DK502
DK502
    C-TON
    VOLTMETER 20VDC LCD PANEL MOUNT
DK502 数据手册
DK500 LCD Digital Panel Meters Specifications Installation and Operating Instructions 3 1/2 Digit LCD - Snap-in Mount FEATURES }} }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Polarity: Decimal Points: Overrange: Hold: INPUTS Ranges: Configuration: Protection: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coefficient: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY 5V powered: 9V(±5V) powered: MOUNTING CONNECTION Low-cost, high-performance replacement for many OEM DPMs Mounting: Snap-in bezel mount eliminates mounting hardware Low power: choice of 180µA (9V) or 2.5mA (+5V) Space-saving design: only 1" (25 mm) deep Occupies less than 2.5 X 1.1 inches of front panel space 3 1/2 digits with high-contrast LCD Optional loop powered 4 to 20mA process inputs available (see DK590) ORDERING INFO 3 ½ digits (±1999 counts) 0.5" (12mm) high-contrast reflective LCD automatic, “-” displayed 3 position, user-selectable three lower order digits blank for inputs >1999 & < -1999 available OEM option, contact factory PART NUMBER BACKLIGHT COLOR METER INPUT METER POWER BACKLIGHT POWER DK500...........NO BACKLIGHT ....... 200mV ......... +5VDC . ....................NONE DK501...........NO BACKLIGHT .......... 2V ............ +5VDC . ....................NONE DK502 ..........NO BACKLIGHT ......... 20V ........... +5VDC . ....................NONE DK503...........NO BACKLIGHT ....... 200mV ......... +9VDC . ....................NONE DK504...........NO BACKLIGHT .......... 2V ............ +9VDC . ....................NONE DK505 ..........NO BACKLIGHT ......... 20V ........... +9VDC . ....................NONE ±200.0 mV, ±2.000 V, ±20.00 VDC bipolar & differential ±350 VDC, (±100 VDC on 200 mV range) >10 MΩ, (>1 MΩ on 20 V range) ACCESSORIES J1C4........................................................... 4 Pin Connector / Wire Assembly J1C13....................................................... 13 Pin Connector / Wire Assembly ±(0.1% +1 count) typical ±(0.1% + 2 counts) maximum 2.5 per second >30 dB @ 60 Hz ±1 VDC >86 dB automatic 10 minutes typical ±100 ppm per °C typical PW2-5........................................ Regulated 120V AC to 5V DC Power Supply PW2-12.................................... Regulated 120V AC to 12V DC Power Supply CVC...............................................................................................Calibrator 0 to 50 °C -10 to 70 °C +5 VDC (±5%) at 2.5 mA +7.2 to +12 V at 180 µA snap-in bezel mount 13 pins, 0.025" square on 0.1" centers - pin 3 missing C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com DK500 LCD Digital Panel Meters Specifications Installation and Operating Instructions 3 1/2 Digit LCD - Snap-in Mount PANEL CUTOUTS BEZEL MOUNT DIMENSIONS WIRING CONNECTIONS PIN # PIN NAME DESCRIPTION 1 2 3 4 5 6 7 8 9 10 11 12 13 C-TON Industries V+ POSITIVE DPM POWER SUPPLY V- NEG POWER FOR 9V OR ±5V DPMS NC NO PIN GND NEGATIVE POWER FOR +5V DPMS COM ANALOG COMMON INLO DISPLAY INPUTS: DISPLAY NEGATIVE INHI IF INHI IS LOWER THAN INLO RFL (CLK) NEG REFERENCE INPUT (AND OPTIONAL HOLD) RFH POSITIVE REFERENCE INPUT ROH INTERNAL REFERENCE OUTPUT D3 DECIMAL POINT = 1XX.X* D2 DECIMAL POINT = 1X.XX* D1 DECIMAL POINT = 1.XXX* *Connect to Pin 1 • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK502 价格&库存
很抱歉,暂时无法提供与“DK502”相匹配的价格&库存,您可以联系我们找货
