79451903
79451903
    CROUZET(高诺斯)
    PNEUM PANEL MOUNT ADAPTER
79451903 数据手册
www.crouzet.com Timers for mounting installation plan 25x32 Variable timing, 0,1 to 15 s Positive output Part number 81503710 xxx 81503540 81503710 81506710 81503720 81506720 Type Code Fixed timing, Positive output Variable timing, 0,1 to 15 s Positive output Variable timing, 0,1 to 15 s Negative output Variable timing, Positive output 0,1 to 30 s Variable timing Negative output 0.1 to 30 s 81503540 81503710 81506710 81503720 81506720 Symbol Operating pressure (bar) Flow at 6 bars Nl/min Orifice diameter mm Accuracy % Reset min. time S 2 →8 170 2,7 ±5 10 7 90 Panel mounting adaptor Weight (g) 79 451 698 53 Dimension Diagram : References L max. (mm) 81 503 710 78 Dimension Diagram : Adaptor 79 451... : Timing by charging of reservoir 06/06/2011 www.crouzet.com The reservoir fills via the flow restrictor until the switching poir of the timer output is reached (positive or negative). The non-return valve allows the reservoir to be emptied rapidly for the next timing. Curves : *** TRADUCTION MANQUANTE *** No A B 06/06/2011 Legend
79451903 价格&库存
很抱歉,暂时无法提供与“79451903”相匹配的价格&库存,您可以联系我们找货
