DK605
DK605
    C-TON
    VOLTMETER 2VDC LED PANEL MOUNT
DK605 数据手册
DK600 LED Digital Panel Meters Specifications Installation and Operating Instructions 3½ Digit LED Display for voltage inputs FEATURES }} }} }} }} }} Display hold function standard 3½ digits with 0.56” RED or GREEN LED Window mount with optional bezel User-selectable decimal points Optional NEMA case (see DK610 for details) SPECIFICATIONS ORDERING INFO DISPLAY PART NUMBER METER COLOR Digits: Type: Digit Height: Polarity Indication: Decimal Point: Overrange: 3 ½ (±1999 count) 7- segment LED (red or green) .56 in (14.2 mm) automatic “-” for neg input 3 position selectable three lower order digits blank for inputs >1999 & < -1999 DK601 ....................................... GREEN ..................................... 200mV DC DK602 ....................................... GREEN ............................................. 2VDC DK603 ....................................... GREEN ........................................... 20VDC DK604.......................................... RED ....................................... 200mV DC DK605 ......................................... RED ..............................................2V DC DK606 ......................................... RED ............................................20V DC SIGNAL INPUTS Configuration: bipolar, differential Full-Scale Input: ±200 mV, ±2 V, ±20 V Input Offset Adjustment: auto zero Input Impedance: >100 MΩ (±200 mV),‑1 MΩ (other ranges) Common Mode Range: ±1 VDC Common Mode Rejection: >86 dB Protection: ±350 VDC (±100 VDC for 200 mV range) Input Bias Current: 1 pA typical, 100 pA max Control Inputs: decimal point select, hold, span adjust trimpot DK610................................................................................ NEMA Enclosure ACCESSORIES LED-B................................................................. Optional Bezel Mounting Kit C10-5................................................5" - 10 Pin Connector / Wire Assembly J1C10..............................................12" - 10 Pin Connector / Wire Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply CVC...............................................................................................Calibrator PERFORMANCE Sampling Rate: 3.3 readings / s Accuracy: ± (0.1% + 2 counts) typical ±(0.2% + 2 counts) max Warmup, typical: 10 min Temperature Drift, typical: 100 ppm / °C POWER SUPPLY Supply Voltage: Supply Current, typical: +5 VDC ±5% 200 mA ENVIRONMENT Operating Temperature: 0 to 50°C Storage Temperature: -10 to 60°C Relative Humidity: 0 to 95% non-condensing PHYSICAL Package Style: Dimensions: Panel Cutout: Weight: Connector: Bezel: CONNECTION: METER POWER window mount 2.52 x 1.10 x .73 2.05 x .81 0.7 oz (20 g) J1C-10 or C10-5 optional optional 10 pin C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LED Digital Panel Meters Specifications Installation and Operating Instructions DK600 3½ Digit LED Display for voltage inputs DIMENSIONS WIRING PIN # PIN NAME DESCRIPTION 1 V+ +5V POWER SUPPLY 2 GND POWER SUPPLY GROUND 3 DP COM DECIMAL POINT RETURN 4 DP1 1XX.X (CONNECT TO DP COM TO TURN ON) 5 DP2 1X.XX (CONNECT TO DP COM TO TURN ON) 6 DP3 1.XXX (CONNECT TO DP COM TO TURN ON) 7 INPUT(+) POSITIVE INPUT SIGNAL 8 INPUT(-) NEGATIVE INPUT SIGNAL 9 NC NO CONNECTION REQUIRED 10 HOLD HOLD LAST DISPLAY C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK605 价格&库存
很抱歉,暂时无法提供与“DK605”相匹配的价格&库存,您可以联系我们找货
