index Wiha Quality Tools Germany www.wihatools.com 195 SHOP 719 Tamper Resistant Hex In Insert Bits, 1/4” Item No. Inch mm pkg. lbs. 719 30 5/64 25 10 .12 719 32 3/32 25 10 .12 719 34 7/64 25 10 .12 719 36 1/8 25 10 .12 719 38 9/64 25 10 .12 719 40 5/32 25 10 .12 719 55 3/16 25 10 .13 719 56 7/32 25 10 .14 719 60 1/4 25 10 .15 SHOP SHOP 719 95 PokitPak - Tamper Resistant Hex Metric Insert Bits In Molded Case lbs. .31 Set Includes 6 - 1/4” Insert Bits Metric: 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm SHOP 719 Tamper Resistant Hex Bits, 1/4” Item No. mm mm pkg. 719 39 2.0 25 10 719 41 2.5 25 10 719 42 3.0 25 10 719 43 4.0 25 10 719 44 5.0 25 10 719 45 6.0 25 10 719 46 8.0 25 10 743 Hex Inch Power Bit Packs, 2” Item No. Inch mm lbs. 2 Bit Pack 743 81 3/32 50 .07 743 82 7/64 50 .07 743 83 1/8 50 .07 743 84 9/64 50 .07 743 85 5/32 50 .07 743 86 3/16 50 .07 743 87 7/32 50 .07 743 88 1/4 50 .07 Metric Insert lbs. .12 .12 .12 .12 .15 .15 .20 SHOP SHOP SHOP 719 Tamper Resistant Hex Inch Insert Bit Packs, 1” CVM S2 modified tool steel. Item No. Inch mm lbs. 2 Bit Pack 719 70 5/64 25 .03 719 71 3/32 25 .03 719 72 7/64 25 .03 719 73 1/8 25 .03 719 74 9/64 25 .03 719 75 5/32 25 .03 719 76 3/16 25 .04 719 77 7/32 25 .04 719 78 1/4 25 .04 719 Tamper Resistant Hex Metric Insert Bit Packs, 1” CVM S2 modified tool steel. Item No. mm mm lbs. 2 Bit Pack 719 79 2.0 25 .03 719 80 2.5 25 .03 719 81 3.0 25 .03 719 82 4.0 25 .03 719 83 5.0 25 .04 719 84 6.0 25 .04 719 85 8.0 25 .05 SHOP 743 Hex Inch Power Length 2.0”/50mm Item No. Inch mm 743 11 3/32 50 743 12 7/64 50 743 13 1/8 50 743 14 9/64 50 743 15 5/32 50 743 16 3/16 50 743 17 7/32 50 743 18 1/4 50 Bits. 1/4” Hex Drive, pkg. 10 10 10 10 10 10 10 10 lbs. .30 .30 .30 .30 .30 .30 .30 .30 Wiha MagicRing Power Bits Screw Holding Hex Bits SHOP SHOP 743 Hex Metric Power Bits. 1/4” Hex Drive, Length 2.0”/50mm Item No. mm mm pkg. lbs. 743 25 2.5 50 10 .25 743 30 3.0 50 10 .25 743 40 4.0 50 10 .25 743 50 5.0 50 10 .25 743 60 6.0 50 10 .25 743 80 8.0 50 10 .38 PREVIOUS 743 Hex Metric Power Bit Packs, 2” Item No. mm mm lbs. 2 Bit Pack 743 61 2.5 50 .07 743 62 3.0 50 .07 743 63 4.0 50 .07 743 64 5.0 50 .07 743 65 6.0 50 .07 743 66 8.0 50 .09 NEXT 743 MagicRing Metric Power Bits, 1/4” Item No. mm mm pkg. lbs. 743 01 3.0 50 1 .02 743 05 4.0 50 1 .02 743 07 5.0 50 1 .03 743 19 6.0 50 1 .03 743 MagicRing Inch Item No. mm mm 743 69 1/8 50 743 71 9/64 50 743 73 5/32 50 743 75 3/16 50 743 77 7/32 50 743 79 1/4 50 Power Bits, 1/4” pkg. 1 1 1 1 1 1 lbs. .02 .02 .02 .03 .03 .03 SHOP I N D E X
84871304 价格&库存
很抱歉,暂时无法提供与“84871304”相匹配的价格&库存,您可以联系我们找货
