DK573
DK573
    C-TON
    VOLTMETER 20VDC LCD PANEL MOUNT
DK573 数据手册
DK540-580 LCD Digital Panel Meters Specifications Installation and Operating Instructions EPIC Series - 3½ Digit LCD FEATURES }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Backlighting: Polarity: Annunciators: Decimal Points: Overrange: INPUTS Ranges: Configuration: Protection: Impedance: Bias Current: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY Optional Backlight: MOUNTING CONNECTION Low-cost, high-performance replacement for many OEM DPMs Optional RED, GREEN or AMBER backlighting Snap-in bezel mount eliminates mounting hardware Resistant to RF and EMI 3½ digits with high-contrast LCD User-selectable, displayed engineering units ORDERING INFO PART NUMBER 3½ digits (±1999 counts) 0.45" (11.4 mm) 7 segment LCD Optional Red Negative (red numbers/black background) Optional Green Negative (green numbers/ black background) Optional Amber Negative (amber numbers/ black background) Optional Green Positive (black numbers / green background) automatic, “-” displayed °F, °C, PSI, %, user-selectable 3 position, user-selectable three lower order digits blank for inputs >1999 DK543 ................. NO BACKLIGHT ................... 20V ............................NONE DK551 ....................NEG AMBER ...................200mV ......................... 5VDC DK552 ....................NEG AMBER ...................... 2V............................. 5VDC DK553 ....................NEG AMBER ..................... 20V............................. 5VDC DK561 .................... NEG GREEN ...................200mV ......................... 5VDC DK562 .................... NEG GREEN ...................... 2V ............................. 5VDC DK563 .................... NEG GREEN ..................... 20V ............................ 5VDC DK571 ...................... NEG RED .....................200mV........................... 5VDC DK572 ...................... NEG RED ........................ 2V.............................. 5VDC ± (0.1% fs + 2 count) 3 per second >30 dB @ 60 Hz ±1 VDC max >86 dB automatic 10 minutes typical ±100 ppm per °C typical C-TON Industries METER INPUT BACKLIGHT POWER DK542 ................. NO BACKLIGHT .................... 2V ............................NONE ±200.0mV, ±2.000V, ±20.00V DC bipolar differential ±350 VDC, (±100 VDC on 200 mV range) 1000 MΩ on ± 200 mV; (1 MΩ on 2 V & 20 V range) 1 pA ( ± 200 mV) , 100 pA (other ranges) 0 to 50 °C -10 to 70 °C 5 VDC at 3.5 mA max 24 VDC at 35 mA, 5 VDC at 130mA typical snap-in bezel mount 13 pins, 0.025" square BACKLIGHT COLOR DK541 ................. NO BACKLIGHT .................200mV .........................NONE DK573 ...................... NEG RED ....................... 20V............................. 5VDC DK581 .................... POS GREEN ...................200mV........................... 5VDC DK582 .................... POS GREEN ...................... 2V.............................. 5VDC DK583 .................... POS GREEN ..................... 20V............................. 5VDC ACCESSORIES J4C13....................................................... 13 Pin Connector / Wire Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply PW2-24.................................... Regulated 120V AC to 24V DC Power Supply CVC...............................................................................................Calibrator • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK540-580 EPIC Series - 3½ Digit LCD DIMENSIONS WIRING PIN # PIN NAME DESCRIPTION 1 +5V +5V POWER SUPPLY 2 NEG POWER SUPPLY GROUND 3 INHI POSITIVE INPUT SIGNAL 4 INLO NEGATIVE INPUT SIGNAL 5 COM DECIMAL COMMON 6 000.0 000.0 WHEN CONNECTED TO DECIMAL COMMON 7 00.00 00.00 WHEN CONNECTED TO DECIMAL COMMON 8 0.000 0.000 WHEN CONNECTED TO DECIMAL COMMON 9 NC NO CONNECTION REQUIRED 10 NC NO CONNECTION REQUIRED 11 SH SIGNAL HOLD WHEN CONNECTED TO V+ 12 BLV+ BACKLIGHT V+ (BACKLIT MODELS ONLY) 13 BLV- BACKLIGHT V- (BACKLIT MODELS ONLY) Note: Pins 2 & 4 should be tied together for proper operation C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK573 价格&库存
很抱歉,暂时无法提供与“DK573”相匹配的价格&库存,您可以联系我们找货
