DK630
DK630
    C-TON
    VOLTMETER 200MVDC LED PANEL MT
DK630 数据手册
DK630-640 LED Digital Panel Meters Specifications Installation and Operating Instructions 3½ Digit LED Display FEATURES }} }} }} }} }} 0.56", 3½ digit high intensity LED display Available in RED, BLUE or GREEN User-selectable decimal points Polycarbonate case Optional bezel mount SPECIFICATIONS ORDERING INFO DISPLAY PART NUMBER Numeral Size: Overrange: Polarity Indication: Supply Voltage: INPUTS Input Ranges: Input Impedance: Common Mode Range: PERFORMANCE Accuracy: Sampling Rate: .56” (14.27 mm) three lower order digits blank for inputs >1999 & < -1999 automatic (-) for negative +5 VDC @ 40 mA ±200 mV, ± 2 V, ±20 V 1000 MΩ (200 mV) 1 MΩ (other ranges) ± 1 VDC ±1% F.S. ± 2 counts 3 per second ENVIRONMENT Operating Temperature: 0 to 50 °C Max Humidity: 95% (non-condensing) CONNECTION 12 pin METER COLOR METER INPUT DK630.......................................... RED..............................................200mV DK631.......................................... RED.................................................... 2V DK632.......................................... RED.................................................. 20V DK633........................................ GREEN............................................200mV DK634........................................ GREEN.................................................. 2V DK635........................................ GREEN................................................ 20V DK636..........................................BLUE..............................................200mV DK637..........................................BLUE.................................................... 2V DK638..........................................BLUE.................................................. 20V DK640............................ RED with hold function................................200mV DK641............................ RED with hold function...................................... 2V DK642............................ RED with hold function ................................... 20V ACCESSORIES DLA-BEZ . ............................................................................Bezel Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply CVC...............................................................................................Calibrator C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LED Digital Panel Meters Specifications Installation and Operating Instructions DK630-640 3½ Digit LED Display DIMENSIONS Pin Dimensions: 0.025" (0.626 mm) x 0.025" (0.626 mm) To enable DPs (Pin 4-6) connect to Pin 3 (5V return) Pin 3 should be tied to Pin 12 for normal operation Connect Pins 7 & 8 For hold option, connect Pin 2 to Pin 1 (+5V supply) C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK630
物料型号: - DK630-640系列LED数字面板表。
器件简介: - 该系列为3½位LED显示表,具有0.56"高亮度LED显示屏,提供红色、蓝色或绿色选项,用户可选择小数点显示,采用聚碳酸酯外壳,可选的前框安装。
引脚分配: - 共有12个引脚,具体分配如下: - Pin 1: +5V供电 - Pin 2: 5V供电测试(OPTHOL) - Pin 3: 5V返回 - Pin 4-6: 启用DP(连接到Pin 3) - Pin 7 & 8: 连接以启用保持功能 - Pin 9: 负输入低(-)INPUT LO - Pin 10: 正输入高(+)INPUT HI - Pin 11: 模拟公共 - Pin 12: 正常操作应连接到Pin 3
参数特性: - 数字大小:0.56”(14.27 mm) - 过载:输入大于1999或小于-1999时,三个低阶数字空白 - 极性指示:自动显示负号(-) - 供电电压:+5V DC @ 40 mA ±200 mV,±2 V,±20 V - 共模范围:±1 VDC - 输入阻抗:1000 MΩ(200 mV),1 MΩ(其他范围) - 精度:±1% F.S. ± 2 counts - 采样率:每秒3次
功能详解: - 该系列表具有高亮度LED显示,用户可自定义小数点位置,支持负值自动显示负号,提供多种供电电压选项,并具备高精度和快速采样率。
应用信息: - 适用于需要数字显示的各种工业和商业应用,如电力、自动化控制等领域。
封装信息: - 尺寸:引脚尺寸为0.025" x 0.025"(0.626 mm x 0.626 mm),并提供前框安装选项。
DK630 价格&库存
很抱歉,暂时无法提供与“DK630”相匹配的价格&库存,您可以联系我们找货
