DK712
DK712
    C-TON
    VOLTMETER 20VDC LCD PANEL MOUNT
DK712 数据手册
DK700-710 LCD Digital Panel Meters Specifications Installation and Operating Instructions Low Cost 4½ Digit LCD Display FEATURES }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Polarity: Annunciators: Decimal Points: Overrange: Hold: INPUTS Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY 5V powered: 9V powered: MOUNTING DK700: DK710: CONNECTION ORDERING INFO DK700 SERIES - WINDOW / SURFACE MOUNT 4 ½ digits (±19999 counts) 0.5" (13mm) 7 segment LCD automatic, “-” displayed “LoBat” when power 19999 & < -19999 standard PART NUMBER ±200.0 mV, ±2.000 V, ±20.00 VDC single ended for 9 V powered, differential for 5 V powered ±10 VDC on 200 mV ; ±100 VDC on @ 2V ; ±350 VDC on 20 V range >100 MΩ on ± 200 mV ; (>1 MΩ on 2 V & 20 V range) 10 pA typical ±(0.06% fs + 1 count) maximum 2 per second >30 dB @ 60 Hz ±1 VDC (5 V powered) >86 dB automatic 10 minutes typical ±50 ppm per °C typical ±100 ppm max for 200 mV range ±100 ppm per °C typical ±200 ppm max for 2V and 20V ranges METER INPUT DK703 ...........................................2V ............................................. +5VDC DK704 ....................................... 200mV ................................................. 9V DK705 ...........................................2V .................................................... 9V DK710 SERIES - SNAP-IN BEZEL MOUNT METER INPUT DK711 ...........................................2V ............................................. +5VDC DK712 ..........................................20V ............................................ +5VDC ACCESSORIES J4C13....................................................... 13 Pin Connector / Wire Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply PW2-12.................................... Regulated 120V AC to 12V DC Power Supply CVC...............................................................................................Calibrator +5 VDC (4.65 - 5.35) at 2.6 mA +7.2 to +12 V at 1.5 mA surface or window mount snap-in bezel mount C-TON Industries METER POWER DK710 ....................................... 200mV .......................................... +5VDC 0 to 50 °C -10 to 70 °C 13 pins, 0.025" square on 0.1" centers METER POWER DK702 ....................................... 200mV .......................................... +5VDC PART NUMBER Ranges: Configuration: Protection: Impedance: Bias Current: PERFORMANCE Low-cost, high-performance replacement for many OEM DPMs Mounting choices: Window mount for custom OEM Surface mount with minimum space behind the panel Snap-in bezel mount eliminates mounting hardware Low power: choice of 1.5mA (9V) or 2.6mA (+5V) Space-saving design: only 1" (25 mm) deep Occupies less than 2.5 X 1.1 inches of front panel space 4½ digits with high-contrast LCD • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com DK700-710 LCD Digital Panel Meters Specifications Installation and Operating Instructions Low Cost 4½ Digit LCD Display WINDOW/SURFACE MOUNT DIMENSIONS PANEL CUTOUTS SNAP-IN BEZEL MOUNT DIMENSIONS WIRING CONNECTIONS PIN # PIN NAME DESCRIPTION 1 2 3 4 5 6 7 8 9 10 11 12 13 C-TON Industries V+ V- INHI INLO D1 D2 D3 D4 DP RNG HLD NC NC POSITIVE SUPPLY CONNECTION NEGATIVE SUPPLY CONNECTION INPUT HIGH TERMINAL INPUT LOW TERMINAL DECIMAL POINT = 000.0 DECIMAL POINT = 00.00 DECIMAL POINT = 0.000 DECIMAL POINT = .0000 TO DECIMAL DP COMMON CONNECT POINTS TO ACTIVATE 10:1 RANGE CONNECT TO V+ HOLD FEATURE POINTS TO ACTIVATE NO CONNECTION REQUIRED NO CONNECTION REQUIRED } • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK712
物料型号: - DK700系列:适用于窗口/表面安装 - DK710系列:适用于快装式边框安装
器件简介: DK700-710系列是低成本的4½位LCD显示屏,适用于许多原始设备制造商(OEM)DPMs的高性能替代品。这些数字面板表可以选择窗口安装或表面安装,以最小化面板背后的空间,并且具有快装式边框安装,省去了安装硬件。它们具有低功耗特性,可以选择1.5mA(9V)或2.6mA(+5V),并且节省空间的设计仅1"(25mm)深,占用的前面板空间小于2.5×1.1英寸。
引脚分配: - 1号引脚:V+,正电源连接 - 2号引脚:V-,负电源连接 - 3号引脚:INHI,输入高终端 - 4号引脚:INLO,输入低终端 - 5号引脚:D1,小数点=000.0 - 6号引脚:D2,小数点=00.00 - 7号引脚:D3,小数点=0.000 - 8号引脚:D4,小数点=.0000 - 9号引脚:DP,连接到小数点DP公共点以激活 - 10号引脚:RNG,10:1范围 - 11号引脚:HLD - 12NC引脚:无连接要求 - 13号引脚:NC,无连接要求
参数特性: - 显示范围:±19999计数 - 显示类型:0.5"(13mm)7段LCD自动显示,当电源<7.2VDC时显示“LoBat” - 测量输入:标准±200.0 mV,±2.000 V,±20.00 VDC单端9V供电,5V供电时差分±10 VDC在200 mV;±100 VDC在2V;±350 VDC在20V范围内 - 阻抗:在±200 mV上>100 MΩ;在2V和20V范围上>1 MΩ - 准确度:最大±(0.06% fs + 1计数) - 转换速率:每秒2次 - 电源抑制:>30 dB @ 60Hz - 预热时间:典型10分钟
功能详解: DK700-710系列提供高精度测量,具有多种输入范围和电源选项。它们支持自动量程选择,并具备用户可选的四位下位数字空白功能,适用于输入值大于19999或小于-19999的情况。
应用信息: 这些数字面板表适用于需要精确测量和显示的多种应用场合,包括工业控制、医疗设备和测试仪器等。
封装信息: - 安装选项:窗口安装或表面安装,快装式边框安装 - 工作温度范围:0到50°C(DK700),-10到70°C(DK710) - 供电电压:+5VDC(4.65 - 5.35)在2.6 mA,+7.2到+12V在1.5 mA - 封装类型:13引脚,0.025"方格,0.1"中心距
DK712 价格&库存
很抱歉,暂时无法提供与“DK712”相匹配的价格&库存,您可以联系我们找货
