DK704
DK704
    C-TON
    VOLTMETER 200MVDC LCD PANEL MT
DK704 数据手册
DK700-710 LCD Digital Panel Meters Specifications Installation and Operating Instructions Low Cost 4½ Digit LCD Display FEATURES }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Polarity: Annunciators: Decimal Points: Overrange: Hold: INPUTS Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY 5V powered: 9V powered: MOUNTING DK700: DK710: CONNECTION ORDERING INFO DK700 SERIES - WINDOW / SURFACE MOUNT 4 ½ digits (±19999 counts) 0.5" (13mm) 7 segment LCD automatic, “-” displayed “LoBat” when power 19999 & < -19999 standard PART NUMBER ±200.0 mV, ±2.000 V, ±20.00 VDC single ended for 9 V powered, differential for 5 V powered ±10 VDC on 200 mV ; ±100 VDC on @ 2V ; ±350 VDC on 20 V range >100 MΩ on ± 200 mV ; (>1 MΩ on 2 V & 20 V range) 10 pA typical ±(0.06% fs + 1 count) maximum 2 per second >30 dB @ 60 Hz ±1 VDC (5 V powered) >86 dB automatic 10 minutes typical ±50 ppm per °C typical ±100 ppm max for 200 mV range ±100 ppm per °C typical ±200 ppm max for 2V and 20V ranges METER INPUT DK703 ...........................................2V ............................................. +5VDC DK704 ....................................... 200mV ................................................. 9V DK705 ...........................................2V .................................................... 9V DK710 SERIES - SNAP-IN BEZEL MOUNT METER INPUT DK711 ...........................................2V ............................................. +5VDC DK712 ..........................................20V ............................................ +5VDC ACCESSORIES J4C13....................................................... 13 Pin Connector / Wire Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply PW2-12.................................... Regulated 120V AC to 12V DC Power Supply CVC...............................................................................................Calibrator +5 VDC (4.65 - 5.35) at 2.6 mA +7.2 to +12 V at 1.5 mA surface or window mount snap-in bezel mount C-TON Industries METER POWER DK710 ....................................... 200mV .......................................... +5VDC 0 to 50 °C -10 to 70 °C 13 pins, 0.025" square on 0.1" centers METER POWER DK702 ....................................... 200mV .......................................... +5VDC PART NUMBER Ranges: Configuration: Protection: Impedance: Bias Current: PERFORMANCE Low-cost, high-performance replacement for many OEM DPMs Mounting choices: Window mount for custom OEM Surface mount with minimum space behind the panel Snap-in bezel mount eliminates mounting hardware Low power: choice of 1.5mA (9V) or 2.6mA (+5V) Space-saving design: only 1" (25 mm) deep Occupies less than 2.5 X 1.1 inches of front panel space 4½ digits with high-contrast LCD • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com DK700-710 LCD Digital Panel Meters Specifications Installation and Operating Instructions Low Cost 4½ Digit LCD Display WINDOW/SURFACE MOUNT DIMENSIONS PANEL CUTOUTS SNAP-IN BEZEL MOUNT DIMENSIONS WIRING CONNECTIONS PIN # PIN NAME DESCRIPTION 1 2 3 4 5 6 7 8 9 10 11 12 13 C-TON Industries V+ V- INHI INLO D1 D2 D3 D4 DP RNG HLD NC NC POSITIVE SUPPLY CONNECTION NEGATIVE SUPPLY CONNECTION INPUT HIGH TERMINAL INPUT LOW TERMINAL DECIMAL POINT = 000.0 DECIMAL POINT = 00.00 DECIMAL POINT = 0.000 DECIMAL POINT = .0000 TO DECIMAL DP COMMON CONNECT POINTS TO ACTIVATE 10:1 RANGE CONNECT TO V+ HOLD FEATURE POINTS TO ACTIVATE NO CONNECTION REQUIRED NO CONNECTION REQUIRED } • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK704 价格&库存
很抱歉,暂时无法提供与“DK704”相匹配的价格&库存,您可以联系我们找货
